Kết quả 1 tới 10 của 12
    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Arrow Cách Nhập Code Cho Những Máy Unlock= Code
    How to Enter Unlock Codes on a Cingular BlackJack
    Step Action
    1. Insert NON Cingular SIM into device
    2. Power on the device
    - Wait approximately 30 seconds until the Sim Lock application appears (the delay may be longer if the user has already attempted an unlock with the wrong code)
    3. Enter the unlock code in the blank field
    4. Press Ok
    - If the unlock code is incorrect, an error dialog will appear. After pressing Ok on this dialog, the user has to re-enter the unlock code after delays (see above in Device Specific Information)
    - If the unlock code is correct, a success dialog will appear.
    5. Press Ok
    - The device is now unlocked and should continue booting
    OR
    1. Insert disallowed simcard (a simcard that the phone does not usaully accept) and enter unlock codes when prompted
    2. NOTE: If you are unable to connect to service provider or unable to make out going calls or recieve messages, this has nothing to do with your phone being locked or not, you need to force the BlackJack to change to GSM mode, this can be done as follows:
    Power on your Phone
    Enter *#1546792*#
    Select Option 3 Network & Call Settings
    Select option 5 Network Mode
    Select GSM
    Without sim alternative i607 / Blackjack
    Power on without sim, you will then get a message saying "SIM Failure" at the top of the screen.
    Click "Done" then press the green button to get into the dial pad. Type in #7465625*638*
    Then it will display "Enter Network Control Key" this is where you enter the 8 digit unlock code. Then click ok
    Your phone is now unlocked
    How to Enter Unlock Codes on Samsung Z105 and Z107:
    • Switch ON your phone with a not accepted SIM card
    • Compose : #7465625*638*YOURCODE# (by "yourcode" I mean the unlock code we gave you)
    How to Enter Unlock Codes on Samsung Z510 and Z320i:
    • Switch ON your phone without SIM Card
    • Compose : **YOURCODE# (by "yourcode" I mean the unlock code we gave you)
    How to Enter Unlock Codes on Samsung 3G, Zxxx & Dxxx, A707 Series:
    • Switch ON your phone without SIM Card.
    • Compose : #7465625*638*YOURCODE# (or *#7465625*638*CODE#) (by "yourcode" I mean the unlock code we gave you)
    How to Enter Unlock Codes on Samsung (all other models):
    • Phone will ask for the "Password"
    • You can now enter the unlock code
    OR (if phone shows "Insert Correct SIM Card")
    • Compose : #0111*YOURCODE# (by "yourcode" I mean the unlock code we gave you)
    How to Enter Unlock Codes on Treo 180, 270, 750:
    • Compose : *#*#CODE# (substitute the word "code" with the unlock code we gave you).
    or
    • Switch ON your phone with a not allowed SIM card.
    • Enter the unlock code.
    • Important Note: On some models the Num Lock is not automatically enabled so make sure it is ON before entering the unlock code.
    How to Enter Unlock Codes on Treo 750: (alternative instructions):
    • Please insert a not allowed SIM card.
    • Place the battery and the cover, windows will boot automatically.
    • Turn on the phone by pressing the front upper-right red button on the keypad.
    • The phone will ask for the unlock code.
    • Pull out the stylus at the back of the phone, tap the keyboard icon at the center-bottom of the screen.
    • Enter the unlock code by tapping your stylus on the screen keyboard. Then tap OK.
    • Your Palm Treo phone should be unlocked by now.
    or
    • Switch ON your phone with allowed SIM card.
    • Go to menu and select "Phone Tool" or "Phone Application"
    • Type on virtual keyboard *#*#CODE# (substitute the word "code" with the unlock code we gave you).
    • Select with PEN "Number" and phone will show that it's unlocked.
    How to Enter Unlock Codes on Treo 650, 680:
    • Remove Treo battery, unplug cable
    • Insert incorrect a not allowed SIM card (one the phone does not accept)
    • Power on your Treo, “Sim not allowed” is displayed, click “ok”
    • Go to the dial pad, and use the stylus to enter code *#*#CODE#. Then press “Dial”. (substitute the word "code" with the unlock code we gave you).
