Trang 15 của 20 Đầu tiênĐầu tiên ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 CuốiCuối
Kết quả 141 tới 150 của 195
  1. #141
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.6.5 is out!
    Octoplus / Octopus Box Samsung Software v.2.6.5 Release Notes:
    Added support for the following models:
    - SM-J250F - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J250G - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J250M - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    Added Reset FRP via ADB (combination method) for the following devices:
    - J530F, J530FM, J530G, J530GM, J530K, J530L, J530Y, J530YM
    - J730F, J730FM, J730G, J730GM, J730K
    - N9500, N9508, N950F, N950FD, N950N, N950U, N950U1, N950W
    - G9500, G9508, G950D, G950F, G950FD, G950J, G950N, G950U, G950U1, G950V, G950W
    Note: before you write any combination firmware, please read this topic
    New combination firmwares were uploaded into the Support Area.
    Some adjustments and improvements were made.
    All supported operations described in details in the manual ("Cable & Manual" button in the software).
    This software version is adapted to new, improved back-end server architecture. To ensure effective operation of on-line services (Samsung Factory Unlock, Samsung TMB Unlock, Read Codes, Samsung Factory Reset FRP/Reactivation), please always use the latest Software version.
    Download Octoplus / Octopus Box Samsung Software v.2.6.4
    [INDENT]
  2. #142
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.6.7 is out!
    Added support for new security (latest firmwares and Security patch levels) for wide range of Exynos CPUs-based devices.
    Released Direct Unlock, Read Codes, Read/Write Cert, Repair Network operations for the latest firmwares (firmwares released on January, February and March 2018 are supported!) for a wide range of Exynos CPU-based devices!
    Octoplus / Octopus Box Samsung Software v.2.6.7 Release Notes:
    🐙 Released Direct Unlock, Read Codes (method which requires root), Read/Write Cert, Repair Network operations for the latest firmware versions/ Security patch levels for the following devices:
    - SM-A310F, SM-A310FD, SM-A310M, SM-A310MD, SM-A310N0, SM-A310Y
    - SM-A510F, SM-A510FD, SM-A510K, SM-A510L, SM-A510M, SM-A510MD, SM-A510S, SM-A510Y, SM-A510YD
    - SM-A710F, SM-A710FD, SM-A710K, SM-A710L, SM-A710M, SM-A710MD, SM-A710S, SM-A710Y
    - SM-J710F, SM-J710FD, SM-J710FN, SM-J710FQ, SM-J710FZ, SM-J710GN, SM-J710K, SM-J710MN
    - SM-G610F, SM-G610FD, SM-G610FZ, SM-G610K, SM-G610L, SM-G610M, SM-G610S, SM-G610Y
    - SM-G930F, SM-G930FD, SM-G930K, SM-G930L, SM-G930S, SM-G930W8
    - SM-G935F, SM-G935FD, SM-G935K, SM-G935L, SM-G935S, SM-G935W8
    - SM-T580
    - SM-T585, SM-T585C
    - SM-P585M, SM-P585N, SM-P585Y
    🐙 Released Direct Unlock, Read/Write Cert, Repair Network operations for the latest firmware versions/Security patch levels for the following devices:
    - SM-A320F, SM-A320FL, SM-A320Y
    - SM-J530F, SM-J530FM, SM-J530G, SM-J530GM, SM-J530K, SM-J530L, SM-J530Y, SM-J530YM
    - SM-J730F, SM-J730FM, SM-J730G, SM-J730GM, SM-J730K
    - SM-J701F, SM-J701FD, SM-J701M, SM-J701MT
    🐙 Added Set SIM Count operation for the following devices:
    🐙 Improved “Unlock” operation (fast factory method) for TMB SM-G935T.
    🐙 Some adjustments and improvements were made.
    🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software).
    Download Octoplus / Octopus Box Samsung Software v.2.6.7
    [INDENT][INDENT]
  3. #143
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.6.8 is out!
