1200 rớt nước,sấy khô xái được2 tháng mất nguồn,em thay cpu+flash+uem.bỏ vô jaf nạp sw 5.80,ok hết,chưa có imei????????????,info ok,chuyển chế độ normal,máy lên nguồn.nhưng khi kẹp nguồn thì không lên,dao động khoảng 0.3v rồi rớt xuống,em đã thay con uem khác,tình trạng vẫn y như vậy.anh nào gặp rồi chỉ giáo em với.cám ơn các anh trước nha.
MCU ID: 0x2292
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 2A7E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.80
14-11-08
RH-99
(c) NMP
HW version:
PCI version:
UEM version: 1314
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.80
14-11-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.80\n14-11-08\nRH-99\n(c) NMP\nmr
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 6F F8
Master Code: 5013663745
Phone type: RH-99, Software version: 5.80, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: \Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ij
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ij
Done!
			 1200 bệnh lạ đây
 1200 bệnh lạ đây
