Kết quả 1 tới 10 của 12
    Thành viên mới maihuong_2010's Avatar
    Oct 2009
    Mặc định 6030 chết nguồn
    Xin chào các anh. Em có cái 6030 chết nguồn, lúc đầu có nguồn nhưng em thay ic chuông thì chết luôn, bỏ vào hộp check ok, info và chạy cũng ok. Nhưng nó ko lên nguồn, chỉ nhích 1 tý rồi tụt kim về 0. Các anh xem có cách gì giúp em vớiFILES SET FOR FLASHING:
    MCU Flash file: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.400
    PPM Flash file: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.40v
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    CNT Flash file: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.40.image_v
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\357594007219182_imei_back up_212276.rpl
    Done!
    Backup imei OK!
    MCU: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.400
    Booting phone...
    MCU ID: 0x2031
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    Flash ID is 0x7E2C0100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 10
    Loader is ready...
    MSID: 8429953FBD7124DEAC5797C52A
    MSID decoded: 8BA1BAE9009D0A09A8000000
    FAID: A1D697F55B788429B67254AC
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01000000 - 0101FFFF...
    Erasing area: 01020000 - 017BFFFF...
    Erasing area: 01F20000 - 01FDFFFF...
    Operation took 0 minutes 48 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 26 seconds...
    Restarting MCU...
    CNT: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.40.image_v
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 842654643B2980FB0D95EF3E30
    MSID decoded: 1C15BAE3009D0A09AD0005BD
    FAID: 8BE3AFB141735C98B069D898
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01C00000 - 01F1FFFF...
    Operation took 0 minutes 19 seconds...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Operation took 0 minutes 0 seconds...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract Skiped.
    PPM: C:\Documents and Settings\admin\My Documents\6030_RM_74_V_05[1].40\6030_RM_74_V_05.40\rm74__5.40v
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x7518; Loader chk: f0
    Loader is ready...
    MSID: 842C0AEDB4D695CFC49CFCB44E
    MSID decoded: 3E4EBAE9009D0A09A8000000
    FAID: 6CFDC1ED7DD3994BBA2FF647
    Operation took 0 minutes 6 seconds...
    Erasing PPM...
    Erasing area: 017C0000 - 01BFFFFF...
    Operation took 0 minutes 23 seconds...
    Writing...
    Operation took 0 minutes 24 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 54 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-74, Software version: 5.40
    IMEI: 357594007219182
    Product Code: 0525021
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Operation took 0 minutes 4 seconds...
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: 2
    SW version: 5.40
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 34
    Done!
    Thanks
    Thành viên tích cực binhdtdd's Avatar
    Sep 2008
    máy của bạn bình thường mà
    0933.379.527
    Thành viên tích cực BUIVANCHUNG's Avatar
    Kim Anh Mobile Đồng Nai
    kiểm tra áp nút nguồn xem sao??nhiều khi nó tăng trị số điện trở cũng không lên nguồn,remove ic chuông xem sao bạn
  4. ( BUIVANCHUNG ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    maihuong_2010 (06-01-2010)
    Thành viên mới hieudtdd847's Avatar
    ban xem thu co d ap o nut n ko
  6. ( hieudtdd847 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  7. #5
    Sep 2008
    kiểm tra đường bsi đi bạn
    0933.379.527
  8. ( binhdtdd ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Thành viên tích cực Tuanbinhduong's Avatar
    kẹp dòng máy báo thế nào bạn, thử có bị đức nút nguồn không .
    Mua sim Vina 0918 01 1981 có con nào 09xx.180181 mà giá fixx nhiều tý càng ok AE nào có thì buzz mình cái nhe:0918 085 685 hoặc Tuan_Nguyen812001@yahoo.com
  10. ( Tuanbinhduong ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    remove con trở đường bsi cho nó thử đi anh
  12. ( VŨ PRO ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #8
    Oct 2009
    Em đã kiểm tra BSI, tháo con trở kép BSI rồi, nhưng vẫn ko được Khổ thân em quá, giờ biết nói làm sao với khách bây giờ, Các anh có cách nào giúp em với
  14. #9
    Thành viên tích cực minhnhut777's Avatar
    Feb 2008
    bạn tháo ic chuông ra chưa
  15. #10
    Oct 2009
    Em tháo rồi các anh ạ, chưa đc. Xin nhờ các anh
  1. 6030 chết nguồn
    By ntoan92 in forum DCT4 - WD2
    Bài viết cuối: 07-04-2014, 05:52
  2. nguồn và flash 6030 chạy chung với?
    By hungtrung in forum DCT4 - WD2
    Bài viết cuối: 27-06-2009, 10:38
  3. 6030 chết nguồn
    By lovemobile868 in forum BB5
    Trả lời: 13
    Bài viết cuối: 27-06-2009, 10:00
  4. 6030 chết nguồn
    By lovemobile868 in forum DCT4 - WD2
    Trả lời: 11
    Bài viết cuối: 27-06-2009, 01:05
  5. 6030 bị chạm mất nguồn.
    By duylam in forum DCT4 - WD2
    Bài viết cuối: 20-08-2008, 11:11