    Added unlock via server for Galaxy S9/S9+ TMB/MPCS devices!
    Added world's first Unlock (via server) for Samsung TMB/MPCS (with “Device Unlock App") Galaxy S9 and S9+ devices.
    Added Unlock support (via server) for Android 8.0 firmwares for TMB/MPCS S8/S8+/Note 8 devices.
    Added support of "Read Codes” (via server) for Android 8.0 firmwares for Qualcomm CPUs-based S8/S8+/Note 8 series of devices.
    Added direct Unlock for SM-J330F, SM-J330FD, SM-J330FN, SM-J330G (damaged KNOX and all firmwares/Security patch levels are supported).
    Octoplus / Octopus Box Samsung Software v.2.6.8 Release Notes:
    🐙 Added support for the following models:
    - SM-G960U TMB - added world's first Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    - SM-G960U1 TMB - added world's first Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    - SM-G965U TMB - added world's first Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    - SM-G965U1 TMB - added world's first Unlock via server (without erasing/wiping data, no root needed, fast factory algo)
    - SM-J330F - added direct Unlock (damaged KNOX and all firmware versions/Security patch levels are supported)
    - SM-J330FD - added direct Unlock (damaged KNOX and all firmware versions/Security patch levels are supported)
    - SM-J330FN - added direct Unlock (damaged KNOX and all firmware versions/Security patch levels are supported)
    - SM-J330G - added direct Unlock (damaged KNOX and all firmware versions/Security patch levels are supported)
    🐙 Improved "TMB Unlock via server" operation (added support for Android 8.0 firmwares and latest Security patch levels) for the following devices:
    - SM-G950U, SM-G950U1
    - SM-G955U, SM-G955U1
    - SM-N950U, SM-N950U1
    🐙 Improved “Read Codes” (via server) operation (added support for Android 8.0 firmwares and latest Security patch levels) for the following devices:
    - SM-G9500, SM-G9508, SM-G950W, SM-G950U, SM-G950U1
    - SM-G9550, SM-G955W, SM-G955U, SM-G955U1
    - SM-N9500, SM-N9508, SM-N950U, SM-N950U1, SM-N950W
    🐙 Improved “Repair Network” for SM-J710x series (thanks to Mr. sebaelpotro).
    Download Octoplus / Octopus Box Samsung Software v.2.6.8
    [INDENT][INDENT]
  4. #144
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.0 is out! Added Read Codes via server for Galaxy S9/S9+ based on Exynos CPUs and more!
    Added “Read Codes” (via server) for Samsung Galaxy S9, S9+, A6 2018, J6 2018 series based on Exynos CPUs. This operation costs 100 credits.
    Added new additional “Read Codes” (via server) method for latest Exynos CPUs-based devices: S8/S8+, Note 8, A8/A8+ 2018, A3/A5/A7 2017, J7 2017/Nxt/Prime series. This operation costs 50 credits.
    Added new additional “Read Codes” (via server) method for an old Exynos CPUs-based devices: S7/S7 Edge, Note 7/FE, A3/A5/A7 2017, On 7, J7 2016/Prime/Prime2, Tab A 2016 series. This operation costs 20 credits.
    Octoplus / Octopus Box Samsung Software v.2.7.0 Release Notes:
    Note. For the following models a Read Codes operation costs 100 credits.
    - SM-G960F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G960N - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G965F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G965N - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A600F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A600FN - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A600G - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A600GN - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-A600N - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J336AZ - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J337A - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J337AZ - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J400F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J400G - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J400M - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600FN - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600G - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600GF - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600GT - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600L - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J600N - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SSM-J737A - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    Note. For the following models a Read Codes operation costs 20 credits.
    - SM-G611F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G611K - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G611L - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G611M - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G611S - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    🐙 Added new additional Read Codes (via server) method for next Exynos CPU-based devices (all firmwares and KNOX are supported, no root required):
    Note. For the following models a Read Codes operation costs 50 credits.
