Trang 13 của 20 Đầu tiênĐầu tiên ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 CuốiCuối
Kết quả 121 tới 130 của 195
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.3.7 - reset FRP boost!
    [/URL]
    Octoplus / Octopus Box Samsung Software v.2.3.7 is out!
    We have added support for Samsung Galaxy XCover, Samsung Galaxy J7, Samsung Galaxy S6 and many other models!
    Octoplus / Octopus Box Samsung Software v.2.3.7 Release Notes:
    🐙 Added support for the following models:
    - SM-G389F - added Direct Unlock, Read Codes, Fast Unlock, Fast Read Codes, Read/Write Cert, Read/Write security, Read/Write EFS, Write Firmware, Read PIT
    - SM-J710F - added Reset FRP (auto-enable ADB)
    - SM-J710FN - added Reset FRP (auto-enable ADB)
    🐙 Added Reset FRP via ADB for next devices (ADB must be enabled):
    - SM-G890A
    - SM-G920A, SM-G920AZ, SM-G920D, SM-G920F, SM-G920FD, SM-G920FZ, SM-G920I, SM-G920K, SM-G920L, SM-G920S, SM-G920T, SM-G920T1, SM-G920W8
    - SM-G9250, SM-G925A, SM-G925F, SM-G925FQ, SM-G925I, SM-G925K, SM-G925L, SM-G925S, SM-G925T, SM-G925T1, SM-G925W8
    - SM-G9287, SM-G9287C, SM-G928C, SM-G928F, SM-G928G, SM-G928I, SM-G928K, SM-G928L, SM-G928N0, SM-G928S, SM-G928T, SM-G928W8
    - SM-G9300, SM-G9308, SM-G930F, SM-G930FD, SM-G930K, SM-G930L, SM-G930S, SM-G930T, SM-G930T1, SM-G930U, SM-G930V, SM-G930W8
    - SM-G9350, SM-G935D, SM-G935F, SM-G935FD, SM-G935J, SM-G935K, SM-G935L, SM-G935S, SM-G935T, SM-G935T1, SM-G935U, SM-G935V, SM-G935W8
    - SM-J105B, SM-J105F, SM-J105H, SM-J105Y
    - SM-J120A, SM-J120AZ, SM-J120F, SM-J120FN, SM-J120G, SM-J120M, SM-J120P, SM-J120W, SM-J120ZN
    - SM-J200BT, SM-J200F, SM-J200G, SM-J200GU, SM-J200H, SM-J200M, SM-J200Y
    - SM-J210F, SM-J210FD
    - SM-J320A, SM-J320AZ, SM-J320F, SM-J320FN, SM-J320G, SM-J320H, SM-J320M, SM-J320MU, SM-J320ZN
    - SM-J321AZ
    - SM-J5108, SM-J510F, SM-J510FN, SM-J510G, SM-J510H, SM-J510K, SM-J510L, SM-J510N, SM-J510S, SM-J510U
    - SM-N9200, SM-N9208, SM-N920A, SM-N920C, SM-N920CD, SM-N920F, SM-N920G, SM-N920I, SM-N920K, SM-N920L, SM-N920S, SM-N920T, SM-N920T, SM-N920W8
    - SM-N9300, SM-N930A, SM-N930F, SM-N930FD, SM-N930K, SM-N930L, SM-N930P, SM-N930R4, SM-N930S, SM-N930T, SM-N930U, SM-N930W8
    🐙 Combination firmware versions for most models are uploaded into the Support Area ("COMBINATION" folder)
    🐙 New Cert files were uploaded into the Support Area! (thanks to mr.Ca0ss)
    🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software)
    To remove FRP lock you can try to do the following:
    1. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select combination firmware, un-check partitions except "boot.img")
    2. Perform "Reset FRP" operation in the software
    or..
    1. Write Full Combination Firmware
    2. Go to "Developer Options" in the phone’s Settings
    3. Check "Enable OEM unlock" option
    4. Perform Factory Data Reset
    5. Re-flash the phone with full stock (original) firmware
    Note: "boot.img" from combination firmware can be not compatible with current phone's firmware. In that case phone will stuck on logo, or will be rebooting after writing of such boot. To restore the phone to its initial condition you need to re-flash it with different full stock (original) firmware (or try to write only boot of such firmware).