    • Phone will reset and display “sim lock removed”
    Ensure you enter the codes in this manner *#*#CODE# (e.g. *#*#12345678#)
    Troubleshooting:
    Error Message: "The SIM Lock has NOT been removed from this phone"
    Solution 1: Please make sure you are entering the correct code and enter it using this method *#*#CODE# dial
    Solution 2: If the phone says that the SIM lock has not been removed, ensure that the phone radio (wireless mode) is on.
    HP iPaq Unlock Code Entry Instructions
    How to Enter Unlock Codes on HP iPaq series phones (iPaq 6315, 6325, 6300, 6515 , etc)
    Step Action
    1 Insert NON Cingular SIM into device
    2 Power on the device
    - Wait approximately 30 seconds until the SimLock application appears (the delay may be longer if the user has already attempted an unlock with the wrong code)
    3 Enter the unlock code in the blank field
    4 Press Ok
    5 Press Ok
    OR
    1. On the Today screen, tap Start > Settings.
    2. Tap the Phone Band icon.
    3. Tap the Keyboard icon to open the virtual keyboard
    4. Tap Shift and then Ctl key to enable the keys.
    5. Tap the blank area below the band selection box to open the unlock tool.
    6. Tap Shift and then Ctl to disable the keys.
    7. Enter the 8-digit unlock code and tap OK when done.
    8. Wait for the device to validate the unlock code (about five seconds). You will see one of the following screens:
    1) Unlock successful.
    2) Unlock failed due to incorrect code. The user has three attempts to unlock. After three attempts, the device will refuse any more unlocking attempts. Perform a soft reset to reset the counter to perform additional unlocking attempts.
    3) Device is not ready for unlocking. This error message displays when the user tries to unlock when the phone application (not the device) is not in a steady state. It takes 30 seconds after powering on the phone for it to reach a steady state.
    *If you already have an unlock code and sim card but when you input code, it always says " unlock code not accepted, you have tried...." You must update your ROM version . About 5% hp 6315 have this problem.
    This problem can easy be resolved with this ROM update ( ROM v1.00.38 )
    This rom update will remove all T-mobile logos and sofware and your 6315 will become OEM 6315
    dowload here : http://rebootitsmagic.com/ipaq/SP29760_6315.zip
    1. Unzip/Extract it using your unzip program (i.e. WinRAR, WinZip, 7zip, etc...)
    2. Place the h6315 in cradle. connect it to USB and charger
    3. Double click on the hpRUU.exe to run the program
    4. View the Readme and if you wish to proceed Agree to the Terms and Conditions
    5. Click Next
    6. Click Next again to flash the device with the new ROM
    How to Enter Unlock Codes on Sony Ericsson Cell Phones (all models):
    If your phone has a "JOGDIAL" (for example SonyEricsson K700i), then you must press the "down arrow" instead of the "left arrow" for step 3 & 5. By "Down Arrow" I mean directing the Jogdial down!
    • For the unlocking of a locked Sony Ericsson no sim card is required.
    • Turn on the handset. Display will indicate “Insert SIM.”
    • Press the left Arrow (<) button.
    • Press the star (*) button twice.
    • Press the left Arrow (<) button again.
    • You will briefly see one of the following messages listed on devices display: “Personalized with MNC2” or “Personalized with MNC3”.
    • Wait approximately three seconds.
    • The display will indicate “Network” and a picture of a closed lock.
    • Press Select.
    • The display will indicate “Unlock (Net) 5” and “NCK:”
    • Enter the 16 digit NLCK4U code (unlock code we provided you) and press okay.
    • The handset will display “Network unlocked” and the display “Insert SIM” appears.
    • The handset is successfully unlocked.
    How to Unlock LG (most models):
    • Insert not-allowed SIM card
    • Power on the handset- phone will display "phone restricted"
    • Select "Cancel" - phone will display "phone restriction code"
    • Enter the SIM unlock code
    • Select "OK" - the handset is now successfully unlocked
    Unlock Instruction for LG TU720 (SHINE)
    1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
    2. Type *#865625#
    3. the phone will ask you to input the unlock code twice, just input the unlock code
    4.
