Trang 10 của 14 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 CuốiCuối
Kết quả 91 tới 100 của 134
    Jan 2007
    LG 2-3G Tool v7.6 released. LG G2 mini, F60
    Added :
    - support LG D625 (imei repair, direct unlock in test mode) thanks to cellcarcol - first in the world
    - support LG MS395 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to TBOUY
    Multi-language interface - for translate use Z3X LG 2-3G Tool (Z3X LG 2-3G Tool)
    P.S more and more hot things comming soon.
    Jan 2007
    LG 2-3G Tool v7.7 released. LG Leon™ LTE, G Stylo™ - world first
    Added :
    - support LG H345 (imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) - first in the world
    - support LG H631 (imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) - first in the world
    - support LG H815L (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H815T (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H815TR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG MS345 (imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) - first in the world
    - support LG MS631 (imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) - first in the world
    Jan 2007
    LG 2-3G Tool v7.8 released. LG H959 G Flex 2
    WORLD FIRST SOLUTION for enable DIAG port in LG Android 5.x!
    Code:
    277634#*# -> Port check Test -> set Enabled. Reconnect device.
    Added :
    - support LG H955A (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H955AR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H955HK (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H955P (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H955TR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support LG H959 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks goguzhan - world first!
    + In options new function: Auto backup/restore qcn.
    * Fixed Device not found! - now software kill ADB server few times.
    Jan 2007
    LG 2-3G Tool v8.0 released. LG L90 Dual, G2 mini, G3 Beat, G3S Dual
    Added :
    - support D150 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D157 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D157F (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to toninhosantos
    - support D410 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D410H (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D410HN (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to toninhosantos - world first!
    - support D410N (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D618 imei master/slave repair
    - support D722AR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D722PA (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D724 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D727 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D728 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D729 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D856 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D857 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D858 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D858HK (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support D859 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support H440AR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    - support H443 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
    * some bug fix.
    + new qcn files.
    Jan 2007
    LG 2-3G Tool v8.1 released. Big Boom Update. Direct unlock without root.
    Added :
    - support D410 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D410H (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D410HN (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D410N (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D618 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D724 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D728 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D729 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D856 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D857 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D858 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D858HK (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support D859 (world first direct unlock(without root), world first imei master/slave repair(without root), sec zone read/write/reset(without root))
    - support LG H815LA (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to raulka2003 - world first!
    Support without root:
    D290 (direct unlock, imei repair, sec zone read/write/reset)
    D290AR (direct unlock, imei repair, sec zone read/write/reset)
    D290G (direct unlock, imei repair, sec zone read/write/reset)
    D290N (direct unlock, imei repair, sec zone read/write/reset)
    D290TR (direct unlock, imei repair, sec zone read/write/reset)
    D295 (direct unlock, imei repair, sec zone read/write/reset)
    D295F (direct unlock, imei repair, sec zone read/write/reset)
    D390AR (direct unlock, imei repair, sec zone read/write/reset)
    D390 (direct unlock, imei repair, sec zone read/write/reset)
    D390N (direct unlock, imei repair, sec zone read/write/reset)
    D390NS (direct unlock, imei repair, sec zone read/write/reset)
    H815 (direct unlock, imei repair, sec zone read/write/reset)
    H815AR (direct unlock, imei repair, sec zone read/write/reset)
    H815K (direct unlock, imei repair, sec zone read/write/reset)
    H815P (direct unlock, imei repair, sec zone read/write/reset)
    and more new LG models.
    some bug fix.
    new qcn files.
    Jan 2007
    LG MTK Tool 2.5.0.0 Has been released. The biggest news in MTK since MTK
    After few month of work new big update ready
    Just enjoy.
