em tét thu con N81 rồi chạy phà phà mấy anh àh.căm ơn anh CHDD HUNG PHONG nhiều nà
mới unlock xong cây 5610d-2b
đây là log
Reading phone info ...
3/31/2009 9:45:46 AM >> Type: RM-359
3/31/2009 9:45:46 AM >> Version: V_05.92_14-03-08_RM-359_(c)_Nokia
3/31/2009 9:45:46 AM >> IMEI: 359303020759069
3/31/2009 9:45:47 AM >> SP LOCK status:
3/31/2009 9:45:47 AM >> Config Key: 8000000000000000
3/31/2009 9:45:47 AM >> Provider Key: 3102000000000000
3/31/2009 9:45:47 AM >> Block 1: CLOSED Type 5 Data: 310160
3/31/2009 9:45:47 AM >> Block 2: CLOSED Type 5 Data: 310200
3/31/2009 9:45:47 AM >> Block 3: CLOSED Type 5 Data: 310210
3/31/2009 9:45:47 AM >> Block 4: CLOSED Type 5 Data: 310220
3/31/2009 9:45:47 AM >> Block 5: CLOSED Type 5 Data: 310230
3/31/2009 9:45:47 AM >> Block 6: CLOSED Type 5 Data: 310240
3/31/2009 9:45:47 AM >> Block 7: CLOSED Type 5 Data: 310250
3/31/2009 9:45:47 AM >> Block 8: CLOSED Type 5 Data: 310260
3/31/2009 9:45:47 AM >> Block 9: CLOSED Type 5 Data: 310270
3/31/2009 9:45:47 AM >> Block 10: CLOSED Type 5 Data: 310310
3/31/2009 9:45:47 AM >> Block 11: CLOSED Type 5 Data: 310580
3/31/2009 9:45:47 AM >> Block 12: CLOSED Type 5 Data: 310660
3/31/2009 9:45:47 AM >> Block 13: CLOSED Type 5 Data: 310800
3/31/2009 9:45:47 AM >> Block 14: CLOSED Type 5 Data: 310202
3/31/2009 9:45:47 AM >> Counters: 0/3, 0/10
3/31/2009 9:45:47 AM >> Phone is Locked
3/31/2009 9:45:47 AM >> Read Phone Info OK
3/31/2009 9:45:58 AM >> Searching for JAF box ...
3/31/2009 9:45:58 AM >> JAF box detected
3/31/2009 9:45:59 AM >> Box firmware version: 1B1
3/31/2009 9:46:09 AM >> Searching for phone ...
3/31/2009 9:46:09 AM >> Phone found on FBUS interface
3/31/2009 9:46:09 AM >> Reading phone info ...
3/31/2009 9:46:09 AM >> Type: RM-359
3/31/2009 9:46:09 AM >> Version: V_05.92_14-03-08_RM-359_(c)_Nokia
3/31/2009 9:46:09 AM >> IMEI: 359303020759069
3/31/2009 9:46:10 AM >> SP LOCK status:
3/31/2009 9:46:10 AM >> Config Key: 8000000000000000
3/31/2009 9:46:10 AM >> Provider Key: 3102000000000000
3/31/2009 9:46:10 AM >> Block 1: CLOSED Type 5 Data: 310160
3/31/2009 9:46:10 AM >> Block 2: CLOSED Type 5 Data: 310200
3/31/2009 9:46:10 AM >> Block 3: CLOSED Type 5 Data: 310210
3/31/2009 9:46:10 AM >> Block 4: CLOSED Type 5 Data: 310220
3/31/2009 9:46:10 AM >> Block 5: CLOSED Type 5 Data: 310230
3/31/2009 9:46:10 AM >> Block 6: CLOSED Type 5 Data: 310240
3/31/2009 9:46:10 AM >> Block 7: CLOSED Type 5 Data: 310250
3/31/2009 9:46:10 AM >> Block 8: CLOSED Type 5 Data: 310260
3/31/2009 9:46:10 AM >> Block 9: CLOSED Type 5 Data: 310270
3/31/2009 9:46:10 AM >> Block 10: CLOSED Type 5 Data: 310310
3/31/2009 9:46:10 AM >> Block 11: CLOSED Type 5 Data: 310580
3/31/2009 9:46:10 AM >> Block 12: CLOSED Type 5 Data: 310660
3/31/2009 9:46:10 AM >> Block 13: CLOSED Type 5 Data: 310800
3/31/2009 9:46:10 AM >> Block 14: CLOSED Type 5 Data: 310203
3/31/2009 9:46:10 AM >> Counters: 0/3, 0/10
3/31/2009 9:46:10 AM >> Phone is Locked
3/31/2009 9:46:10 AM >> Read Phone Info OK
3/31/2009 9:46:10 AM >> Searching for phone ...