    Device is now unlocked
    How to Unlock LG KG800 or TG800 Chocolate:
    • With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
    • Go to: Settings>Security>SimLock>Network
    • Select deactivate. Enter the unlock code
    How to Unlock LG C2000:
    • Insert non-Cingular SIM card
    • Power on the handset - phone will display "phone restricted"
    • Enter the SIM Unlock code
    How to Enter Unlock Codes on LG F2250:
    • With allowed sim card in the start menu type: 2945#*3311#.
    • Handset shows saved, then return to startup screen
    • Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
    • Enter your unlock code and OK.
    How to Enter Unlock Codes on LG U8150:
    • Compose: 277634#*#.
    • Go to menu "SIM Lock".
    How to Enter Unlock Codes on LG U8110:
    • With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
    • Select 'Sim Unlock' menu #
    • Enter NCK code then validate
    • Your phone is now unlocked.
    How to Enter Unlock Codes on LG U8210:
    • With a not allowed sim card enter Pin code then validate, type: 277634#*#
    • Shows test menu
    • Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
    • Handset shows 'Enter NCK'
    • Enter code, then hit OK.
    How to Enter Unlock Codes on LG U81xx:
    • To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
    • Enter the code
    In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
    How to Enter Unlock Codes on Cingular AT&T LG CU500:
    • Insert non-Cingular SIM card.
    • Power on the handset. Phone will display "Invalid SmartChip"
    • (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
    • In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
    • Enter the 8 digit SIM unlock code
    • Select "OK". The handset is now successfully unlocked.
    How to Enter Unlock Codes on all other LG cell phones:
    • Switch ON your phone with an allowed SIM card
    • Then compose:
    • 2945#*5101# - (if you have a LG 510w)
    • 1945#*5101# - (if you have a LG 1200 & B1200)
    • 2945#*5221# - (if you have a LG 5200 & 52200)
    • 2945#*5301# - (if you have a LG 5300)
    • 2945#*5401# - (if you have a LG 5400)
    • 2945#*70001# - (if you have a LG 7020)
    • 2945#*7101# - (if you have a LG 7100)
    • 2945#*1201# or 2945#*70001# - (if you have a LG 1100)
    • 2945#*70001# - (if you have a LG7250T)
    • 2945#*2201# - (if you have a LG C2200)
    • 2945#*5301# - (if you have a LG T5100)
    • 2945#*3311# - (if you have a LG C3310)
    • Go to "Menu" and then to "Settings"
    • Then select "Security"
    • To finish select "Network Provider" and select "Deactivate"
    • If your cell phone is not listed, please follow instructions for LG C2000 above
    How to Enter Unlock Codes on all other LG KE970 Shine:
    • Then compose: 2945#*9701#
    • Press CALL.
    • It should you ask you for the code.
    Pantech, Cingular, HTC, HP, 8525, 3125, 2125 & all Windows Smartphones, Windows Pocket PC Phones:
    Power on with incorrect sim, enter unlock code when prompted
    Enter code using onscreen keyboard when unlocking a Pocket PC Phones
    ***Below are Blackberry instructions that work for most network providers. T-Mobile locked cell phones have to be entered differently and are shown at the end ***
    How to Enter Unlock Codes on BlackBerry 8800 and 8800 Pearl:
    • You must have a SIM card in your phone to complete these steps (can be active or inactive)
      Go to settings menu => and then Options.
    • Select Advanced options => and then Sim card
    • Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
    • Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
    • You should be presented with a prompt "Enter Network MEP Code". Type in the 16 or 8 digit unlock code and press in the track wheel / jog dial to confirm
    How to Enter Unlock Codes on BlackBerry Curve:
    You must have a SIM card in your phone to complete these steps, I have found that this procedure works best with an AT&T or Cingular Sim card in the phone (can be active or inactive ). Make sure the phone is not displaying the low battery warning!
    • Power on
    • Go to settings
    • Go to advanced options
    • Go to sim card
    • Type MEPD
    • Type MEP[Alt + 2] (all this with either a cingular or ATT SIM inside)
    • It will ask you for the unlock code. Enter it and your phone is unlocked!
