Trang 10 của 19 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 CuốiCuối
Kết quả 91 tới 100 của 186
    Jan 2007
    [/URL]
    Octoplus/Octopus Box LG v.2.0.4 is out!
    Added world's first support for AS323, LS751 and additional support for the wide range of LG mobile phones!
    Octoplus/Octopus Box LG Software v.2.0.4 Release Notes:[INDENT]������ Added support for the following models:
    - AS323 - added world's first Direct Unlock, Repair IMEI, Read/Write NVM, Read Security, Write Security backup, Read/Write QCN, Repair BT Address, Repair Wi-Fi,
    - AS323 - Write Firmware (in Test Mode), Read Full Flash (Dump NAND), Reset Screen Lock (thanks to Mr. Ariel Sellanes).
    - LS751 - added world's first Repair MEID, Repair AKEY / SSD_A / SSD_B / OTKSL / SPC, Read/Write/Repair NVM, Read/Repair Security, Write Security backup,
    - LS751 - Read/Write QCN, Read/Write PRL, Repair BT Address, Repair Wi-Fi, Write Firmware (in Test Mode), Read Full Flash (Dump NAND).
    - D625 - added Direct Unlock (without root, Test Mode), Repair IMEI (without root), Read Full Flash, Reset Screen Lock.
    - D410 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D410H - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D410HN - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D618 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D724 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D728 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D729 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D856 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D857 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D858 - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D858HK - added Direct Unlock and Repair IMEI (A/B) without Root.
    - D859 - added Direct Unlock and Repair IMEI (A/B) without Root.
    Added Write Firmware (now is possible to convert for flashing KDZ, DZ and TOT files) for the listed below devices:
    - H815, H815AR, H815K, H815L, H815P, H815T, H815TR,
    - H630, H630D, H630I,
    - H634,
    - H635, H635A, H635AR, H635C,
    - H636. [B]
    All supported operations are described in details in the manual ("Cable & Manual" button in Software)
    Download Octoplus/Octopus Box LG v.2.0.4
    Find out more at: www.octoplusbox.com
  2. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TuệNguyễn (22-08-2015)
    Jan 2007
    Octoplus/Octopus Box LG v.2.0.5 - another world's 1st update! [HR][/HR]
    Octoplus/Octopus Box LG v.2.0.5 is out!
    Added world's first support for G4s Dual, G4 Beat LTE, LG G4s and Wine Smart phones - without root, fast and effective! Boom-boom! The summer has ended, but our updates has not! Stay tuned for more!
    Octoplus/Octopus Box LG Software v.2.0.5 Release Notes:
    • Added support for the following models:
    H540 - added world's first Direct Unlock, Read codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read info
    H540F - added world's first Direct Unlock, Read codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read info
    H540T - added world's first Direct Unlock, Read codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read info
    H734 - added world's first Direct Unlock (without root), Repair IMEI (A/B) (without root), Read/Write/Repair NVM, Read/Repair Security,
    Write Security backup, Read/Write QCN, Repair BT Address, Repair Wi-Fi, Write Firmware, Read Full Flash (Dump NAND), Reset Screen Lock
    H735 - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    H735AR - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    ������ H735L - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    H735MT - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    H735P - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    H735T - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    H735TR - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    ������ H736 - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write NVM, Read Security,
    ������ H736P - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write NVM, Read Security,
    ������ D486 - added world's first Direct Unlock (without root), Repair IMEI (without root), Read/Write/Repair NVM, Read/Repair Security,
    • All supported operations are described in details in the manual ("Cable & Manual" button in Software)
    Download Octoplus/Octopus Box LG v.2.0.5
    Jan 2007
    Octoplus/Octopus Box LG v.2.0.6 - another world's 1st update! [HR][/HR]
    Octoplus/Octopus Box LG v.2.0.6 is out!
    Added world's first support for LG G4 series, LG Band Play LTE and more!
    Octoplus/Octopus Box LG Software v.2.0.6 Release Notes:
    - H815 - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815AR - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815K - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815L - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815P - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815T - added Direct Unlock, Repair IMEI (no need to root the device)
    - H815TR - added Direct Unlock, Repair IMEI (no need to root the device)
    - H818 - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock (no need to root the device)
    - H818N - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    - H818P - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    - F570S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write/Repair NVM,
    - F500K - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock (no need to root the device)
    - F500L - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    - F500S - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
    New QCN files were uploaded into the Support Area
    Download Octoplus/Octopus Box LG v.2.0.6
    Jan 2007
    Octoplus/Octopus Box LG v.2.0.7 - LG Flex2 and Magna series support!
    Octoplus/Octopus Box LG v.2.0.7 is out!
    Octopus Team keeps their hard work to provide you with regular free, hot, world's first releases!
    In this update we are proud to announce support for LG Flex2 and LG Magna series!
    We have no rest! We keep on rockin'!