    - SM-A520F, SM-A520K, SM-A520L, SM-A520S, SM-A520W
    - SM-A530F, SM-A530N, SM-A530W
    - SM-A720F
    - SM-A730F, SM-A730N
    - SM-G950F, SM-G950FD, SM-G950N, SM-G955F, SM-G955FD, SM-G955N
    - SM-N950F, SM-N950FD, SM-N950N
    🐙 Added new additional Read Codes (via server) method for next old Exynos CPU-based devices (all firmwares and KNOX are supported, no root required):
    - SM-A310F, SM-A310FD, SM-A310M, SM-A310MD, SM-A310Y, SM-A310N0
    - SM-A510F, SM-A510FD, SM-A510M, SM-A510MD, SM-A510Y, SM-A510YD, SM-A510S, SM-A510K, SM-A510L
    - SM-A710F, SM-A710FD, SM-A710M, SM-A710MD, SM-A710S, SM-A710K, SM-A710L, SM-A710Y
    - SM-G930F, SM-G930FD, SM-G930S, SM-G930K, SM-G930L, SM-G930W8
    - SM-G935F, SM-G935FD, SM-G935S, SM-G935K, SM-G935L, SM-G935W8
    - SM-J710F, SM-J710FQ, SM-J710FZ, SM-J710FD, SM-J710FN, SM-J710GN, SM-J710K, SM-J710MN
    - SM-N930F, SM-N930FD, SM-N930S, SM-N930K, SM-N930
    Note: the "Read Codes" (via server) operation for all the above mentioned devices works for most available devices` firmwares (modems). If your device has an unsupported modem, just write another available firmware or properly supported modem. Or wait a few hours and try to repeat the operation again - support for unsupported modem firmware will be added to a server automatically during a few hours.
    🐙 Added new additional “Read Codes” method for SM-G950x and SM-G955x. From now two “Read Codes” methods are supported – “Read Codes (Via DIAG PORT)” and “Read Codes (Via ADB interface)”. If “Read Codes” operation was unsuccessful by one method, try to perform another “Read Codes” operation using the other method.
    Download Octoplus / Octopus Box Samsung Software v.2.7.0
    [INDENT]
  5. #145
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.1 is out! Added Read Codes via server for Galaxy Note 9 series based on Exynos CPUs and more!
    Added “Read Codes” (via server) for Samsung Galaxy Note 9, J7 Duo and Galaxy J7 2017 series, based on Exynos CPUs.
    Added “Read Codes” (via server) for Samsung J5 Prime series.
    Improved "Read Codes" via server operation for Galaxy J3 / Amp Prime 3 2018, J7 2018 and Sol 2 series.
    Octoplus / Octopus Box Samsung Software v.2.7.1 Release Notes:
    �� Added support for the following models:
    - SM-N960F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-N960FD - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-N960N - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-N960W - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J720F - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J720M - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J727A - added Read Codes via server, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-J727AZ - added Read Codes via server, Reset FRP (via ADB), Read/Write Security, Read/Write EFS, Write Firmware, Read PIT, Reboot in Download/Recovery mode
    - SM-G570F - added Read Codes via server (latest firmware supported)
    - SM-G570FD - added Read Codes via server (latest firmware supported)
    - SM-G570M - added Read Codes via server (latest firmware supported)
    - SM-G570MD - added Read Codes via server (latest firmware supported)
    - SM-G570Y - added Read Codes via server (latest firmware supported)
    �� Improved "Read Codes" via server operation (added support for 16 digits codes) for the following devices:
    - SM-J336AZ
    - SM-J337A, SM-J337AZ
    - SM-J737A
    �� Improved "Read Codes" via server operation (added support for U2/S2 firmwares) for the following S9 and S9+ devices:
    - SM-G960F, SM-G960N
    - SM-G965F, SM-G965N
    * For more detailed information about prices, please check Octoplus Credits Consumption.