    How to Enter Unlock Codes on BlackBerry 8100 and 8100 Pearl:
    • Go to Options Menu => Advanced Options
    • In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
    • You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2 (*You won't see any text while you are typing either one of these.)
    • Type in the 16 or 8 digit unlock code and your phone is unlocked!
    or
    • Insert SIM into device
    • Power phone on and Turn off the radio (Turn Wireless Off option) VERY IMPORTANT.
    • Select "Options" THEN SELECT ADVANCED OPTIONS
    • Scroll down and select "SIM Card"
    • Type "MEPPD" (please note that you will not see what you type on the screen)
    • Type "MEPP then [ALT BUTTON] then "2" (please note that you will not see what you type on the screen)
    • Enter the Unlock Code
    • Press enter
    • Reboot device. Device is now unlocked.
    How to Enter Unlock Codes on BlackBerry 8700 and 8700c:
    • Go to settings
    • Go to options
    • Go to sim card
    • Type MEPD (not case sensitive) (you will not see text appear on screen while typing)
    • Does it say Network active? if so your phone is locked
    • Hold the ALT Key while typing in MEPE (not case sensitive, and you will not see text appear on screen while typing)
    • It will say "Enter Network MEP Code, Type in the 16 or 8 digit unlock code, press in the jog dial to confirm.
    How to Enter Unlock Codes on BlackBerry 6xxx 7xxx: ie 6230, 7100, 7290 etc.:
    • Select Options menu on BB.
    • Now you select SIM CARD menu. To be able to see this you have to type this on the keypad on phone : (TEXT WILL NOT APPEAR ON THE SCREEN until you enter the unlock code)
    • Type 'MEPD' for all models except 7100 in which case in case use 'MEPPD'.
    • Usually you should see "active" NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if phone is 7100 and will appear a dialog asking for code. NOTE: You must use the "alt" or "shift" key to enable numbers so example would be: m-e-p-"alt key"-2.
    • Now you should see the place to enter your net unlock code. (if not, you didn't type in mep2 or mepp2 properly.)
    • Here you must enter the "NET Unlock Code" that the bb unlocker showed you and hit return.
    How to Enter Unlock Codes on T-Mobile BlackBerry Cell Phones:
    • On the Home screen, click the Tools icon. The Options screen appears.
    • In the tools screen, select the Settings icon.
    • Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
    • Type ‘mepd’ to display the first five levels of SIM locking.
    • T-Mobile uses network locking so the Network should display Active. All other states should display Disabled. Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
    • Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
    • Input the Network Unlock code
    • Press ENTER and reboot handheld.
    How to Enter Unlock Codes on T-Mobile BlackBerry 8100 Cell Phones (alternative instructions if above instructions do not work):
    • Can be done without a sim card inserted.
    • While on the home screen, click the “blackberry key” on keyboard, then select “options”.
    • Choose “Advanced Options”.
    • Select “Sim Card”
    • There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled (you will not see text appear on screen while typing)
    • Type m e p p 2 to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2) ( you will not see text appear on screen while typing )
    • Input the SIM Unlock code
    • Press in the trackball in once
    How to Enter Unlock Codes on T-Mobile Blackberry 8100 Cell Phones (alternative instructions if above instructions do not work):
    • <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">Can be done without a sim card inserted. <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">While on the home screen, click the “blackberry key” on keyboard, then select “options”. <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">Choose “Advanced Options”. <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">Select “Sim Card” <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">There is no area to type these letters; you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled (you will not see text appear on screen while typing) <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">Type m e p p 2 to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2) ( you will not see text appear on screen while typing ) <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt">Input the SIM Unlock code
    How to Enter Unlock Codes on Nokia phones:
    • Compose #pw+yourcode+1# ("yourcode" is meant to be the actual unlock code we gave you)
    ie. #pw+000000000000000+1#
    *** IF THE CODE IS REJECTED, DO NOT TRY AGAIN. ***
    Substitute the 1 at the end with 7.