    New models added:
    - LG D331 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG D335 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG D337 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H500 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H500F (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H500G (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H500T (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H502 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H502F (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H502G (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H502T (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H320 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H320AR (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H320MB (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H324 (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H324T (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H324TR (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H326G (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read Full Flash, Read info)
    - LG H326T (Direct Unlock, Read codes, Repair IMEI, BT/Wi-Fi, R/W/R EEPROM, Read FEPROM, Read Full Flash, Read info)
    Addition function added:
    Direct UNLOCK + IMEI1 , IMEI2 and WIFI+BT repair for old models :
    LG D100,LG D100AR,LG D100F,LG D100G,LG D100J,LG D105,LG D105F,LG D107F
    LG D213,LG D213AR,LG D213C,LG D213CF,LG D213CJ,LG D213F,LG D213N,LG D213TR
    LG E440,LG E440F,LG E440G,LG E440J,LG E445,LG E450,LG E450B,LG E450F,LG E450G
    LG E450J,LG E451G,LG E455,LG E455F,LG E455G,LG E460,LG E460F
    - Write EEPROM Function
    Qualcomm 9008 (qhsusb_buld) Repair Tool news:
    LG D850 QHSUSB 9008 Mode Read/Write BOOT
    LG D851 QHSUSB 9008 Mode Read/Write BOOT
    LG D852 QHSUSB 9008 Mode Read/Write BOOT
    LG D855 QHSUSB 9008 Mode Read/Write BOOT
    LG MS500 QHSUSB 9008 Mode Read/Write BOOT
    LG D500 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM7x30 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8x10 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8x25 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8x25A QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8x25Q QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8064 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8660 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8930 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8960 QHSUSB 9008 Mode Read/Write BOOT
    Generic MSM8974 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-T QHSUSB 9008 Mode Read/Write BOOT
    Andromax-U3 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-C3 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-G2 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-I3S QHSUSB 9008 Mode Read/Write BOOT
    Andromax-U QHSUSB 9008 Mode Read/Write BOOT
    Andromax-C2 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-C QHSUSB 9008 Mode Read/Write BOOT
    Andromax-I3 QHSUSB 9008 Mode Read/Write BOOT
    Andromax-G QHSUSB 9008 Mode Read/Write BOOT
    Andromax-I2 QHSUSB 9008 Mode Read/Write BOOT
    ONE PLUS ONE QHSUSB 9008 Mode Read/Write BOOT
    NOKIA 925 RM892 QHSUSB 9008 Mode Read/Write BOOT
    Added TP view for semi dead devices for forcing 9008 tp mode
    Sample log
    Code:
    Selected model is:LG D335
    Using COMPORT: COM5
    Analising USB Configuration...
    Connect powered off MTK Device to USB cable... You have 20 seconds.
    USB Serial COM Attached to system...
    COM Port short name : COM20
    COM Port full name : LGE AndroidNet USB Serial Port
    COM Port hardware id : USB\VID_1004&PID_61F1&REV_0100&MI_02
    Open port COM20...
    Send start CMD commands...done
    Read HW_CODE...done
      HW_CODE: 0x6582
    Read HW_SW_VER...done
      HW_SUB_CODE: 0x8A00
      HW_VER: 0xCA01
      SW_VER: 0x0001
    GetEntryRegion...donedonedone
    Send DA Agent...done
    Wait DA response...done
    Send storage device and external ram device config...done
    Detect NAND Flash...done
    Get target inforamtion...done
    Booting OK
    EMMC Config:
    EMMC rpmb size: 512kb
    EMMC boot1 size: 4096kb
    EMMC boot2 size: 4096kb
    EMMC user area size: 3360 Mb
    Read logical partitions info...done
    Totally detected partitions: 34
    Searching security blocks...ok
    Reading Security...done
    IMEI A: 34543344534444
    IMEI B: 34543344534444
    Bluetooth address:0C48851FC6AB
    Wi-Fi MAC address:34FCEFE7AF50
    NCK: 7074190899707317
    NSCK: 2003184140924574
    SPCK: 4863651695645790
    CCK: 1229041444683883
    SIM: 3526112302063762
    HCK: 0000000000000000
    Backup are saved into C:\Program Files (x86)\Z3X\MTK\\Backups\Backup_LG D335_00000066337668_SEC.BIN
    done
    Read Info OK , Model:LG D335
    Using COMPORT: COM5
    Open port COM20...
    Read HW_CODE...done
      HW_CODE: 0x6582
      HW_SUB_CODE: 0x8A00
      HW_VER: 0xCA01
      SW_VER: 0x0001
    Booting OK
    EMMC Config:
    SML Data: 000
    Old IMEI A: 34543344534444
    New IMEI A: 777777777777777
    Old IMEI B: 34543344534444
    New IMEI B: 555555555555555
    Write MISC2 Partition...done
    Update Security Info OK
    Using COMPORT: COM5
    Open port COM20...
    Read HW_CODE...done
      HW_CODE: 0x6582
      HW_SUB_CODE: 0x8A00
      HW_VER: 0xCA01
      SW_VER: 0x0001
    Booting OK
    EMMC Config:
    Backup are saved into C:\Program Files (x86)\Z3X\MTK\\Backups\Backup_LG D335_77777777777777_SEC.BIN
    done
    Jan 2007
    LG 2-3G Tool v8.2 released. Lot of news inside
    Added:
    - support D280( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280AR( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280F( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280G( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280N( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280NR( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D280TR( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D285 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D285F (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode(
    - support D285G ( flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode)
    - support D290 ( flashing )
    - support D290AR (flashing )
    - support D290G (flashing )
    - support D290J (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support D290N (flashing)
    - support D290TR (flashing)
    - support D295 (flashing)
    - support D295F (flashing)
    - support D320 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320AG (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320AR (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320F (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320F8 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320G8 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320J8 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320N (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D320TR (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D321 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D390 (flashing)
    - support D390AR (flashing)
    - support D390N (flashing)
    - support D390NS (flashing)
    - support D410 (flashing)
    - support D410H (flashing)
    - support D410HN (flashing)
    - support D410N (flashing)
    - support D618 (flashing)
    - support D722 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D722AR (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D722J (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support D722K (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D722P (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D722PA ( flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D722V (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support D723 (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support D723TR (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support D724 (flashing)
    - support D728 (flashing)
    - support D729 (flashing)
    - support H220 (flashing, direct unlock in flash mode, imei repair in flash mode, sec zone read/write/reset in flash mode)
    - support H221 ( flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H221AR (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H221F (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H221G (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support H222 (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H222F (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H222G (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H222TTV (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support H222TV (flashing, direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, read/write qcn, sec zone read/write/reset in flash mode/adb mode.)