3/31/2009 9:46:10 AM >> Phone found on FBUS interface
3/31/2009 9:46:10 AM >> Reading phone info ...
3/31/2009 9:46:10 AM >> Type: RM-359
3/31/2009 9:46:10 AM >> Version: V_05.92_14-03-08_RM-359_(c)_Nokia
3/31/2009 9:46:10 AM >> IMEI: 359303020759069
3/31/2009 9:46:10 AM >> Reading PM Field 308 Subfield 1 with length 8192 bytes
3/31/2009 9:46:13 AM >> PM308 readed OK
3/31/2009 9:46:13 AM >> BB5 FLASH bb5challenge ...
3/31/2009 9:46:15 AM >> ASIC ID: 000000010000022600010006010C192101013000
3/31/2009 9:46:15 AM >> HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
3/31/2009 9:46:15 AM >> ROM ID: 273F6D55DFAAF68F
3/31/2009 9:46:15 AM >> CMT Boot Ready
3/31/2009 9:46:17 AM >> HELLO
3/31/2009 9:46:17 AM >> start
3/31/2009 9:46:17 AM >> JAF BB5Plus No TP by [c]Cinek started.
3/31/2009 9:46:17 AM >> ok
3/31/2009 9:46:18 AM >> Initial PM 308 sent
3/31/2009 9:46:18 AM >> Certificates sent
3/31/2009 9:46:18 AM >> Unlocked PM 308 SL buffer received
3/31/2009 9:46:18 AM >> Unlocked PM 308 field build OK
3/31/2009 9:46:18 AM >> After unlock.
3/31/2009 9:46:30 AM >> Searching for phone ...
3/31/2009 9:46:30 AM >> Phone found on FBUS interface
3/31/2009 9:46:30 AM >> Writting PM Field 308 Subfield 1 with length 8192 bytes
3/31/2009 9:46:34 AM >> Reset phone ...
3/31/2009 9:46:37 AM >> PM Field 308 Subfield 1 written OK
3/31/2009 9:46:48 AM >> Searching for phone ...
3/31/2009 9:46:48 AM >> Phone found on FBUS interface
3/31/2009 9:46:48 AM >> Reading phone info ...
3/31/2009 9:46:48 AM >> Type: RM-359
3/31/2009 9:46:48 AM >> Version: V_05.92_14-03-08_RM-359_(c)_Nokia
3/31/2009 9:46:48 AM >> IMEI: 359303020759069
3/31/2009 9:46:48 AM >> SP LOCK status:
3/31/2009 9:46:48 AM >> Config Key: 8000000000000000
3/31/2009 9:46:48 AM >> Provider Key: 0010100000000000
3/31/2009 9:46:48 AM >> Block 1: OPEN Type 5 Data: 00101F
3/31/2009 9:46:48 AM >> Counters: 0/3, 0/10
3/31/2009 9:46:48 AM >> Phone is Unlocked
3/31/2009 9:46:48 AM >> Read Phone Info OK
3/31/2009 9:46:48 AM >> Successfully done.
3/31/2009 9:46:59 AM >> Searching for JAF box ...
3/31/2009 9:46:59 AM >> JAF box detected
3/31/2009 9:47:01 AM >> Box firmware version: 1B1
3/31/2009 9:47:11 AM >> Searching for phone ...
3/31/2009 9:47:11 AM >> Phone found on FBUS interface
3/31/2009 9:47:11 AM >> Reading phone info ...
3/31/2009 9:47:11 AM >> Type: RM-359
3/31/2009 9:47:11 AM >> Version: V_05.92_14-03-08_RM-359_(c)_Nokia
3/31/2009 9:47:11 AM >> IMEI: 359303020759069
3/31/2009 9:47:11 AM >> SP LOCK status:
3/31/2009 9:47:11 AM >> Config Key: 8000000000000000
3/31/2009 9:47:11 AM >> Provider Key: 0010100000000000
3/31/2009 9:47:11 AM >> Block 1: OPEN Type 5 Data: 00101F
3/31/2009 9:47:11 AM >> Counters: 0/3, 0/10
3/31/2009 9:47:11 AM >> Phone is Unlocked
3/31/2009 9:47:11 AM >> Read Phone Info OK
anh em cứ thoải máy test ko chết máy đâu![]()
Công Sanh Mobile
0710.3855877 - 097.3855877
dailuong (08-09-2009)
pó tay với bác này bao giờ rùi còn đi tìm mấy thứ này.