    So 2nd time try: #PW+YOURCODE+7#
    ie. #pw+000000000000000+7#
    The letter P appears after you quickly press 3 times the button star ( * )
    The letter W appears after you quickly press 4 times the button star ( * )
    The letter + appears after you quickly press 2 times the button star ( * )
    The phone shows "SIM Restriction Off" and is unlocked!
    IF YOU HAVE TRIED TO PUT IN AN INCORRECT CODE 3 OR MORE TIMES PREVIOUSLY & YOU GET PHONE RESTRICTED SIGN, THEN YOUR DEVICE IS HARD LOCKED AND MUST BE UNLOCKED WITH WITH A CABLE AND HARDWARE BOX.
    Sierra Wireless Aircard
    Please download and install Sierra Watcher. Once you have Watcher installed put the non-Cingular SIM into the card and Watcher will prompt you to enter the unlock code. Please make sure to enter the unlock code correctly.
    How to Enter Unlock Codes on Motorola phones:
    • Switch ON your phone with a not allowed SIM Card,
    • Phone should show "Enter Special or Subsidy Code",
    • Enter unlock code
    WARNING: if any of these messages appear :
    - "Contact Service Provider"
    - or "Tamper Alter"
    - or "Wait Before Enter Special Code"
    - or "Contact Service'
    It's because you or somebody else has already entered too many wrong codes. You just have to leave the phone ON on the error message and after 1hr - 8hrs the message "Enter Special Code" will appear again!
    Note: If your phone is on a 3G network enter **057*, then another window will appear to enter the unlock code.
    How to Enter Unlock Codes on Motorola CDMA and TDMA:
    • Press 74663 # [Menu] [Menu] and you will be asked for a subsidy code.
    • Enter unlock code
    • Your phone will be unlocked instantly.
    How to Enter Unlock Codes on Motorola MPX:
    I will supply you with 2 unlock codes. One will be the NETWORK PIN and the other the SERVICE PROVIDER PIN.
    • If phone is asking for NETWORK PIN enter the NETWORK PIN we sent you
    • If phone is asking for SERVICE PROVIDER PIN. Enter the SERVICE PROVIDER PIN we sent you.
    • Your Phone should now be unlocked.
    MPX FAQ's:
    Question: Phone is asking for NETWORK PUK and a new password twice. I entered the code from yourselves but phone saying "Operation not supported by this SIM card".What should I do?
    Answer:
    If you still have the original card
    Please power on the phone with the original card in and when phone fully powered on (You have access to the menu), then
    TYPE: * # * * 3 6 4 # and press green button
    you'll get a error message and after it your will see:Engineering menu
    Click "Options"
    Click "GSM Test"
    Select "Send AT command"
    Now you will see a new window with :
    Send AT Command
    type
    AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN] "
    and press send.
    If you get Response "0 []" phone is unlocked
    If you get 1 error, then make sure you have typed the code correct and try the other code
    If you don't have the original card
    Please switch your phone off, take battery out. Put battery back in, power on the phone.
    Now the phone it will ask to enter NETWORK PUK. Now please DON'T TOUCH the phone for 2 hours.
    After 2 hours it will change screen! Now please enter the code received from us and 00000000 (eight zero's) as a new password.
    Now the phone will be unlocked.
    Question: Phone is asking for SERVICE PROVIDER PUK and a new password twice. I entered the code from yourselves but phone saying "Operation not supported by this SIM card".What should I do?
    Answer:
    YOU NEED to have the original card
    Please power on the phone with the original card in and when phone fully powered on (you have access to the menu), then
    you'll get a error message and after it your see:Engineering menu
    Click "Options"
    Click "GSM Test"
    Send AT Command
    type
    AT+CLCK="PP",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
    and press send.
    If you don't have the original card or if the original card is not accepted because you flashed the phone with other firmware, then sorry but we can't help you.
