em nhận cây 2730 contact sevice em đã flass lại rùi đây là log của em nó ạ
MXKEY Serial: [FT SCR2000 0] - C0848F40
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.67
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: rm578__10.47.mcusw
[BB5,BB5 ALGORITHM] size: 21.65 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2609CF45
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101023000
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0F90000A66F88D56080C87E27031FF780DE59DCA
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3AAFD673
Verifying communication to device OK.
Erase size: 23.25 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.687 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.703 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.579 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.296 s
CMT FLASH,NOR area [00140000-0155FFFF] erased in 1 min 41.688 s
CMT FLASH,NOR area [01560000-0175FFFF] erased in 10.203 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 8669C775 [RAP Certificate 215 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 16.875 s
Processing PPM file: rm578__10.47.ppm_x
[BB5,BB5 ALGORITHM] size: 6.78 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01760000-01FFFFFF] erased in 43.031 s
Programming completed in 25.406 s
Processing CNT file: rm578__10.47_005.image_x_ctv_id_v2_4r0c9
[BB5,BB5 ALGORITHM] page size: 128 K size: 16.27 MB
Erase size: 31.75 MB
CMT FLASH,NOR area [02000000-0245FFFF] erased in 27.672 s
CMT FLASH,NOR area [02460000-03FBFFFF] erased in 2 min 54.937 s
Programming completed in 1 min 0.281 s
Total time for flashing process(boot+erase+write) was 9 min 14.016 s
Device connected: nmwcdc\Nokia 2730 classic USB Phonet, PORT_ID: 33864E32
Phone type: RM-578 (Nokia 2730 classic)
SW version: V 10.47 27-08-10 RM-578 (c) Nokia
Imei plain: 35937003485190-1
Product code: 0585313
Battery voltage: 3847 mV, current: 64 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359370034851901
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.453 s
em đã thử flass lại bằng ATF log cũng đẹp long lanh à
sư huynh nòa có cao kiến gì chỉ dùm em với.em vẫn chưa làm phần chứng
			 2730 contact sevice cần dúp
