n1202 thay CPU chạy JAF báo:
JAF version 1.98.62
Detected PKEY: 9002DF6E
Card life counter: 64.28%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.10il
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh1120_nai03.10il
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-112\rh112_003.100
Booting phone...
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
This MCU ID is not supported in chosen flash file...
Error booting phone...
anh em nào có kinh nghiệm về 1202 chỉ dùm.
thank you!!
