Kết quả 1 tới 10 của 16
    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định Video hướng dẫn chạy mcn-pro
    McnPro - Pinouts Detection Procedure - A Quick Scan Guide
    Quick scan RX ,TX
    - Txd Rxd Gnd and Api(sky cpu) Pinout Scan
    - Supports MTK TI ADI INF SKY AGE OM SPD...
    - Takes just a few seconds
    Step by Step:
    * Connect McnPro to computer and open the main software
    * Connect the phone with the right cable via USB etc.
    * Use our special cable to connect phone to Negative / Positive, Box can automatic identification and that already have Protection System, so don't worry about the polarity.
    * Press [Scan Rx Tx]
    * If you already know the based cpu in phone, just select the related one (will be fast), otherwise select "Auto" (will take a few more seconds than usuall)
    * Hold power-on button of your phone and press start button on the software interface , in just a few second you will get results ,eg.
    Quote:
    Scanning results:
    GND: 12 13 ,RXD 10, TXD 15
    Quote:
    Scanning results:
    Spd chipset
    GND: 12 13 ,RXD 10, TXD 15, Boot:6
    Quote:
    API Scanning results:
    API Pin 4-5
    * You can save the scan results , because you might need that for the flash process
    * BTW, for SKY cpu it's a little be different, Api can be detected and phone can be Reset. IMEI can be change too. (plz follow the window step by step procedure, its very easy.) eg.
    Quote:
    Scanning results:
    SKY chipset
    Scanning API pin(Please waiting...)
    API pin 5-6
    Quote:
    Connect ok
    Modify imei...
    Modify successful !
    USB Scan
    - Charge / Boot pin ,USBD+/-
    - Will take more seconds than above step
    Step by Step:
    * Press [USB Scan]
    * In select option choose the same cable which you used, Eg. Mcnpro-11
    * Hold power-on of your phone and press [Read starts] button on the software interface .eg.
    Quote:
    Scanning pin-status, please waiting..
    9,10 short-pin
    >>Pin-status scanning completed
    * Press [Charge-pin] button Box will be start to analyzing ,then follow the window step by step to do the procedure.when computer find a new USB device which mean's all step done. eg.
    Quote:
    USB D-:8 USB D+: 7 VCC:1 GND: 6 11
    If scan other phone ,please press [stop]
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
  2. ( saigonmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    VŨ PRO (14-07-2010)
  1. Video hướng dẫn chạy ATF
    By HoangThong_hotrokythuat5 in forum Advance Turbo Flasher
    Trả lời: 13
    Bài viết cuối: 21-10-2013, 15:47
  2. video hướng dẫn chạy jaf
    By NGUYÊNQNGAI in forum J.A.F
    Bài viết cuối: 22-11-2010, 14:16
  3. ae ai có video chạy hộp z3x cho mình xin với !!
    By minhquan0989908397 in forum Phần mềm Samsung
    Bài viết cuối: 10-04-2010, 13:00
  4. video chạy sámung bằng HWK
    By vipnokia in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 13-03-2010, 09:25
  5. VIDEO chạy hwk bao gồm
    By van_ninh_mobile in forum BB5
    Bài viết cuối: 27-12-2009, 07:07