    �� Many new Samsung Combination firmwares were uploaded into the Support Area.
    �� All supported operations described in details in the manual ("Cable & Manual" button in the software).
    Download Octoplus / Octopus Box Samsung Software v.2.7.1
  6. #146
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.2 is out! Added Read Codes (via server) for Galaxy A6+ 2018, A8/A9 Star and more!
    Added Read Codes (via server) for Samsung Galaxy A6+ 2018, S Lite, A8 Star, A9 Star and On8 2018 series, based on Qualcomm CPUs.
    Added Read Codes (via server) for Samsung Galaxy Galaxy J2 Core 2018 series, based on Exynos CPUs.
    Improved Read Codes operation (added support for latest firmwares) for Galaxy J2 2018, S7, S7 Edge, S7 Active, S8 Active series, based on Qualcomm CPUs.
    Octoplus / Octopus Box Samsung Software v.2.7.2 Release Notes:
    - SM-A6050 - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-A605F - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-A605FN - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-A605G - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-A605GN - added Read Codes (via server), Read/Write NVM, Read/Write QCN, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G8750 - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G8850 - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G8858 - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G885F - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G885S - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-G885Y - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J810F - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J810G - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J810M - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J810Y - added Read Codes (via server), Read/Write NVM, Read/Write EFS, Read/Write QCN, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J260F - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J260G - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J260M - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J260Y - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Download/Recovery mode
    - SM-J327P (Sprint) - added Unlock
    - SM-J727PP (Sprint) - added Unlock
    🐙 Improved Read Codes operation (updated new MSM Crypto algorithm) for the following devices:
    - SM-G9500, SM-G9508, SM-G950U, SM-G950U1, SM-G950W
    - SM-G9550, SM-G9558, SM-G955U, SM-G955U1, SM-G955W
    - SM-J250F, SM-J250G, SM-J250M, SM-J250N, SM-J250Y
    - SM-G930A, SM-G930AZ
    - SM-G935A, SM-G935AZ
    - SM-G891A
    - SM-G892A
    🐙 Many new Samsung Combination firmwares were uploaded into the Support Area.
    Note: please always use the latest Software version.
    Also note: if you have any problem with Read Codes operation, please contact us on Skype, you can find our contact info in our profile.
    Download Octoplus / Octopus Box Samsung Software v.2.7.2
    [INDENT]
  7. #147
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.3 is out! Added Note 9 TMB Unlock and more!
    Added Unlock (via server) for Samsung Note 9 TMB.
    Added Read Codes (via server) for Samsung Galaxy J3 2017/Galaxy J7 Prime 2/Wide 2 series, based on Exynos CPUs.
    Improved TMB Unlock (via server) operation (for latest firmware versions: from now on no need to write modem from combination firmware) for TMB Note 8, S8, S9 and S9+ series.
    Improved Read Codes (via server) operation (added support for latest firmwares) for Note 8, S8 and S8+ series, based on Qualcomm CPUs.
    Octoplus / Octopus Box Samsung Software v.2.7.3 Release Notes:
    - SM-N960U (TMB) - added Unlock (via server), Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-N960U1 (TMB) - added Unlock (via server), Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-G611FF - added Read Codes (via server), Read/Write EFS, Read/Write Security, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J727S - added Read Codes (via server), Reset FRP (via ADB), Read/Write EFS, Read/Write Security, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J330GM - added Unlock (via server, any KNOX), Read Codes (via server), Reset FRP (via ADB), Read Cert, Read/Write EFS, Read/Write Security, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J330L - added Unlock (via server, any KNOX), Read Codes (via server), Reset FRP (via ADB), Read Cert, Read/Write EFS, Read/Write Security, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J330N - added Unlock (via server, any KNOX), Read Codes (via server), Reset FRP (via ADB), Read Cert, Read/Write EFS, Read/Write Security, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    🐙 Improved TMB unlock (via server) operation (for latest firmware versions: from now on no need to write modem from combination firmware) for the following TMB devices:
    - SM-G960U, SM-G960U1
    - SM-G965U, SM-G965U1
    🐙 Improved Read Codes (via server, via UploadMode) operation (added support for BIT5 firmwares) for the following devices:
    Note: Please, always use the latest Software version.
