Kết quả 21 tới 30 của 30
    May 2011
    Hà Nội City
    Pegasus Box v1.2.4
    Pegasus Box v1.2.4 is out! Added support for E2600, C3350 and E2652 Samsung mobiles.
    Pegasus Box v1.2.4 Release Notes:
    • E2600 - added Read Unlock Codes, Unlock, Repair IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
    • C3350 - added Read Unlock Codes, Unlock, Repair IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
    • E2652 - added Read Unlock Codes, Unlock, Repair Primary and Secondary IMEI, Original Firmware Converter, Write Firmware, Read MCU Flash.
    This release is dedicated in memory of all who struggled in WWII and sacrificed their lives in fight against Nаzism.
    Download Pegasus Box v1.2.4
    _______________________
    WBR,
    Pegasus Box Team
  2. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TUYHOAGSM™ (09-05-2012)
    May 2011
    Hà Nội City
    Pegasus Box v1.2.5 - public discussion thread
    Pegasus Box v1.2.5 is out! Added support for a wide range of Samsung mobiles.
    Pegasus Box v1.2.5 Release Notes:
    • S6500 - added Read Unlock Code, Direct Unlock, Repair IMEI, Factory Reset.
    • S6500D - added Read Unlock Code, Direct Unlock, Repair IMEI, Factory Reset.
    • S6500T - added Read Unlock Code, Direct Unlock, Repair IMEI, Factory Reset.
    • SC03B - added Direct Unlock.
    • I957 - added Direct Unlock.
    • I957M - added Direct Unlock.
    • I757 - added Direct Unlock.
    • I757M - added Direct Unlock.
    • I847 - added Direct Unlock.
    • I9210 - added Direct Unlock.
    • Added "Show Log File" button to the main software. Now you can easily open and view your Pegasus operation log file.
    Download Pegasus Box v1.2.5
    WBR,
    Pegasus Box Team
    May 2011
    Hà Nội City
    Pegasus Box v1.2.6 released! New Samsung sets supported!
    Pegasus Box v1.2.6 is out! Added support for a wide range of Samsung mobiles.
    Pegasus Box v1.2.6 Release Notes:
    • S5220 - added Read Unlock Codes, Unlock, Read Phone Code, Repair IMEI, Factory Reset, Write Firmware, Original Firmware Converter.
    • S5222 - added Read Unlock Codes, Unlock, Read Phone Code, Repair Primary IMEI, Repair Secondary IMEI, Write Firmware, Original Firmware Converter.
    • S7500 - added Unlock, Repair IMEI, Factory Reset.
    • S7500L - added Unlock, Repair IMEI, Factory Reset.
    • S7508 - added Unlock, Repair IMEI, Factory Reset.
    • S6500/S6500D - Unlock Bug fixed.
    Download Pegasus Box v1.2.6
    WBR,
    Pegasus Box Team
    Nov 2010
    Pegasus Box v1.2.7 - i9300 and more! Pegasus Box v1.2.7 is out!
    Pegasus Box v1.2.7 Release Notes:
    • I9300 – added Direct Unlock (manual root is required).
    • I9300M – added Direct Unlock (manual root is required).
    • S3353 – added Read Unlock Codes, Direct Unlock, Repair IMEI, Write Flash.
    • S5229 – added Read Unlock Codes, Direct Unlock, Repair IMEI, Write Flash, Original Firmware Converter.
    • E1180 – added Read Unlock Codes, Direct Unlock, Repair IMEI, Read Flash/Write Flash.
    Download Pegasus Box v1.2.7
    WBR,
    Pegasus Box Team
    __________________
    Mặc định PEGASUS BOX 1.2.9 - really massive update!
    PEGASUS BOX 1.2.9 IS OUT!
    As you remember Pegasus Team was the first to released "no patch/flash mode" solution for Swift phones. So here is the next revolutionary update for this platform.
    PEGASUS BOX 1.2.9 RELEASE NOTES:
    • E1200 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1200M - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1200T - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1205L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1202 - world's first super fast Unlock Code Reading/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1085L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1086il - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080f - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1080w - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1050 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1150 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1150i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1153 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1155L - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170i - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1170t - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1172 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1180 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1190 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • E1195 - world's first super fast Unlock Code Reading/Unlock/Repair IMEI/Factory Reset/Read/Write Full Flash/Firmware/EEPROM (no patch is required)
    • C3330 - Read Unlock Codes/Unlock/Repair IMEI/Write Firmware/Convert Original Firmware
    • C3312 - Read Unlock Codes/Unlock/Primary IMEI Repair/Secondary IMEI Repair/Write Firmware/Convert Original Firmware
    • S5839I - Read Unlock Codes/Unlock/Repair IMEI
    • S5270K - Read Unlock Codes
    • I827 - Direct Unlock/Repair IMEI
    Download Pegasus Box v1.2.9
    Mặc định Pegasus 1.3.0 released! New phone models added for Direct Unlock Solution!
    Dear Users,
    Pegasus Box v1.3.0 is out!Added Direct Unlock feature for Samsung I9305, I9305T, N7105, I317, i317m, T889 mobile devices.