    Note: You can write "boot.img" combination firmware or to downgrade phone's firmware version only on your own risk!
    PS: If you cannot find combination firmware for your model inside "COMBINATION" folder in support area, this means we don’t have this files at the moment.
    Download Octoplus / Octopus Box Samsung Software v.2.3.7
  2. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TuệNguyễn (23-09-2016)
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.3.9 - check inside!
    [/URL]
    Octoplus / Octopus Box Samsung Software v.2.3.9 is out!
    Octoplus/Octopus Box Samsung Software v.2.3.9 is out!
    We have added “Factory Unlock” feature and support for Samsung Galaxy C9, Samsung Galaxy On5 2016 Duos TD-LTE, Samsung Galaxy On7 2016 Duos TD-LTE, Samsung Galaxy J3 and other models!
    Factory Unlock feature is intended to unlock any phone, with some exceptions, that is not supported by normal means, e.g. QC-based devices with revised security. This will be your emergency button, that you don't really have to touch,
    like Factory FRP/Reactivation reset. Of course we are focusing on developing new solutions to expand your possibilities in unlocking with no additional charges, but also we hope for this feature to be handy for you one day. Or in two words: it's not obligatory. You don't have to pay for this if you don't really need this
    Octoplus/Octopus Box Samsung Software v.2.3.9 Release Notes:
    🐙 Added “Factory Unlock” feature!
    - This feature costs 220 Octopus credits per phone. Process time: 0-8 hours
    - Devices with "Device Unlock App" (T-Mobile, MetroPCS and AT&T) are not supported and credits will not be refunded!
    - Sprint, Verizon devices, which IMEIs starting with 99xx are not supported and credits will not be refunded!
    To perform "Factory Unlock" do the next:
    1. Go to "Support & Options" tab in the software
    2. Press "Factory Services (Reset FRP / Unlock)" button
    3. Select UART interface and connect powered on device to Box via UART cable (Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor)
    4. Press "Factory Unlock" button and follow instructions in the software. If software cannot read necessary data from the phone via UART, please select USB interface, connect the phone via USB cable and repeat "Factory Unlock" operation
    5. Factory Unlock process can take 0-8 hours. If the phone will not be unlocked instantly, run the software in a few hours later, press "Status and History" / "Re-fresh" buttons and check unlock status
    6. When status is "Ready", press "Factory Unlock" button again - phone is now unlocked
    7. If device still requests unlock code - enter 00000000 (8 zeroes) code.
    - SM-C9000 - added Read/Write NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Reboot in Download/Recovery mode
    - SM-G5700 - added Read/Write NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable Hidden Languages, Reboot in Download/Recovery mode
    - SM-G6100 - added Read/Write NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable Hidden Languages, Reboot in Download/Recovery mode
    - SM-J320W8 - added Fast Unlock, Fast Read Codes, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-J510MN - added Reset FRP, Read/Write/Repair NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable Diag, Enable Hidden Languages, Reboot in Download/Recovery mode
    - SM-G389F - Reset FRP (via download mode)
    - SM-N930P - added Direct Unlock, Domestic Unlock, Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Read PIT, Write Firmware
    🐙 Improved "Write Cert" operation for Galaxy S6 and S6 Edge phones: fixed issue, when phone IMEI is 350000000000009 and operation stops after "Exploit has been executed successfully". This issue occurs if phone was processed with other tools.
    [INDENT] 🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software).
    https://www.youtube.com/watch?v=4TS5H7aoX9M
    Download Octoplus / Octopus Box Samsung Software v.2.3.9
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.4.0 - introducing 'Fix Multicore Checksum'
    Octoplus / Octopus Box Samsung Software v.2.4.0 is out!
    We have added support for Samsung Galaxy Folder 2, Samsung Galaxy S7 Active, Samsung SM-T719C Galaxy Tab S2 Plus 8.0 and many other models!
