Kết quả 1 tới 3 của 3
    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định ::::::Furious Pinout,s ::::::
    Hi ..Here U Will Find All Kind Of Furious Box Pinouts.
    Rj45 ,Usb etc
    LG 18 PIN CONNECTOR
    1..........................18
    1 GND connect to 6, 7 RX, 8 TX
    O2X4 PINOUT
    KEYBOARD
    1----------10
    1,2 - GND (black)
    7 - Data + (green)
    8 - Data - (white)
    10 - +5V USB (red)
    BenQ, O2X3, M300, O2x1b, O2x1li PINOUT
    KEYBOARD
    1----------10
    1 - GND
    5 - RX
    6 - TX
    NEWGEN, 8150, 8210, 8290, 8260, C1200
    24.............12.........6.......1
    13 RX PHONE
    14 TX PHONE
    12,19 GND
    LOBSTER PINOUT
    KEYBOARD
    1------------------18
    17,18 - GND
    12 - RX
    11 - TX
    T28 Cable
    Phone pins:
    +++Keyboard+++
    |12345678|9|1011|
    pins:
    1. nc
    2. nc
    3. nc
    4.
    5.
    6.Rx Phone
    7.Tx phone
    8.
    9. Vcc 5V
    10.GND - to RJ45 pin 3
    LG 3G PINOUT:
    Phone pins:
    24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
    21 link to 2
    19 link to 12 GND green
    18 Tx white
    17 Rx red
    16 Vcc +5v orange
    Sharp 802/902/703/903 PINOUT
    Use video connector of phone:
    1.
    2. gnd
    3.
    4.
    5. Phone Tx
    6.
    7. Phone Rx
    8.
    9. + 5V to rj45 +5v AND over 1 Kohm resistor to RJ45 Tx Pin
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
    Aug 2006
    Tp.Hồ Chí Minh
    VG207, VK207i, VK500, VK520, VK530, VK560, VK570, VK900
    18-pin connector
    KEYBOARD
    1.........18
    1. Ground
    7. Rx
    8. Tx
    microsnapper Pinout:
    Keyboard
    1 = Gnd
    11 = Tx
    12 = Rx
    MAXON 79XX AND O2X1 PINOUT:
    Standard data cable 3v interface
    keyboard UP
    1............12
    1+12 - GND
    10 - Tx
    11 - Rx
    SIEMENS C62 Cable Fix for cable that comes with box
    if u have c62 furious cable that only have red (+) wire .. u must open the cable jack.. and see
    2 Gnd
    5 Tx
    7 Rx
    9 +9v
    simply take a new wire and jumper it into (2) Gnd..
    Now it is ur Gnd (- )wire
    Now cable is ready to unlock c62 mobiles...connect to the furiuos box.. left click must be push to the box..
    Must note that when upper left LED is RED means +5V is enabled. I say that because on soem boxes on position means button unpressed
    Panasonic VS2,VS3,SA6,MX6,VS6,VS7,SA7,MX7
    Connector: NEC N8, E228/313/616/338
    PINOUT:
    1_2_3_4_5_6_7_8_9_10
    o o o o o o o o o o
    o o o o o o o o o o (o)
    11________________20
    *****KEYBOARD*****
    Test-Mode cable: USB cable
    1: Gnd
    2: USB-Green
    3: USB-White
    4: USB-Red (USB power)
    PANASONIC A100/PHILIPS 568Pin
    Signal
    Description
    4 Gnd 3 RxD 1 TxD
    PINOUT FOR DRAGON/ARIMA:KEYBOARD
    18...........1
    2- GND
    13-Rx
    14-Tx
    for Rx/Tx lines is better to use cable with 4.7k-10k resistors on +5v
    PINOUT FOR GR1000 AND ONDA N3000:KEYBOARD
    1...........18
    2- GND
    4 - Rx
    5 - Tx
    pinout For Toshiba Ts10/nec 343/nec 121:
    | 1 2 3 4 5 |
    | 6 7 8 9 . |
    \________/
    5 - Gnd
    9 - Rx
    10 - Tx
    Aug 2006
    Tp.Hồ Chí Minh
    KONKA 926 PINOUT:
    pinout :
    * 0 #
    1---18
    7-TX
    9-RX
    18-GND
    NEC 18 PIN CONNECTOR (ex. 412i/949/L1 etc)
    in case user use orig charger connector
    keyboard
    1----------18
    1 V-bus(+5v)
    2 D+
    3 D-
    4 GND
    charger connector cable soldering side
    3- 6- 9- 12- 15- 18-
    2- 5- 8- 11- 14- 17-
    1- 4- 7- 10- 13- 16-
    THOMPSON TN320:
    pinout :
    * 0 #
    1---18
    7-TX
    9-RX
    18-GND
    Lobster 544:Keyboard UP
    1...14
    7: Gnd
    8: Phone Rx
    9: Phone Tx
    LG QUALCOMM U300/U500/U880/u890/U900/U8500/KU730
    ORIGINAL USB CABLE OR SAMSUNG Z140 USB CABLE
  1. Trả lời: 3
    Bài viết cuối: 01-07-2015, 18:51
  2. ZTE T12 unlock ok furious
    By TuệNguyễn in forum FuriouS Team Products
    Bài viết cuối: 18-11-2014, 16:51
  3. tư vấn box Furious
    By phicong1991 in forum FuriouS Team Products
    Bài viết cuối: 22-04-2013, 09:03
  4. [Furious-Gold] [2.0] [Furious-Gold Developer Program Launched]
    By hungphongmobile™ in forum FuriouS Team Products
    Bài viết cuối: 31-01-2009, 11:39
  5. furious gold và furious blink!
    By vulua in forum FuriouS Team Products
    Bài viết cuối: 15-12-2007, 13:50
