Good evening dear comrads,
Today we add free of charge:
SUPPORT FOR : KG270, KG271, KG275, KG276, KG278, MG160, MG161
SUPPORTED FEATURES:
[X] FLASH WRITE
[X] FLASH READ
[X] IMEI CHANGE/REPAIR
[X] CODE READ (*)
(*) IF SOFT SHOWS LOCKS INACTIVE BUT PHONE IS LOCKED IN FACT PLEASE SEND US THE CREATED BACKUP BY SOFT WHILE 'DIRECT UNLOCK/READ CODE' OPERATION.
ALSO FOR SOME FIRMWARES FLASHING IS NEEDED IN ORDER TO ALLOW 'UNLOCK CODE' ENTERING.
ALSO ADDED SUPPORT FOR A NEW FLASH CHIP FOUND IN KE850/ME850 MODELS.
ALSO FIXED A PROBLEM ON LG U830 COUNTRY CODE CHANGING.
FWS ADDED:
./KG270
KG270P16-07-V10c-XXX-XX-APR-17-2007.zip
KG270P16-07-V10e-XXX-XX-MAY-30-2007.zip
KG270P16-852-V10b-XXX-XX-MAY-09-2007.zip
KG270P16-886-V10c-XXX-XX-MAY-02-2007.zip
KG270P16-AFR-V10a-XXX-XX-APR-02-2007.zip
KG270P16-AFR-V10c-XXX-XX-MAY-09-2007.zip
KG270P16-ARB-V10b-XXX-XX-APR-09-2007.zip
KG270P16-ARB-V10c-XXX-XX-APR-30-2007.zip
KG270P16-ESA-V10b-XXX-XX-APR-17-2007.zip
KG270P16-ESA-V10c-XXX-XX-MAY-03-2007.zip
KG270P16-ESA-V10d-XXX-XX-MAY-10-2007.zip
KG270P16-ESA-V10g-XXX-XX-JUN-05-2007.zip
KG270P16FL-61-V10a-505-02-MAY-09-2007+0.zip
KG270P16FL-91-V10b-404-XX-APR-13-2007.zip
KG270P16FL-91-V10e-404-XX-JUN-07-2007.zip
./KG271
KG271P16-886-V10b-XXX-XX-APR-11-2007.zip
KG271P16-91-V10a-XXX-XX-APR-18-2007.zip
KG271P16-91-V10d-XXX-XX-JUN-12-2007.zip
KG271P16-ESA-V10a-XXX-XX-APR-09-2007.zip
KG271P16-ESA-V10d-XXX-XX-MAY-14-2007.zip
KG271P16-ESA-V10e-XXX-XX-JUN-11-2007.zip
./KG275
KG275P16-212-V10b-XXX-XX-MAY-10-2007.zip
KG275P16-886-V10b-XXX-XX-APR-11-2007.zip
KG275P16-92-V10d-XXX-XX-MAY-29-2007.zip
KG275P16-AFR-V10a-XXX-XX-APR-02-2007.zip
KG275P16-AFR-V10c-XXX-XX-MAY-09-2007.zip
KG275P16-ARB-V10b-XXX-XX-APR-09-2007.zip
KG275P16-ESA-V10a-XXX-XX-APR-05-2007.zip
KG275P16-ESA-V10c-XXX-XX-MAY-03-2007.zip
KG275P16-ESA-V10e-XXX-XX-MAY-22-2007.zip
KG275P16FL-33-V10b-208-01-JUN-08-2007+1.zip
KG275P16FL-34-V10b-214-03-JUN-08-2007+1.zip
KG275P16FL-351-V10b-268-06-MAY-29-2007+2.zip
KG275P16FL-40-V10b-226-10-JUN-08-2007+1.zip
KG275P16FL-91-V10e-404-XX-JUN-07-2007.zip
./KG276
KG276P16-91-V10a-XXX-XX-APR-18-2007.zip
KG276P16-92-V10c-XXX-XX-MAR-28-2007.zip
KG276P16-ESA-V10c-XXX-XX-MAY-03-2007.zip
./KG278
KG278P16-CHN-V10e-XXX-XX-MAR-19-2007.zip
./MG160
MG160aP16FL-502-V10a-704-01-May-14-2007+3.zip
MG160aP16FL-502-V10a-704-02-May-11-2007+3.zip
MG160aP16FL-505-V10a-710-21-May-08-2007+2.zip
MG160aP16FL-52-V10a-334-020-FEB-14-2007+3.zip
MG160aP16FL-55-V10c-724-06-MAR-12-2007+4.zip
MG160aP16FL-57-V10a-732-101-Apr-11-2007+5.zip
MG160aP16FL-593-V10a-740-01-Apr-04-2007+4.zip
MG160aP16FL-AM_MOV-V10a-722-07-MAY-17-2007+5.zip
MG160bP16FL-55-V10a-724-05-MAR-19-2007+1.zip
MG160bP16FL-55-V10a-724-16-Apr-13-2007+2.zip
./MG161
MG161aP16FL-AM_MOV-V10a-716-06-MAR-22-2007+3.zip
MG161aP16FL-AM_MOV-V10a-732-123-APR-04-2007+3.zip
MG161aP16FL-AM_MOV-V10a-734-04-MAR-29-2007+4.zip
As allways latest version can be found in BETA folder of our support.
