Kết quả 11 tới 11 của 11
  1. #11
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    Trích Được post bởi tran hoi Xem bài viết
    ---------- eMMC Device Information ----------
    EMMC CID : 90014A4834473262110106B70C305284
    EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA
    EMMC Manufacturer ID: 0090 , OEM ID: 014A
    EMMC Date: 05/2015 Rev.0x1
    EMMC NAME: H4G2b , S/N: 112659504
    EMMC NAME (HEX): 48344732622000
    EMMC ROM1 (Main User Data) Capacity: 3728 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
    EMMC Permanent Write Protection: No
    EMMC Temporary Write Protection: No
    EMMC Password Locked: No
    Extended CSD rev 1.6 (MMC 4.5)
    Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
    Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
    H/W reset function [RST_N_FUNCTION]: 0x00
    High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
    Partitioning Support [PARTITIONING_SUPPORT]: 0x07
    Device support partitioning feature
    Device can have enhanced tech.
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01
    Backup saved: H4G2b _ 112659504_20170401_1644.extcsd
    Searching for partition tables...
    Detected GPT over MBR...
    Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20
    Warning: Entries Count = 26
    MMCBLK0P0 (SBOOT) Range: [0X400000,0X5FFE00] ,Len: 200000
    MMCBLK0P1 (SBOOT2) Range: [0X600000,0X7FFE00] ,Len: 200000
    MMCBLK0P2 (WFIXNV1) Range: [0X800000,0X8FFE00] ,Len: 100000
    MMCBLK0P3 (WFIXNV2) Range: [0X900000,0X9FFE00] ,Len: 100000
    MMCBLK0P4 (TDFIXNV1) Range: [0XA00000,0XAFFE00] ,Len: 100000
    MMCBLK0P5 (TDFIXNV2) Range: [0XB00000,0XBFFE00] ,Len: 100000
    MMCBLK0P6 (WDSP) Range: [0XC00000,0XFFFE00] ,Len: 400000
    MMCBLK0P7 (MODEM) Range: [0X1000000,0X17FFE00] ,Len: 800000
    MMCBLK0P8 (MODEM2) Range: [0X1800000,0X1FFFE00] ,Len: 800000
    MMCBLK0P9 (TDDSP) Range: [0X2000000,0X23FFE00] ,Len: 400000
    MMCBLK0P10 (FOTA_SIG) Range: [0X2400000,0X24FFE00] ,Len: 100000
    MMCBLK0P11 (WRUNTIMENV1) Range: [0X2500000,0X25FFE00] ,Len: 100000
    MMCBLK0P12 (WRUNTIMENV2) Range: [0X2600000,0X26FFE00] ,Len: 100000
    MMCBLK0P13 (TDRUNTIMENV1) Range: [0X2700000,0X27FFE00] ,Len: 100000
    MMCBLK0P14 (TDRUNTIMENV2) Range: [0X2800000,0X28FFE00] ,Len: 100000
    MMCBLK0P15 (PARAM) Range: [0X2900000,0X2AFFE00] ,Len: 200000
    MMCBLK0P16 (EFS) Range: [0X2B00000,0X3EFFE00] ,Len: 1400000
    MMCBLK0P17 (PRODNV) Range: [0X3F00000,0X43FFE00] ,Len: 500000
    MMCBLK0P18 (RESERVED2) Range: [0X4400000,0X44FFE00] ,Len: 100000
    MMCBLK0P19 (KERNEL) Range: [0X4500000,0X54FFE00] ,Len: 1000000
    MMCBLK0P20 (RECOVERY) Range: [0X5500000,0X64FFE00] ,Len: 1000000
    MMCBLK0P21 (CSC) Range: [0X6500000,0X12CFFE00] ,Len: C800000
    MMCBLK0P22 (SYSTEM) Range: [0X12D00000,0X53CFFE00] ,Len: 41000000
    MMCBLK0P23 (HIDDEN) Range: [0X53D00000,0X564FFE00] ,Len: 2800000
    MMCBLK0P24 (USERDATA) Range: [0X56500000,0XE8FFFE00] ,Len: 92B00000
    Done...Presets has been updated...
    Done.
    log đẹp .k thể chết emmc dc.
    xem log phần dưới luôn kìa(Backup saved: M MOR _ 576_20170401_1657.extcsd
    Done.)
    EMMC CID : 65646F4D204D4F521281000002400152
    EMMC CSD : D07FFF320F59007FF6DB80001E40001C
    EMMC Manufacturer ID: 0065 , OEM ID: 646F
    EMMC Date: 00/2014 Rev.0x81
    EMMC NAME: M MOR , S/N: 576
    EMMC NAME (HEX): 4D204D4F522000
    EMMC ROM1 (Main User Data) Capacity: 128 MB
    EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
    EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
    EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
    Extended CSD rev 1.5 (MMC 4.41)
    Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area)
    Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78.
    Partitioning Support [PARTITIONING_SUPPORT]: 0x03
    Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
    Done.
    Running:eMMC: Factory Format...
    Z3X EasyJtag Software ver. 2.5.0.8
    Skip loading eMMC Addon Firmware
    CMD Pullup Level:1732 mV
    CMD Active Level:1804 mV
    Box IO Level:1800 mV
    CLK Rate:14000 khz
    Formatting eMMC card, please wait up to 3 min...
    Setting Service Mode FAILED....
    eMMC Format Failed.
    Done.
    lyvant@yahoo.com.vn 0934030540
  2. ( TÍNH-NGHI_MOBILE ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoangtrung02 (15-04-2017)