    Octoplus / Octopus Box Samsung Software v.2.4.0 Release Notes:
    - SM-G1600 - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-G891A - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T719C - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T719Y - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T818T - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T818V - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T819C - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-T819Y - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-W2017 - added Read/Write NVM, Read/Write Security, Read/Write EFS, Read/Write QCN, Enable DIAG, Enable Hidden Languages, Read PIT, Write Firmware
    - SM-J111F - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J111M - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J210F - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J210FD - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320F - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320FN - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320G - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320H - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320M - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-J320MU - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T280 - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T280Q - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T280QZ - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T285 - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T285M - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T285YD - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    - SM-T287 - added Fix Multicore Checksum, Repair Network (new method). Improved Repair IMEI, Read/Write Cert operations for latest versions of firmware
    🐙 Added Fix Multicore Checksum for the following devices:
    - GT-I9060C, GT-I9060I, GT-I9060M
    - SM-G110B, SM-G110H, SM-G110M
    - SM-G130BU, SM-G130BT, SM-G130E, SM-G130H, SM-G130M, SM-G130HN, SM-G130U
    - SM-G313H, SM-G313HY, SM-G313HZ, SM-G313M, SM-G313ML, SM-G313MU, SM-G313MY, SM-G313U
    - SM-G361H, SM-G361HU, SM-G316M, SM-G316ML, SM-G316U
    - SM-G318H, SM-G318HZ, SM-G318ML, SM-G318MZ
    - SM-G350E
    - SM-G355H, SM-G355HN, SM-G355HQ, SM-G355M
    - SM-G531H
    - SM-G360H, SM-G360HU
    - SM-J100H
    - SM-J105B, SM-J105H, SM-J105Y
    - SM-J110L, SM-J100ML
    - SM-J110H
    - SM-J120H
    - SM-J200H
    - SM-T560, SM-T561, SM-T562
    - SM-T113
    - SM-T116, SM-T116BU, SM-T116IR, SM-T116NQ, SM-T116NU, SM-T116NY
    🐙 Added option to perform DRK fix via UART cable (if phone has FRP lock + corrupted DRK - write combination firmware and fix DRK, then try to reset FRP by known methods)
    Note: All phones, for which "Unlock" operation is not supported at the moment can be unlocked via Factory Unlock service.
    Download Octoplus / Octopus Box Samsung Software v.2.4.0[
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.4.1 - J1 mini, J3 2016 and more!
    Octoplus / Octopus Box Samsung Software v.2.4.1 is out!
    We have added support for Samsung Galaxy S4 zoom, GALAXY Ace 4, GALAXY J1 Mini, Galaxy Tab S2, Galaxy J3 2016 Duos!
    Octoplus / Octopus Box Samsung Software v.2.4.1 Release Notes:
    • Added support for the following models:
    - SM-T713 - added Read/Write NVM/Repair NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
    - SM-T813 - added Read/Write NVM/Repair NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
    - SM-J510UN - added Read/Write NVM/Repair NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
    - SM-J106H - added Direct Unlock, Read Codes, Repair IMEI, Reset FRP, Read/Write Security, Read/Write EFS, Repair Network, Read/Write Cert, Reset FRP, Fix Multicore Checksum, Write Firmware, Factory Services
    - SM-J106F - added Direct Unlock, Read Codes, Repair IMEI, Reset FRP, Read/Write Security, Read/Write EFS, Repair Network, Read/Write Cert, Reset FRP, Fix Multicore Checksum, Write Firmware, Factory Services
    - SM-J320YZ - added Read/Write NVM/Repair NVM, Write Firmware, Read/Write Security, Read/Write EFS, Read/Wrote QCN, Enable DIAG, Enable hidden languages, Reboot in Download/Recovery mode
    - SM-C1010 - added Direct Unlock, Repair IMEI, Read/Write Security, Read/Write EFS, Read/Write Cert, Enable Hidden Languages, Write Firmware
    - SM-G3139D - added Direct Unlock, Read Codes, Repair IMEI, Repair SN, Repair Network, Disable Factory Mode, Enable Hidden languages, Write Firmware, Factory Services
    • Added ability to write Original Samsung versions of Firmware (*.tar, *.md5) for Android devices without converting into *.oct format
    • All supported operations described in details in the manual ("Cable & Manual" button in the software)
    Also, don't forget about possibility to remove FRP/Reactivation lock via Factory Reset FRP service
    Download Octoplus / Octopus Box Samsung Software v.2.4.1
    Jan 2007
    Samsung Tool PRO 27.1 Released. First in the world.
