1202 rớt nước khách bỏ pin vào sài một hồi ngủ luôn.em kẹp nguồn ko có dao động.em chà sấy kỹ ,bóc nguồn+cu+flash .rồi em nạp lại phân mềm thì nó báo vậy?
Detected PKEY: 9002CF36
Card life counter: 77.87%
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Phone Type:
MCU Flash file: D:\PHAI NOKIA\phai nokia\rh-112\1202_RH-112_sw03.10ppmMR\rh112_003.100
Phone Type:
PPM Flash file: D:\PHAI NOKIA\phai nokia\rh-112\1202_RH-112_sw03.10ppmMR\rh112_003.10mr
Phone Type:
CNT Flash file: D:\PHAI NOKIA\phai nokia\rh-112\1202_RH-112_sw03.10ppmMR\rh1120_nai03.10mr
MCU: D:\PHAI NOKIA\phai nokia\rh-112\1202_RH-112_sw03.10ppmMR\rh112_003.100
Booting phone...
Phone didn't answer with TX line low after UEM reset!
Causes:
1. put a 27-33 pico capacitor in connector b/w mbus-gnd.
2. UEM damaged -> replace uem.
MCU ID: 0xDDDD
This MCU ID is not supported in chosen flash file...
Error booting phone...
Booting phone...
Causes:
MCU ID: 0xDDDD
Booting phone...
MCU ID: 0xFFFF
Booting phone...
Causes:
MCU ID: 0xDDD
em thay .cpu+nguồn nó cũng báo như vậy.mong anh em nhiệt tình cứ giúp
