ai có mx-box thử giúp mình coi có dc k ? thanks
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C085E81D
Using device: HTI, FW ver: 00.50, SN: 01006CF8
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
ERROR: Packet Error(0xAA), code 0xC0000002
Error details:
Bad contact, TX line remains low !
VCC_PH BSI TX RX RX2 CLK
0 0 0 1 1 0
ERROR: bootstrap failed!
bạn check máy gì thế ! hinh như sai cáp rùi
MLONG_GSM (21-04-2012)
kiểm tra cáp đi nha bạn mình vẫn check được bình thường nha bạn
cái cáp thì nói làm gì .đã cài bản cao nhất 3.5 1.9 .cáp đa năng cũng k nhận .hay là sever nó cà tưng .
mở giao diện mx nó báo vậy nè ae
Sever ok mà, buscheck cũng ok luôn , em sài cáp đa năng Fbus II, đây là log :
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN:
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
ASIC ID: 0x3160 [UPP_8M ver: 6.0]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
UEM ID: 001BAB7F:2984DA60
ASIC type: 2
UEM Imei: 35294002331671
Flash Imei: 35294002331671
MasterCode: 4232016155
RPL saved to "C:\mobileEx\3.5\data\backup\35294002331671_BACK.r pl"
Phone type: RM-166 (Nokia 6070)
SW version: V 04.22 24-05-07 RM-166 (c) Nokia.
Imei plain: 35294002331671-5
Imei OTP: 35294002331671
Product code: 0535809
Cellular system: GSM
ASIC ID: 0x3160, type: 2
Ppm Id: V
Language Pack:
English,Vietnamese,Chinese S,Chinese T
Master code: 4232016155
Security code: 12345
Imei net: 35294002331671
Version: SIMLOCK SERVER VERSION 58
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
bạn xóa di cài lại 3 lần đi mình đả găp trường hợp gtuongw tự như bạn rui update driver chuẩn nhớ tất pm diệt vi rút đi nha thân
lấy box khác ra tets phát nếu cộng cáp đó ok thì kiểm tra con transistor cấp áp
lấy con transistor bên 1280 thay qua thử
sao chèn hình vào không được nè