    Samsung Tool PRO 27.1 Released:
    Added:
    - support SM-J106B (Flashing, Unlock, Read codes, Read/Write/Patch CERT, Read/Write EFS, Repair, reboot to download/recovery) - world first
    - support SM-J106M (Flashing, Unlock, Read codes, Read/Write/Patch CERT, Read/Write EFS, Repair, reboot to download/recovery) - world first
    - support SM-G3586V (Flashing, Unlock, Read/Write EFS, Read/Write QCN, Read/Write SEC, Write CERT, reboot to download/recovery)
    - support SM-G610Y (Flashing, Read/Write EFS, Reset FRP, reboot to download/recovery)
    Addition function added:
    - support SM-C111 (Repair, Patch CERT)
    - support SM-C1116 (Repair, Patch CERT)
    - support SM-C111M (Repair, Patch CERT)
    P.S. Something very big on the way! Be ready.
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.4.5 - Oh, wait.. What??
    [/URL]
    Octoplus / Octopus Box Samsung Software v.2.4.5 is out!
    Sometimes it may look like the octopus is hiding... or he ran away. But then, out of nowhere, he attacks!
    Constant hard work and sleepless nights to bring you the best!
    Today we are happy to announce world's first support (Direct Unlock, Read Codes, Read/Write Cert) for the latest firmware version (Security patch level: November 2016) of the most popular Samsung Exynos-based phones.
    Also added world's first support for Galaxy J7 Prime, Galaxy Tab A (2016) series and more!
    Still hesitate? Black Friday is coming soon
    Octoplus / Octopus Box Samsung Software v.2.4.5 Release Notes:
    - SM-N930F – added world's first Direct Unlock, Read Codes, Read Cert
    - SM-N930FD – added world's first Direct Unlock, Read Codes, Read Cert
    - SM-N930S – added world's first Direct Unlock, Read Codes, Read Cert
    - SM-N930K – added world's first Direct Unlock, Read Codes, Read Cert
    - SM-N930L – added world's first Direct Unlock, Read Codes, Read Cert
    - SM-G610F – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610FD – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610FZ – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610L – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610K – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610S – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-G610Y – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-J710FZ – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-P585M – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-P585N – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-P585Y – added world's first Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    - SM-T585 – added Direct Unlock, Read Codes, Read Cert, Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Enable Hidden Languages
    🐙 Added world's first support (Direct Unlock, Read Codes, Read/Write Cert) for the latest firmware version (Security patch level: November 2016) of the following models:
    - Galaxy S7 (SM-G930F, SM-G930FD, SM-G930U, SM-G930VL, SM-G930S, SM-G930K, SM-G930L, SM-G930W8)
    - Galaxy S7 Edge (SM-G935F, SM-G935FD, SM-G935D, SM-G935J, SM-G935U, SM-G935S, SM-G935K, SM-G935L, SM-G935W8)
    - Galaxy Note 5 (SM-N9208, SM-N920A, SM-N920I, SM-N920F, SM-N920F, SM-N920G, SM-N920I, SM-N920K, SM-N920L, SM-N920S, SM-N920T, SM-N9200, SM-N920C, SM-N920CD, SM-N920W8)
    - Galaxy S6 Edge Plus (SM-G928F, SM-G928I, SM-G928K, SM-G928L, SM-G928S, SM-G928T, SM-G928W8, SM-G9287, SM-G9287C, SM-G928G, SM-G928C, SM-G928N0)
    - Galaxy A3 2016 (SM-A310N0, SM-A310F, SM-A310FD, SM-A310M, SM-A310MD, SM-A310Y)
    - Galaxy A5 2016 (SM-A5100, SM-A5108, SM-A510F, SM-A510FD, SM-A510M, SM-A510MD, SM-A510Y, SM-A510YD, SM-A510S, SM-A510K, SM-A510L)
    - Galaxy A7 2016 (SM-A7100, SM-A7108, SM-A710F, SM-A710FD, SM-A710M, SM-A710MD, SM-A710S, SM-A710K, SM-A710L, SM-A710Y)
    - Galaxy J7 2016 (SM-J7108, SM-J710F, SM-J710FD, SM-J710FN, SM-J710GN, SM-J710K, SM-J710MN)
    - Galaxy J2 (SM-J200F, SM-J200BT, SM-J200G, SM-J200GU, SM-J200M, SM-J200Y)
    - Galaxy ON5 (SM-G5500, SM-G550F, SM-G550FY)
    - Galaxy J1 2016 (SM-J120F, SM-J120G, SM-J120M, SM-J120FN, SM-J120ZN, SM-J120W)
    [INDENT]🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software).
