Sgold3 Tool 2.3.0.1 Update
Added:
- GS170 Full Support.
- GT350 Full Support.
- KM553 Full Support.
Added Pause SmartCard function.
Added support of new TOP SmartCards.
Added:
MT BOX (29-06-2011)
LG 2/3G Tool 2.1.5 Update. check inside
Added:
- GD880 full support (read/write/repair NVM, improved unlock, imei repair)
- GD880f full support (read/write/repair NVM, improved unlock, imei repair)
- GD880g full support (read/write/repair NVM, improved unlock, imei repair)
-new version of korean firmware added for unlock
p.S From now 2g tool phones, 3g tool phones, lang editor will be in 1 program: LG 2g/3g tool
http://forum.gsmhosting.com/vbb/f453...nside-1219220/
mobile services
NHƯ HẠ
yahoo: gialai_gsm
MT BOX (29-06-2011)
LG Sgold3 Tool 3.2 Update.
Added:
- C100 full support ( Flash R/W, Read Codes, Direct Unlock )
- C105 full support ( Flash R/W, Read Codes, Direct Unlock )
- A130/C300/GU230 Module Improved , now
- all codes include NS SP CP are read and no zero codes.
C100 Rebranding video :
YouTube - LG C100 Flashing with Z3X Sgold Tool 3.2
MT BOX (29-06-2011)
SGOLD 3.3 Update
Added:
- Added GT500 Full Support (Flash R/W Unlock Direct )
-Added GT505 Full Support (Flash R/W Unlock Direct )
-Added T300GO Full Support (Flash R/W Unlock Direct / Codes)
-Improved T300 Codes Reading
Thanks R-Man for testing.
MT BOX (29-06-2011)
Z3X LG BOX NEWS. LG SGOLD 3.6 Update.
LG SGOLD 3.6 Update
Added:
- KF900 P rada Full Support (Flash Read/Write, Unlock Direct )
- T310i Full Support (Flash Read/Write Unlock Direct )
- T310N Full Support (Flash Read/Write Unlock Direct )
LG SGOLD 3.6. Few phones added.
mobile services
NHƯ HẠ
yahoo: gialai_gsm
MT BOX (29-06-2011)
Z3X LG BOX NEWS. LG SGOLD 3.6 Update. LG 2-3G Tool v2.2 build 0048.Begin of mass upd
LG 2-3G Tool v2.2 build 0048. Update. First in the world
Added:
- A170 support (direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- A175 support (direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- A175a support (direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- A175bsupport ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- A180support ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset) - First in the world
- A180asupport ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset) - First in the world
- A180bsupport ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset) - First in the world
- B2250 support ( direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- C1300i support ( direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- C2100support ( direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- F2200 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- F2250 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G1500 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G210 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G220 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G232 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G233 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G259 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G262 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G263support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G282support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- G4011 support (direct unlock, firmware/call.data write, full flash/call.data read, factory reset)
- GW550support (direct unlock, code reading, security repair.
- GW550hsupport ( direct unlock, code reading, security repair.
// Update for korea users
Added :
- KH2700 new version support (KW270805_NAND_BLOCK)
- SH650 new version support (SW650805_NAND_BLOCK)
- KU9300 new version support (KU930003_NAND_BLOCK)
- KH6400 new version support (KW640806_NAND_BLOCK)
- KH2700 new customization support (KW180711_NAND_BLOCK____)
- KH1800M new version support (KW18M807_NAND_BLOCK)
- SH150 new customization support (SW150706_NAND_BLOCK__)
- KH8000 new customization support (KW800907_NAND_BLOCK_)
LG 2-3G Tool v2.2 build 0048. Begin of mass updates.are you ready?
mobile services
NHƯ HẠ
yahoo: gialai_gsm
MT BOX (29-06-2011)
Z3X LG BOX NEWS. LG 2-3G Tool v2.3 build 0053. Second mass update. Need more?
LG 2-3G Tool v2.3 build 0053 Update. First in the world.
Added:
- A100 support ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset) - World first!
- GB107 support ( direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset )
- GB125 support (direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset )
- GB125a support ( direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset )
- GB125R support ( direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset )
- GM205GO support ( direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- GS117 support ( direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- GU200e support (direct unlock, code reading, firmware/eeprom write, full flash/eeprom read, factory reset)
- KG98 support ( direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- KP107 support (direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- KP109 support (direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- KP109a support (direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- KP109b support ( direct unlock, code reading, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- KP135 support ( direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- L1400i support ( direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- L341i support (direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- LG225 support ( direct unlock, imei repair, firmware/eeprom write, full flash/eeprom read, factory reset)
- LG900G support ( code reading, full flash/eeprom read )
GW550 new version support added(M76XXDSDCAOPZM-656010 , CCI:LG LQ86 1.0.11)
LG 2-3G Tool v2.3 build 0053. Second mass update. First in the world. Need more?
Thanh Tùng MobileĐịa chỉ : Chợ gạo - Thành Lợi - Vụ Bản - Nam Định
Phone : 0905022590
Z3X BOX LG NEWS. LG 2-3G Tool 2.3 build 0059 release. Mass update.
LG 2-3G Tool 2.3 build 0059 release. Update.
Added:
- KU6300 support (direct unlock, nvm read/write/repair, read nand)
- SU630 suppoprt (direct unlock, nvm read/write/repair, read nand)
- L03C support (direct unlock, nvm read/write)
- G7020 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- G7030 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)-
- G7070 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- KG129 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- KG180 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- KG248 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- KG298 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- KG276 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- LG8390 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG110 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG115 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG161a support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG165 support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG165a support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG180c support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG185c support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG191a support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
- MG191b support (direct unlock, imei repair, read call.data/full flash, write call.data/firmware/full flash, factory reset)
Added more hints for phones - special thanks to Brod Aries, if need some correct in hints or add write to my in PM and we will add
LG 2-3G Tool 2.3 build 0059 release. Again mass update.
mobile services
NHƯ HẠ
yahoo: gialai_gsm
Z3X LG SGOLD 3.7 Update. All inside![]()
SGOLD 3.7 LG Update:
Added :
- GM600 Full Support (Flash R/W Unlock Direct )
- T320E Full Support (Flash R/W Unlock Direct )
- T320G Full Support (Flash R/W Unlock Direct )
- TE770 Full Support (Flash R/W Unlock Direct )
- KE820 Full Support (Flash R/W Unlock Direct )
- KM900E Full Support (Flash R/W Unlock Direct )
Added detailed step-by-step operations manuals for most each model from list.
- Improved SEMC modules ( hang upon connection , improved flashing speed , UI etc )
- Fixed critical bug with hanging upon connection on "sending authority..." msg
Z3X LG SGOLD 3.7 Update:
mobile services
NHƯ HẠ
yahoo: gialai_gsm
MTK Smart Tool 2.0.1.0 Released.
MTK Smart Tool 2.0.1.0:
-Improved support of phones , based on MT6253 chipset.
-Fixed some models avatars.
-Faster software startup , few seconds on new smartcards.
LG Module:
Added:
- LG A155 support(Unlock, Flash Reading, Codes Reading)
- LG A165 support(Unlock, Flash Reading, Codes Reading)
- LG GB161 support(Unlock, Flash Reading)
- LG KG198 support(Unlock, Flash Reading)
ALCATEL Module:
Added some new pids for existing models base updated to Sept. 2011. P.S Many new pids will be avaiable in next release.
-Alcatel OT-361 Calc Codes NCK etc.
-Alcatel OT-362 Calc Codes NCK etc.
-Alcatel OT-385(J) Calc Codes NCK etc.
Phone : 0905022590