    [YOUTUBEHD]7l_6x1MGsAs[/YOUTUBEHD]
    Octoplus/Octopus Box LG Software v.2.0.7 Release Notes:
    [B Added support for the following models:[/B]
    - H520 - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H520F - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H520G - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H520Y - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H522 - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H522F - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H522Y - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - F510K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
    - F510L - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
    - F510S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
    All supported operations described in details in the manual ("Cable & Manual" button in Software)
    [YOUTUBEHD]MHwqEkChZoo[/YOUTUBEHD]
    Download Octoplus/Octopus Box LG v.2.0.7
    Jan 2007
    Octoplus/Octopus Box LG v2.0.8 world's first support for LG H340G, H810 and more!
    Octoplus/Octopus Box LG v.2.0.8 is out!
    It's Friday again and time for new world's first releases has come!
    This update features world's first support for LG H340G, H810 and more!
    Octoplus/Octopus Box LG Software v.2.0.8 Release Notes:
    - H340G - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash, Reset Screen Lock, Root Device
    - H810 - added world's first Direct Unlock (in Test Mode), Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash, Reset Screen Lock (thanks to Mr. Hector Bermudez)
    - F430K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Write Firmware, Read/Write/Repair NVM, Read/Write QCN, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
    - F430L - added world's first first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Write Firmware, Read/Write/Repair NVM, Read/Write QCN, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock (thanks to Mr. Xtreme Mobiles)
    - F430S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Write Firmware, Read/Write/Repair NVM, Read/Write QCN, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
    - D625 - added Read/Write EEPROM, improved Repair IMEI (without root) and Unlock (without root) operations
    • All supported operations described in details in the manual ("Cable & Manual" button in Software)
    A big thanks to all our customers who were actively involved in improving of the Software, sent reports, logs and dumps to us.
    Download Octoplus/Octopus Box LG v.2.0.8
    Jan 2007
    Octoplus/Octopus Box LG v.2.0.9 - LG H950, H819, G350 and more! [HR][/HR]
    Octoplus/Octopus Box LG v.2.0.9 is out!
    Cheer up! Another Octoplus world's first update is here! This release features world's first support for LG H950, H819, G350 and more!
    Still not excited? Stay tuned for more! Octoplus - always ready to serve.
    Octoplus/Octopus Box LG Software v.2.0.9 Release Notes:
    - H950 - added world's first Direct Unlock (no need root), Repair IMEI (no need root), Repair BT Address, Repair Wi-Fi Address, Read/Write NVM,
    - H950PR - added world's first Direct Unlock (no need root), Repair IMEI (no need root), Repair BT Address, Repair Wi-Fi Address, Read/Write NVM,
    - H819 - added world's first Direct Unlock (no need root, in Test Mode), Repair IMEI (no need root, in Test Mode), Repair BT Address, Repair Wi-Fi Address,
    - G350 - added world's first Direct Unlock, Repair IMEI, Read Codes, Read/Write/Repair EPPROM, Read/Write Full Flash, Repair Wi-Fi Address, Repair BT Address, Read Info
    - G360 - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Read/Write/Repair EPPROM, Read/Write Full Flash, Repair BT Address, Read Info
    Download Octoplus/Octopus Box LG v.2.0.9
  8. #7
    Jan 2007
    Octoplus/Octopus Box LG v.2.1.0 - added LG H812, F560K, H542 and more!
    Octoplus/Octopus Box LG v.2.1.0 is out!
    Bang bang bang! All-world's-first update is here! Forget about the rest, cause we are the best!
    This update features world's first support for LG H812, H635CX, F560K, H542 and more!
    Octoplus/Octopus Box LG Software v.2.1.0 Release Notes:
    - H812 - added world's first Direct Unlock (in Test Mode), Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM,
    Read/Write QCN, Read/Repair Security, Write Security Backup, Read Full Flash (dump NAND), Reset Screen Lock
    - H635CX - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM,
    Read/Write QCN, Read/Repair Security, Write Security Backup, Read Full Flash, Write Firmware, Reset Screen Lock
    - F560K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM,
    Read/Write QCN, Read Security, Write Security Backup, Read Full Flash, Write Firmware, Reset Screen Lock
    - D855V - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM,
    Read/Write QCN, Read/Reset Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Factory Reset, Reset Screen Lock
    - H542 - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    - H542TR - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
    [B Improved Reset Screen Lock Operation (added removal of FRP (Factory Reset Protection) Lock)[/B]
    Improved Write Firmware operation (added automatic removal of FRP (Factory Reset Protection) Lock after writing of a firmware)
    Download Octoplus/Octopus Box LG v.2.1.0
  9. #8
    Jan 2007
    Octoplus/Octopus Box LG v.2.1.1 - another world's first update!
    Octoplus/Octopus Box LG v.2.1.1 is out!
    Today we are happy to announce another world's first update, featuring LG LS991 and LS996 phones support! We all strive to push forward your unlocking business by providing constant, top quality, weekly updates!
    As usual, no annual payments, no additional fees.. Octoplus - always ready to serve!