    Download Octoplus / Octopus Box Samsung Software v.2.4.5
  8. #7
    Jan 2007
    Octoplus / Octopus Box Samsung v.2.4.6 - new Tizen phones added, P2P support.
    Octoplus / Octopus Box Samsung Software v.2.4.6 is out!
    We have added world's first support for new Tizen phones - SM-Z200F and SM-Z200Y!
    Also added support for SM-G570F/M/Y, SM-G610M, SM-J106B/M;
    improved Read Codes and Read Cert operations for many Exynos-based devices with latest Security level (now you can perform these operations without root also);
    made some improvements and fixes.
    Added BitTorrent support area access!
    Octoplus / Octopus Box Samsung Software v.2.4.6 Release Notes:
    - SM-Z200F - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Read/Write Cert, Read/Write Security, Write Firmware
    - SM-Z200Y - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Read/Write Cert, Read/Write Security, Write Firmware
    - SM-G570F - added Direct Unlock, Reset FRP, Read Cert, Read/Write Security, Read/Write EFS, Read Cert, Write Firmware, Read PIT
    - SM-G570M - added Direct Unlock, Reset FRP, Read Cert, Read/Write Security, Read/Write EFS, Read Cert, Write Firmware, Read PIT
    - SM-G570Y - added Direct Unlock, Reset FRP, Read Cert, Read/Write Security, Read/Write EFS, Read Cert, Write Firmware, Read PIT
    - SM-G610M - added Direct Unlock, Read Codes, Fast Read Codes, Read Cert (without root), Read/Write Security, Read/Write EFS, Write Firmware, Read PIT
    - SM-G550T * - added Direct Unlock, Read/Write Cert, Read/Write security, Read/Write EFS, Reset FRP/Reactivation, Write Firmware, Read PIT
    - SM-G550T1 * - added Direct Unlock, Read/Write Cert, Read/Write security, Read/Write EFS, Reset FRP/Reactivation, Write Firmware, Read PIT
    - SM-G550T2 * - added Direct Unlock, Read/Write Cert, Read/Write security, Read/Write EFS, Reset FRP/Reactivation, Write Firmware, Read PIT
    - SM-S550TL * - added Direct Unlock, Read/Write Cert, Read/Write security, Read/Write EFS, Reset FRP/Reactivation, Write Firmware, Read PIT
    - SM-J106B - added Direct Unlock, Read Codes, Reset FRP/Reactivation, Reset Screen Lock, Fix Multicore Checksum, Repair IMEI A/B, Read/Write Security, Read/Write EFS, Read/Write Cert, Repair Network
    - SM-J106M - added Direct Unlock, Read Codes, Reset FRP/Reactivation, Reset Screen Lock, Fix Multicore Checksum, Repair IMEI A/B, Read/Write Security, Read/Write EFS, Read/Write Cert, Repair Network
    * Support for SM-G550T, SM-G550T1, SM-G550T2, SM-S550TL is in TEST MODE! Please write us your feedback.
    🐙 Improved Read Codes and Read Cert operations for next phones with latest security level (now you can perform these operations without root):
    - Galaxy S7 (SM-G930F, SM-G930FD, SM-G930U, SM-G930S, SM-G930K, SM-G930L, SM-G930W8)
    - Galaxy S7 Edge (SM-G935F, SM-G935FD, SM-G935S, SM-G935K, SM-G935L, SM-G935W8)
    - Galaxy Note 5 (SM-N920A, SM-N920I, SM-N920F, SM-N920G, SM-N920I, SM-N920K, SM-N920L,S M-N920S, SM-N920C, SM-N920CD,S M-N920W8)
    - Galaxy NOTE 7 (SM-N930F, SM-N930FD, SM-N930S, SM-N930K, SM-N930L)
    - Galaxy A5 2016 (SM-A510F, SM-A510FD, SM-A510M, SM-A510MD, SM-A510Y, SM-A510YD, SM-A510S, SM-A510K, SM-A510L)
    - Galaxy A7 2016 (SM-A710F, SM-A710FD, SM-A710M, SM-A710MD, SM-A710S, SM-A710K, SM-A710L, SM-A710Y)
    - Galaxy J1 2016 (SM-J120A, SM-J120AZ, SM-J120F, SM-J120G, SM-J120M, SM-J120FN, SM-J120P, SM-J120ZN, SM-J120W)
    - Galaxy J3 2016 (SM-J320A, SM-J320AZ, SM-J321AZ, SM-J320W8)
    - Galaxy J7 2016 (SM-G610F, SM-G610FD, SM-G610FZ, SM-G610L, SM-G610K, SM-G610S, SM-G610Y)
    - Galaxy J7 2016 (SM-J710F, SM-J710FD, SM-J710FN, SM-J710FZ, SM-J710GN, SM-J710K, SM-J710MN)
    - Galaxy ON5 (SM-G5500, SM-G550F, SM-G550FY, SM-G389F)
    - Galaxy TAB A (SM-T585, SM-P585M, SM-P585N, SM-P585Y)
    - Galaxy TAB E (SM-T375S, SM-T375L)
    🐙 Added BitTorrent support area access
    As you may know, many users in particular countries (such as India, Pakistan, Cuba, and perhaps some others) encounter low download speed from the Support Area.