    Trung tâm sửa chữa phần mềm dtdd Kha Oanh
    dc:224.Khu phố Rạch Sơn ,Thị trấn Gò Dầu , tỉnh Tây Ninh
    Dt :0909 92 94 94 -0966 74 74 94
  2. ( nhatkha ) đã được 6 thành viên cám ơn vì bài viết hữu ích!
    chauanhmobile (11-01-2008), hoangnguyenmobile (10-01-2008), HungCo (10-01-2008), lucky17880 (14-04-2008), trungcr-kh (11-01-2008), vinhls (23-01-2008)
    Thành viên chính thức raovat's Avatar
    Dec 2007
    về ngủ luôn đi pa ơi , hiểu dc chết liền , froum của người viet nam ko hà , đem qua froum khác của người nước ngoài kìa
    Super Moderator Gsm Hưng yên's Avatar
    Dec 2006
    347 Lê Văn Lương TP Hưng Yên
    Trích Được post bởi raovat Xem bài viết
    cảnh cáo pa nha . người ta có lòng up lên cho a e . nếu ko hiểu có thể thắc mắc . đừng làm người up mất hứng
    ps: thanks a kha nha
    Web :http://gsmhungyen.com/
  5. ( Gsm Hưng yên ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    BaoThykd (08-09-2011)
    Feb 2006
    Arrow
    vạch áo cho người xem lưng chi vậy trời
    thua,mình về ngủ đây ,còn bạn về đi làm gì biết rùi chứ gì
  7. #5
    V.I.P sybenlove's Avatar
    Oct 2007
    thằng này nói đúng,post bài như thế thi có một số anh em hiểu,còn đa số thì ko hiểu,mà nội quy của diễn đàn là phải post bài bằng tiếng việt,có dấu
    đề nghị mod xem lại,nếu có thể thì dịch sang tiếng việt luôn,cảm ơn
  8. ( sybenlove ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    V.I.P HungCo's Avatar
    Aug 2006
    Trích Được post bởi sybenlove Xem bài viết
    Có 1 số vấn đề khi dịch sang TV lại gây khó hiểu đó bạn vì thế tốt nhất nên giữ nguyên bản tiếng anh!
    Và cũng xin lưu ý 2 bạn là nên dùng lời lẻ nhẹ nhàng tí!
    ĐẠI LÝ BƯU ĐIỆN 3-2
    04 ĐẶNG VĂN VIỄN SÓC TRĂNG
  10. ( HungCo ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Thành viên tích cực NgọnHảiĐăng's Avatar
    Nov 2007
    Cát Bụi !!
    nếu nhớ ko lầm thì forum nào cũng có nội quy là " gõ tiếng việt có dấu hoặc tiếng anh "
    Một Nửa Tôi Ơi ....... Đâu Rồi !!!!!!!!!
  12. #8
    Thành viên chính thức huyducgsm's Avatar
    Mar 2006
    em thấy mod up bài lên vậy là một cái hay một cái mới ...nếu không biết tiếng anh thì học cho biết chứ ai lại nói vậy ...có nhiều người vẫn còn học nữa mà anh ...học học nữa học mãi..
  13. #9
    Aug 2006
    Thank nhiều nha!
    Còn ai cần unlock bằng code thì liên hệ mình nha!
    ĐẠI LÝ BƯU ĐIỆN 3-2
  14. #10
    Feb 2006
    các bạn muốn có code thì phải mua HUNG CÒ còn trên chỉ là cách nhập , ah mà HUNGCO ơi mua code có nhanh không bạn
  1. Nhận repair và Unlock máy HTC G2 T-mobile mua code nhập OK mà không có sóng hoặc máy chưa unlock
    By saigonmobile in forum Dịch vụ unlock trực tiếp điện thoại di động
    Trả lời: 20
    Bài viết cuối: 13-01-2016, 10:55
  2. Trả lời: 2
    Bài viết cuối: 24-10-2014, 13:04
  3. bb 9800 at&t nhập code unlock quá 10 lần
    By quangthang007 in forum BLACKBERRY
    Bài viết cuối: 13-04-2013, 08:53
  4. Nokia X6 SHOW Read Code OK bởi UB, nhập code báo lỗi
    By phidinhmobile in forum Universal Box
    Bài viết cuối: 27-03-2011, 23:15
  5. Trả lời: 0
    Bài viết cuối: 16-03-2011, 09:44