    Also note: If you have any problems with Read Codes operation, please contact us on Skype, you can find our contact info in our profile.
    Download Octoplus / Octopus Box Samsung Software v.2.7.3
    [INDENT]
  8. #148
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.4 is out! Added support for Samsung Galaxy A7/J4+/J6+ 2018 and more!
    Octoplus / Octopus Box Samsung Software v.2.7.4 Release Notes:
    - SM-A750F - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-A750FN - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-A750G - added Read Codes (via server), Read/Write Security, Read/Write EFS, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J415F - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J415FN - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J415G - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J610F - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J610FN - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    - SM-J610G - added Read Codes (via server), Read/Write EFS, Read/Write NVM, Read/Write QCN, Read PIT, Write Firmware, Reboot in Recovery/Download mode
    🐙 Added Read Codes (via server, latest firmware versions/Security patch levels are supported, no root needed) for the following devices:
    - SM-J120A, SM-J120AZ, SM-J120F, SM-J120G, SM-J120M, SM-J120FN, SM-J120ZN, SM-J120W
    - SM-J200F, SM-J200BT, SM-J200G, SM-J200GU, SM-J200M, SM-J200Y
    - SM-J320A, SM-J320AZ, SM-J321AZ, SM-J320W8
    - SM-G389F
    - SM-G5500, SM-G550F, SM-G550FY
    - SM-T375S, SM-T375L
    - SM-T377W, SM-T377T
    🐙 Improved Direct Unlock operation for Sprint SM-J327P and SM-J727P.
    Also note: If you have any problems performing Read Codes operation, please contact us on Skype, you can find our contact info in our profile.
    Download Octoplus / Octopus Box Samsung Software v.2.7.4
    [INDENT]
  9. #149
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.5 is out! Added support for Sprint devices and more!
    Added permanent Unlock (via server) for Sprint Samsung Galaxy S7/S7 Edge/S8/S8+/S9/S9+/Note 8/J3 Emerge/J7 Perx.
    Added Unlock (via server) for TMB Samsung Galaxy J3 and J7 Star.
    Added Read Codes (via server) for Samsung Galaxy A7 2018, J3 2018, J4 Core, J4+, J6+.
    Octoplus / Octopus Box Samsung Software v.2.7.5 Release Notes:
    🐙 Added support for the following Sprint devices:
    - SM-G960U - added permanent Sprint Unlock via server ("Upload" method, only old Security is supported at the moment), Read SPC
    - SM-G960U1 - added permanent Sprint Unlock via server ("Upload" method, only old Security is supported at the moment), Read SPC
    - SM-G965U - added permanent Sprint Unlock via server ("Upload" method, only old Security is supported at the moment), Read SPC
    - SM-G965U1 - added permanent Sprint Unlock via server ("Upload" method, only old Security is supported at the moment), Read SPC
    - SM-G950U - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-G950U1 - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-G955U - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-G955U1 - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-N950U - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-N950U1 - added permanent Sprint Unlock via Server ("DIAG" and "Upload" methods), Read SPC
    - SM-G930P - added permanent Sprint Unlock via server ("Upload" method), Read SPC
    - SM-G935P - added permanent Sprint Unlock via server ("Upload" method), Read SPC
    - SM-J327P - added permanent Sprint Unlock via server ("Upload" method), Read SPC
    - SM-J727P - added permanent Sprint Unlock via server ("Upload" method), Read SPC
    Note: before performing "Unlock" operation for mentioned above Sprint devices, it is necessary to insert non-Sprint SIM card ("Invalid SIM" should be on phone's screen), this is important!
