Pegasus Box v1.1.3 is here!
Pegasus Box v1.1.3 is out! We have added support of various features for a wide range of Samsung mobile phones.
Pegasus Box v1.1.3 Release Notes:
Added support for the following Samsung models:
- C414 – Read Unlock Codes – World's First!
- C414M – Read Unlock Codes – World's First!
- C414R – Read Unlock Codes – World's First!
- C414V – Read Unlock Codes – World's First!
- C414W – Read Unlock Codes – World's First!
- C414Y – Read Unlock Codes – World's First!
- T259 – Read Unlock Codes.
- C5130s – Read Unlock Codes.
- S5260P – Read Unlock Codes/Direct Unlock.
- E1080W – Direct Unlock/Read Unlock Codes/Read User Code/IMEI Rebuild/Flash Read/Flash Write.
- E1086i – Direct Unlock/Read Unlock Codes/Read User Code/IMEI Rebuild/Flash Read/Flash Write.
- E2120L – Direct Unlock/Read Unlock Codes/Read User Code/IMEI Rebuild/Flash Read/Flash Write.
- Minor bugs fixed.
- Added "Detailed Manuals" tab with precise unlock procedure description and other guides on Pegasus software.
N.B.: Since there are 2 revisions of S3600i (with and without protected bootrom), we've added support for S3600i without protected bootrom - just select "S3600i REVISION1" from the list.
N.B.: To perform the operations listed above with E1080w and E1086i you have to write patched flash into the phone first. Patched flashes are available at Boot–Loader 2.0 web site. If you only need to unlock phone use "Read Unlock Codes" button on the flash tab of the software (patched flash is not required in this case).
Download Pegasus Box v1.1.3
________________________
WBR,
Pegasus Box Team