    With this release we are glad to introduce to you such new features and improvements:
    • I9305 - added direct unlock (thanks to mr Duzz)
    • I9305T - added direct unlock
    • N7105 - added direct unlock
    • I317 - added direct unlock
    • i317m - added direct unlock (thanks to mr darltech)
    • T889 - added direct unlock
    • minor bug fixes
    Download Pegasus Box v1.3.0
    Best Regards
    GSMServer team
  8. #7
    Mặc định Pegasus 1.3.1 - added I8160, I8160P, I9070 and I9070P
    Dear Users,
    Pegasus Box v1.3.1 is out! Added Unlock/Repair IMEI features for Samsung I8160, I8160P, I9070 and I9070P mobile devices.
    • I8160 - Unlock/Repair IMEI added (manual root required)
    • I8160P - Unlock/Repair IMEI added (manual root required)
    • I9070 - Unlock/Repair IMEI added (manual root required)
    • I9070P - Unlock/Repair IMEI added (manual root required)
    • minor bug fixes
    Download Pegasus Box v1.3.1
    Best Regards
    GSMServer team
  9. #8
    Thành viên chính thức hungthinhmobi's Avatar
    Mar 2012
    Pegasus Box v1.3.2 - Christmas comes early!
    Dear Users,
    Pegasus Box v1.3.2 is out! Added Read Unlock Codes feature for a wide range of Samsung mobiles.
    Pegasus Box v1.3.2 Release Notes:
    • I317 - added Read Unlock Codes.
    • I317M - added Read Unlock Codes.
    • T889 - added Read Unlock Codes.
    • I9305 - added Read Unlock Codes.
    • I9305T - added Read Unlock Codes.
    • N7105 - added Read Unlock Codes.
    • N7105T - added Read Unlock Codes.
    • T999 - added Read Unlock Codes.
    • T999V - added Read Unlock Codes.
    • SC03D - added Read Unlock Codes.
    • SC05D - added Read Unlock Codes.
    • SC06D - added Read Unlock Codes.
    • I747 - added Read Unlock Codes.
    • I747M - added Read Unlock Codes.
    • I957 - added Read Unlock Codes.
    • T989 - added Read Unlock Codes.
    • T989D - added Read Unlock Codes.
    • I577 - added Read Unlock Codes.
    • I9210 - added Read Unlock Codes.
    • I847 - added Read Unlock Codes.
    • I757 - added Read Unlock Codes.
    • I757M - added Read Unlock Codes.
    • I727 - added Read Unlock Codes.
    • I727R - added Read Unlock Codes.
    • I717 - added Read Unlock Codes.
    • I717D - added Read Unlock Codes.
    • I717M - added Read Unlock Codes.
    • I717R - added Read Unlock Codes.
    • minor bug fixes
    Download Pegasus Box v1.3.2
    Best Regards
    GSMServer team
    Unlock-Mở Mạng-Sửa Lỗi Phần Mềm-Nạp TV
    Y!h:hungthinh0939157157
  10. #9
    Jan 2007
    Pegasus Box v1.3.8 - added Galaxy Fame, Pocket Neo and others!
    Added support for a range of Samsung devices.
    Pegasus Box v1.3.8 Release Notes:
    Samsung C3310 - added Read Unlock Codes, Unlock, Repair IMEI, Write Flash.
    Samsung C3310R - added Read Unlock Codes, Unlock, Repair IMEI, Write Flash.
    Samsung S3800M - added Read Unlock Codes, Unlock, Repair IMEI.
    Samsung C3590 - added Read Unlock Codes, Unlock, Repair IMEI.
    Samsung S5310 - added Read Unlock Codes.
    Samsung S5310B - added Read Unlock Codes.
    Samsung S5310E - added Read Unlock Codes.
    Samsung S5310G - added Read Unlock Codes.
    Samsung S5310L - added Read Unlock Codes.
    Samsung S6790 - added Read Unlock Codes.
    Samsung S6790N - added Read Unlock Codes.
    Samsung S6812 - added Read Unlock Codes.
    Samsung S6812B - added Read Unlock Codes.
    Download Pegasus Box v1.3.8
  11. #10
    Jan 2007
    Pegasus Box v1.3.9 - unlock for Samsung I9060, G350 and others!
    Pegasus Box v1.3.9 Release Notes:
    Samsung I9060 - added Read Unlock Codes
    Samsung G350 - added Read Unlock Codes
    Samsung S7392L - added Read Unlock Codes
    Samsung S7580 - added Read Unlock Codes
    Samsung S7582 - added Read Unlock Codes
    Samsung S7582L - added Read Unlock Codes
    Samsung S7390E - added Read Unlock Codes
    Samsung S7580L - added Read Unlock Codes
    Samsung I9150 - added Read Unlock Codes
    Samsung S7270L - added Read Unlock Codes
    Samsung S7273T - added Read Unlock Codes
    Download Pegasus Box v1.3.9
  1. Easy-JTAG New Updates Post Here !!
    By Lính Khang in forum Z3X-Team Products
    Trả lời: 69
    Bài viết cuối: 28-04-2017, 23:56
  2. LGETOOL Updates post here
    By GIALAI_GSM in forum LGETOOL
    Trả lời: 119
    Bài viết cuối: 12-12-2015, 12:58
  3. !! Hyper-Box Updates post here !!
    By GIALAI_GSM in forum Các thiết bị khác
    Bài viết cuối: 25-11-2012, 22:24
  4. All Furious Gold News updates post and check here
    By BlachThon in forum FuriouS Team Products
    Bài viết cuối: 23-02-2009, 19:34
  5. All Cruiser software News updates post and check here
    By BlachThon in forum Cruiser Box
    Bài viết cuối: 29-01-2009, 03:16