    - support V496 (direct unlock in flash mode/adb mode, imei repair in flash mode/adb mode, qcn read/write, sec zone read/write/reset in flash mode/adb mode) thanks to ghacks) - world first!
    * Flasher for this models work in two mode's : indirect(software send firmware image in phone and phone unpack this image) and direct(software write firmware direct in flash). Direct mode faster. In options user can change indirect/direct mode.
    * Changed software logo
    * Fixed some bugs
    * We delete some help files because we work in new help's from zero. Users must wait, if you have any questions ask in forum.
    (Z3X LG 2-3G Tool)
    Jan 2007
    LG 2-3G Tool v8.4 released. Google account lock reset added
    Google Account Lock reset for LG G4, G4s series and other LG Qualcomm in Android 5.X.
    1. Turn off phone.
    2. Press and hold Volume Up button.
    3. Insert USB cable in phone.
    4. In Lg 2-3G tool select your model and press Google Account Reset.
    Added:
    - support D850 (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D850PR (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D851 (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D851TN (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D851WH (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D852 (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D852G (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D855 (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D855AR (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D855K (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D855P (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support D855TR (flashing, direct unlock in flash mode, imei repair in flash mode)
    - support F430K (direct unlock in adb mode, imei repair in adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in adb mode)
    - support F430L (direct unlock in adb mode, imei repair in adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in adb mode)
    - support F430S (direct unlock in adb mode, imei repair adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in adb mode) thanks to love edition
    Jan 2007
    LG 2-3G Tool v8.5 released. New phones added.
    Added:
    - support H630 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H630D (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H630I (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H634 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H635 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H635A (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H635AR (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H635C (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H635CX (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support H636 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, google account reset)
    - support V490 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode)
    - support V495 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode) - world first!
    * Fixed some bugs
    Mega: LG_2-3G_Tool_8_5.exe
    Jan 2007
    LG 2-3G Tool v8.6 released. New flasher. LG G4 Duos. World First!
    Now our flasher have auto partition - you can flash 16Gb firmware in 32Gb phone.
    Now our flasher format user data after flashing(in options check: Format user data after flash)
    Now our flasher support TOT file format.
    Addition function and new phones added:
    - support D800 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D800P (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D800T (direct unlock in flash/adb mode, imei repair in flash/adb mode, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP))
    - support D801 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D801BK (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D801HW (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D801Z (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D802 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D802T (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D802TA (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D802TR (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D803 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D805 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D806 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP))
    - support D856 (flashing, direct unlock in flash mode, repair imei in flash mode, reset Google Account Reset(FRP)) - Thanks to ddilshod93
    - support H812 (imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP)) - Thanks to bubblehead
    - support H818 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP))
    - support H818N (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP))
    - support H818P (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP))
    - support H818PA (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP)) - Thanks to Garry - World first!
    - support H819 (direct unlock in flash/adb mode, imei repair in flash/adb mode, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, reset Google Account Reset(FRP))
    Updated flashing algo for next models:
    D280, D280AR, D280F, D280G, D280N, D280NR, D280TR, D285, D285F, D285G, D290, D290AR, D290G, D290J, D290N, D290TR, D295, D295F, D320, D320AG, D320AR, D320F, D320F8, D320G8, D320J8, D320N, D320TR, D321, D390, D390AR, D390N, D390NS, D410, D410H, D410HN, D410N, D618, D722, D722AR, D722J, D722K, D722P, D722PA, D722V, D723, D723TR, D724, D728, D729, D850, D850PR, D851, D851TN, D851WH, D852, D852G, D855, D855AR, D855K, D855P, D855TR, H220, H221, H221AR, H221F, H221G, H222, H222F, H222G, H222TTV, H222TV, H630, H630D, H630I, H634, H635, H635A, H635AR, H635C, H635CX, H636, H734, H735, H735AR, H735L, H735MT, H735P, H735T, H735TR, H736, H736P
    * Bug fix.
    Mega: LG_2-3G_Tool_8_6.exe
  1. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  2. HWK New Update AE Post ở đây !!!
    By HoangThong_hotrokythuat3 in forum HWK
    Trả lời: 24
    Bài viết cuối: 31-03-2016, 17:58
  3. Axe Box New Update AE Post ở đây
    By TuấnPhát_GSM in forum AxeBox
    Trả lời: 27
    Bài viết cuối: 16-01-2012, 09:38
  4. MT Box New Update AE Post ở đây !!!
    By HoangThong_hotrokythuat3 in forum MT-Box
    Trả lời: 35
    Bài viết cuối: 23-11-2011, 08:07
  5. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
