Kết quả 11 tới 11 của 11
    Aug 2007
    Trích Được post bởi uyenha_1 Xem bài viết
    MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C08593E1
    Using device: HTI, FW ver: 00.50, SN: 0100BCDF
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
    FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00AC9C25A3BDA66
    ASIC type: 11
    UEM Imei: 35687302098642
    Flash Imei: 35687302098642
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35687302098642_BA CK.rpl"
    Processing MCU file: rh99_05.910
    [DCT4,DCT4 ALGORITHM] size: 2.27 MB
    Supported Ids: 2292
    UEM ID: 00AC9C25:2984DA60
    Area [01000000-0100FFFF] erased in 0.437 s
    Area [01010000-013AFFFF] erased in 23.406 s
    Area [013B0000-013EFFFF] erased in 1.594 s
    Area [017C0000-017EFFFF] erased in 0.031 s
    Area [01FC0000-01FEFFFF] erased in 0.032 s
    Flash programming ...
    Programming completed in 12.516 s
    File processed in 49.922 s
    Processing CNT file: rh990_nai5.91mr
    [DCT4,DCT4 ALGORITHM] size: 110.59 KB
    Supported Ids: 2292
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Area [01380000-013AFFFF] erased in 1.250 s
    Programming completed in 0.625 s
    Extracting Content Pack, File Server fake reply for CUI phone.
    Content Pack extracted successfully in 0.141 s
    File processed in 21.281 s
    Processing PPM file: rh99_05.91mr
    [DCT4,DCT4 ALGORITHM] size: 1.13 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 0.422 s
    Area [01250000-0137FFFF] erased in 7.656 s
    Programming completed in 6.265 s
    File processed in 22.187 s
    Total time for flashing process(boot+erase+write) was 1 min 33.406 s
    Phone type: RH-99
    SW version: V 5.91 27-03-09 RH-99 (c) NMP
    Imei plain: 35687302098642-8
    Cellular system: GSM
    ASIC ID: 0x2293, type: 0
    Ppm Id: MR
    Language Pack:
    - not available.
    Master code: 2710471461
    Failed to read SP data
    che chân vpp của pinout chạy lại thử nhé không dược đành thay upp thui.
  1. Trả lời: 3
  2. 1200 liệt phím
    By thaimobile_81 in forum DCT4 - WD2
    Bài viết cuối: 26-12-2010, 12:08
  3. 1200
    By nguyentruong_tho44 in forum DCT4 - WD2
    Bài viết cuối: 08-06-2009, 21:58
  4. ghi rpl 1200
    By hieuchetlien in forum DCT4 - WD2
    Bài viết cuối: 12-12-2008, 09:30
