đã fomat bằng tay mà không hết
đây là log của em nó
mong ace nhiệt tình chỉ giúp
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0846C4D
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00010686
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.14016(30-03-2012)
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0C60010BE59E0052307970F2F9DADC99B3BCEE89
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0xFF bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0xFF bytes).
Reading CMT HWC (0xFF bytes).
Reading CMT R&D (0xFF bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X6-00 USB Phonet, PORT_ID: 1E02EEFE
Verifying communication to device OK.
Phone type: RM-559 (Nokia X6-00)
SW version: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia
ApeCoreSw: V 40.0.002
Imei plain: 35342204927701-4
Product code: 059B881
Battery voltage: 3666 mV, current: 285 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353422049277014
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
 LinkBack URL About LinkBacks
			 nokia x6 phone startup failed contact retailer
			 Được post bởi VanTuan-ST
