This is the list of common problems with Motorola phones, and ways to repair it :
PH_CODE_SIG_ERROR: xx Phone firmware signature does not match ! To repair this problem flash phone with MONSTER FIRMWARE ! DO NOT use "Repair" button!
MEM_MAP_BLANK Service Req'd
Phone firmware is erased. To repair this problem, flash phone with monster flash file. DO NOT use "Repair" button !
SW Version: NOT FOUND Phone has erased PDS. To repair this problem allways flash phone with monster file, and if problem persists PRESS REPAIR button
When insert battery, phone shows:
ERROR:
DE
AD Flash chip is damaged, and it needs to be replaced. After replacement, You have to perform flashing, PDS repair and IMEI write procedure.
ERROR:
DAB
Or
ERROR:
0 Bootcore security does not match. There are two ways to repair it:
Press REPAIR button. If You get "Unable to connect" perform REPAIR using TEST POINT !
When insert battery phone starts in BOOTLOADER mode with NO ERRORS
There is two reasons for this:
- Flash Chip OTP does not match CPU SN To repair this problem, WRITE IMEI to phone
- Flash Chip is damaged and needs to be replaced
			 Những lỗi thường gặp của motorola và cách repair nó
			 Được post bởi nhatkha
			 7 chữ biết k quan trọng chữ thứ 8 - 10 k biết click vô die máy ặc ặc