    🐙 Added support for the following TMB devices:
    - SM-J337T - added Unlock via server, Reset FRP (ADB), Read/Write Security, Read/Write EFS, Write Firmware, Read PIT
    - SM-J737T - added Unlock via server, Reset FRP (ADB), Read/Write Security, Read/Write EFS, Write Firmware, Read PIT
    - SM-J727T - added Unlock support for latest firmware versions
    🐙 Added support for the following devices:
    - SM-A750GN - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT
    - SM-J337W - added Read Codes via server, Read/Write Security, Read/Write EFS, Write Firmware, Read PIT
    - SM-J410F - added Read Codes via server, Read/Write NVM, Read/Write EFS, Read/Write QCN, Write Firmware, Read PIT
    - SM-J410G - added Read Codes via server, Read/Write NVM, Read/Write EFS, Read/Write QCN, Write Firmware, Read PIT
    - SM-J415GN - added Read Codes via server, Read/Write NVM, Read/Write EFS, Read/Write QCN, Write Firmware, Read PIT
    Download Octoplus / Octopus Box Samsung Software v.2.7.5
    [INDENT][INDENT][INDENT][INDENT][INDENT]
  10. #150
    Jan 2007
    Octoplus / Octopus Box Samsung Software v.2.7.6 is out! Improved Unlock operation for Sprint S9/S9+ devices and more!
    Improved "Unlock" operation for Sprint Samsung Galaxy S9 and S9+.
    Improved "Unlock" operation for TMB Galaxy Grand Prime and Galaxy Core Prime devices.
    Added Unlock for Sprint Galaxy S8 Active.
    Octoplus / Octopus Box Samsung Software v.2.7.6 Release Notes:
    🐙 Improved "Unlock" operation (added support for new security type) for the following Sprint Samsung Galaxy S9 and S9+ devices:
    - SM-G960U
    - SM-G960U1
    - SM-G965U
    - SM-G965U1
    🐙 Improved "Unlock" operation for TMB Galaxy Grand Prime (SM-G530T, SM-G530T1) and Galaxy Core Prime (SM-G360T, SM-G360T1) devices.
    🐙 Added Unlock for Sprint Galaxy S8 Active SM-G892U.
    To unlock Sprint Galaxy Note 8/S8/S8+/S9/S9+ it is necessary to perform the following steps:
    1. Download and write into the phone proper binary Combination Modem firmware from the Support Area ("SAMSUNG/COMBINATION" folder) or write Modem part from proper Combination firmware.
    2. Insert non-Sprint SIM card ("Invalid SIM" should be on phone's screen), this is important!
    3. Perform the "Unlock" operation.
    To unlock TMB SM-G530T, SM-G530T1, SM-G360T, SM-G360T1, perform the following steps:
    1. Perform "Factory data reset".
    2. Root the device.
    Note: please always use the latest Software version! Not recent Software version may not support the latest device security type and "Read Codes" or "Unlock" operation may be unsuccessful!
    Also note: before performing "Read Codes" operation via server it is highly recommended to perform Hard/Factory reset operation! In the opposite case, codes may be not read (not found)!
    Download Octoplus / Octopus Box Samsung Software v.2.7.6
    [INDENT]
  1. Octoplus/Octopus Box LG new update!
    By ThanhHaMobile™ in forum Octopus/Octoplus Box
    Trả lời: 185
    Bài viết cuối: 17-11-2023, 19:29
  2. Octoplus/Octopus Suite new update!
    Trả lời: 52
    Bài viết cuối: 11-10-2018, 23:44
  3. Octoplus/Octopus Box Samsung v1.3.5 - world's fist support for Samsung SGH-I257!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 28-09-2013, 10:18
  4. Octoplus/Octopus Box Samsung v1.3.4 - Now supports more than 700 Samsung phones!
    Bài viết cuối: 21-09-2013, 09:57
  5. Octoplus/Octopus Shell Software update!
    Bài viết cuối: 02-07-2013, 16:58