    This can be caused by various different reasons (closed ports by ISP, low Internet channel bandwidth, interrupts, unstable connection, etc.).
    Therefore, besides the main Support Area, we have created a P2P Support Area!
    To enter the P2P Support Area and download necessary torrent files, just click "Go to torrent support" button at "Support & Options" tab in the software.
    To download files, you can use any BitTorrent client convenient for you. Count of downloaded torrent files is unlimited.
    🐙 Fixed «unknown baseband» issue after Unlock and Write Cert operations for SM-G610x and SM-G928x
    🐙 GT-P5100 fixed "Repair Network" for devices with Android 4.1.x firmware
    Download Octoplus / Octopus Box Samsung Software v.2.4.6
  9. #8
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.5.0 is out!
    We have added support for SM-A810F, SM-A810FD, SM-A810S and SM-A810YZ!
    Octoplus / Octopus Box Samsung Software v.2.5.0 Release Notes:
    - SM-A810F - added Direct Unlock, Read Cert, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, DRK Fix, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A810FD - added Direct Unlock, Read Cert, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, DRK Fix, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A810S - added Direct Unlock, Read Cert, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, DRK Fix, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A810YZ - added Direct Unlock, Read Cert, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, DRK Fix, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-N9208 - improved Write Cert operation
    • Octopus/Octoplus card firmware has been updated to 2.5 version!
      To run Octoplus/Octopus Box Samsung Software version 2.5.0 and future versions, it is necessary to update card firmware.
      Also note, that after updating card firmware to v.2.5, it won’t be possible to run older Software versions.
    Octoplus/Octopus Shell Software v1.1.9 is out!
    Octoplus/Octopus Shell Software v1.1.9 Release Notes:
    1. Added smart-card latest firmware compatibility
    2. Minor fixes
    Download Octoplus / Octopus Box Samsung Software v.2.5.0
    Download Octoplus/Octopus Shell Software v1.1.9
    Find out more at: www.octoplusbox.com
  10. #9
    Jan 2007
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.5.2 is out! 🐙
    Octoplus / Octopus Box Samsung Software v.2.5.2 Release Notes:
    🐙 On the numerous requests, IMEI modify functions were disabled for all Indian users, to meet local norms of legislation
    🐙 On the numerous requests, Write Cert functions were disabled for all Indian users, to meet local norms of legislation
    For more info regarding modifying IMEI in India and it's consequences - please contact your local seller.
    Download Octoplus / Octopus Box Samsung Software v.2.5.2
    Find out more at: Octoplus Box - flashing, software repair and unlocking of LG, Samsung, Sony Ericsson and other devices
  1. Octoplus/Octopus Box LG new update!
    By ThanhHaMobile™ in forum Octopus/Octoplus Box
    Trả lời: 185
    Bài viết cuối: 17-11-2023, 19:29
  2. Octoplus/Octopus Suite new update!
    Trả lời: 52
    Bài viết cuối: 11-10-2018, 23:44
  3. Octoplus/Octopus Box Samsung v1.3.5 - world's fist support for Samsung SGH-I257!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 28-09-2013, 10:18
  4. Octoplus/Octopus Box Samsung v1.3.4 - Now supports more than 700 Samsung phones!
    Bài viết cuối: 21-09-2013, 09:57
  5. Octoplus/Octopus Shell Software update!
    Bài viết cuối: 02-07-2013, 16:58
