Kết quả 1 tới 10 của 16
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    Mặc định Nokia 105 lắp sim tắt nguồn, tự khởi động lại.
    Nếu Anh em gặp trường hợp máy 105 lắp sim bị tắt nguồn, tự khởi động lại thì Falsh lại cho máy.
    Chỉ cần Falsh 1 file MCU.RM-908-105_ver 3.10_Flash ok_ Không có Tiếng Việt - Tải về - 4shared _Lưu ý: Chỉ Flash 1 file MCU.
    Nếu nạp cả 3 file trong bộ file này sẽ không có Tiếng Việt.
    Còn nếu Flash file cao hơn 3.10 lên nguồn tối màn hình, chỉ sáng đèn bàn phím.
    Code:
    VBATT Powering Down <<<<
    VBATT Powering Up   >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    Booting Phone...
    CPU ID Response: A200341100
    CPU Type: XG110 2.1B
    Phone Booted at after First attempt...
                      TIME STARTS HERE
    Sending PBL 19456 bytes...
    PBL Successfully Sent...
    Sending SBL 65024 bytes...
    SBL Successfully Sent...
    Flash Chip Manufacturer ID: 0x00EF
    Flash Chip Type: 64 Mbit (4Mb x 16) NOR
    Extended Information: Multi-Bank / 1.8v
    Processing Image File: C:\Documents and Settings\Thien Uy\Desktop\rm908_003.100
     Checking Flash Image...
    Number of Sections: 03
    IMAGE Certificate Block Sent Successfully...
     Processing Section 01 of 03
    IMAGE Erase Block: 0x00800000~0x00A0FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 2162688 bytes
    Data Checksum: 0551
    Uploading Data Blocks to phone...
    IMAGE Data Blocks uploaded to phone...
     Processing Section 02 of 03
    IMAGE Erase Block: 0x00C60000~0x00E8123E
    Start Erasing...
    Block Erase Done...
    Data Size: 2232896 bytes
    Data Checksum: 89F6
     Processing Section 03 of 03
    IMAGE Erase Block: 0x00FFC000~0x00FFC03E
    Start Erasing...
    Block Erase Done...
    Data Size: 64 bytes
    Data Checksum: 0000
    Start Data Verification... (Please wait)
    Data Verification Successful...
    Exit Flash Mode Done...
    Time Elapse : 00:01:16
        You must Factory Reset the phone to enable the
       ringtones and other  customized settings to work
     Waiting For Phone to go Online...
     5,  4,  3,  2,  1...
    MCU: V 03.10 29-05-13 RM-908 (c) Nokia
    IMEI: 358146052403341
    Product Serial Number: 007D2BFAU
    Product Code         : 059R488
    Module Code          : 0205453
    Basic Production Code: 059Q858
    PPM SW Version       : V 02.70 22-02-13 RM-908 (c) Nokia MR
    ADSP Version         : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nmr
    MCU SW Version       : V 03.10 29-05-13 RM-908 (c) Nokia
    HW Version           : 3000
    UEM Version          : 1328
    UPP Version          : 8850
    LCD Version          : CMI:BEIHAIv01 ILI9163C
      ********** SIMLOCK INFO  **********
    CONFIG_DATA  : 0010100000000000
    PROFILE_BITS : 0000000000040002
    ASIC         : 11
    PROVIDER     : Default Test Operator
       Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
    ST_LCD_TEST               : PASSED
    FACTORY SET TO : Full Factory Set
     OK
    FACTORY SET TO : User Data
     OK
    FACTORY SET TO : Leave Factory
     OK
    FACTORY SET TO : Service Center
     OK
    FACTORY SET TO : Software Upgrade
     OK
    FACTORY SET TO : Production Tune
     OK
  2. ( THIÊN UY™ ) đã được 17 thành viên cám ơn vì bài viết hữu ích!
    badboy25062002 (28-03-2014), DTDD Hoai Bao (23-04-2014), hoangdai1989 (18-10-2014), hoanghieu (14-04-2014), huonggiangmobile (23-04-2014), khanhmobile87 (29-03-2014), khuongakak (23-04-2014), Mr.Chi (08-02-2014), ngoccuc_mobi (26-06-2014), nnm (15-02-2014), phamdienmobile (07-03-2014), quankom (23-04-2014), sau666_gsm (26-06-2014), thaigsm181 (28-03-2014), thanhphone (29-03-2014), tnhan1981 (28-05-2014), tuanhung.dd (11-02-2014)
    Thành viên mới Mr.Chi's Avatar
    Oct 2009
    thanks MOD. lần sau gặp chánh lun
    Vi phạm nội quy tuanngoc2911's Avatar
    thank mod , nắp sim tắt nguồn tưởng lỗi phần cứng thế mà lại là nỗi phần mềm sợ thật . Quả là một kinh nghiệm quý báu .
    Thành viên chính thức thaigsm181's Avatar
    May 2012
    AN PHÚ BÌNH DƯƠNG
    hay quá đơn giản mà hiệu quả ,đỡ mất thời gian ,suýt nữa mình phan PA ,cám ơn mod
    Thành viên tích cực sangmobilehd's Avatar
    Aug 2011
    Trích Được post bởi Mr.Chi Xem bài viết
    biết thế mà báo khách .sao phài tránh
    CH Sửa Chữa ĐTDĐ Anh Sáng
    Call : 0973541397 - Kinh Môn - Hải Dương
    Thành viên kỳ cựu dinhtoan179™'s Avatar
    Nov 2012
    HOA BÌNH
    rong mơi bây giơ toan lối pm thui
    Thành viên chính thức badboy25062002's Avatar
    thanks pác ......................
  9. #8
    Thành viên mới khuongakak's Avatar
    Jan 2011
    thank mod e vừa phang 1 e ok......................
  10. #9
    Thành viên tích cực quankom's Avatar
    Oct 2012
    hay thật đúng là điẹn thoại.ai hay chữ ngờ
    thủy nguyên-Hải Phòng.mobile 0965682404...!!!!!!!
  11. #10
    Oct 2013
    Sóc Trăng
    có kèo thử liền
    Đời còn dấu ?
    Thì mọi chuyện còn thay đổi.
  12. ( DTDD Hoai Bao ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hieucbu (26-08-2014)