    Octoplus/Octopus Box LG Software v.2.1.1 Release Notes:
    - LS991 - added world's first Direct Unlock (tested on ZV5 firmware), Repair IMEI,
    Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Repair 3G/4G, Read/Write QCN, Repair MEID, Repair AKEY / SSD_A / SSD_B / OTKSL / SPC,
    Repair MCC / MNC / MIN1 / MIN2 / Home SID / Home NID / Mobile Number, Read / Write PRL, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - LS996 - added world's first Direct Unlock (tested on ZV4 firmware), Repair IMEI,
    - F540K - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - F540L - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - F540S - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - H811 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H631 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - MS631 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H345 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - MS345 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H810 - added Write Firmware
    - H812 - added Write Firmware
    Download Octoplus/Octopus Box LG v.2.1.1
  10. #9
    Jan 2007
    Octoplus/Octopus Box LG v.2.1.2 - as usual, another world's first update! 🐙 [HR][/HR]
    Octoplus/Octopus Box LG v.2.1.2 is out!
    We have added world's first support for LG H342, LG H343 and support for other models!
    Octoplus/Octopus Box LG Software v.2.1.2 Release Notes:
    🐙 Added support for the following models:
    - H342 - added world's first Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    Read / Write QCN, Read / Reset Security, Write Security Backup, Write Firmware, Read Full Flash (Dump NAND), Reset Screen / FRP Lock
    - H342F - added world's first Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - H342FT - added world's first Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - H342I - added world's first Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - H343 - added world's first Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - H818PA - added Direct Unlock, Repair IMEI (A / B), Repair BT Address, Repair Wi-Fi Address, Read / Write / Repair NVM,
    Read / Write QCN, Read / Repair Security, Write Security Backup, Write Firmware, Read Full Flash (Dump NAND), Reset Screen / FRP Lock
    - V495 - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read / Write NVM, Read / Write QCN, Read Security,
    Write Security Backup, Write Firmware, Read Full Flash (Dump NAND), Reset Screen Lock
    - V496 - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read / Write NVM, Read / Write QCN, Read Security,
    - H340 - added Reset Security
    - H340AR - added Reset Security
    - H340F - added Reset Security
    - H340G - added Reset Security
    - H340H - added Reset Security
    - H340N - added Reset Security
    - H340Y - added Reset Security
    🐙 Added Write Firmware operation for the following models:
    - D950, D950G, D950P, D950W
    - D951, D955, D956, D957, D958
    - D959, D959BK, D959TS
    - F340K, F340L, F340S
    - LS995
    🐙 New QCN files were uploaded into the Support Area
    🐙 All supported operations described in details in the manual ("Cable & Manual" button in Software)
    Download Octoplus/Octopus Box LG v.2.1.2
  11. #10
    Jan 2007
    Octoplus/Octopus Box LG v.2.1.3 - another world's first update!
    Octoplus/Octopus Box LG v.2.1.3 is out!
    What's up, guys? Today we are proud to announce LG Spirit and Escape 2 world's first support! Also in this release we present a new, root-less unlock algo for Sprint phones!
    Octoplus/Octopus Box LG Software v.2.1.3 Release Notes:
    - H442 - added world's first Direct Unlock (no need Root), Repair IMEI (A / B) (no need Root), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - H442F - added world's first Direct Unlock (no need Root), Repair IMEI (A / B) (no need Root), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    Read / Write QCN, Read / Reset Security, Write Security Backup, Write Firmware, Read Full Flash, Reset Screen / FRP Lock
    - H445 - added world's first Direct Unlock (in Test Mode, no need Root), Repair IMEI (no need Root), Repair BT Address, Repair Wi-Fi Address, Read / Write NVM,
    - V497 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read / Write NVM, Read / Write QCN, Read Security, Write Security Backup,
    - LS751 - added world's first Direct Unlock (no need Root)
    Released new Unlock algorithm, which does not require Root for LG Sprint phones:
    - LS980
    - LS990
    - LS991
    - LS995
    - LS996
    Added Reset Security for the following models:
    - H440
    - H440AR
    - H440F
    - H440N
    - H440V
    - H440Y
    - H443
    [INDENT]All supported operations described in details in the manual ("Cable & Manual" button in Software)
    [INDENT][INDENT][INDENT]
    Download Octoplus/Octopus Box LG v.2.1.3
Hiện có 11 người đang xem bài này . Bao gồm : 0 thành viên và 11 khách
  1. Octoplus Box Samsung new update!
    By ThanhHaMobile™ in forum Octopus/Octoplus Box
    Trả lời: 193
    Bài viết cuối: 23-10-2025, 10:41
  2. Octoplus/Octopus Suite new update!
    Trả lời: 52
    Bài viết cuối: 11-10-2018, 23:44
  3. Octoplus/Octopus Box Samsung v1.3.6 - starring Galaxy Tab 3 7.0!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-10-2013, 10:08
  4. Octoplus/Octopus Box LG v1.2.2 - LG E981H, and much more...
    By thanhtunggialai™ in forum Octopus/Octoplus Box
    Bài viết cuối: 02-08-2013, 22:21
  5. Octoplus/Octopus Shell Software update!
    Bài viết cuối: 02-07-2013, 16:58
