Trang 6 của 19 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... CuốiCuối
Kết quả 51 tới 60 của 186
    Jan 2007
    Octoplus/Octopus Box LG v1.6.4 - LG C397, C399 world's 1st support!
    Octoplus/Octopus Box LG v1.6.4 is out!
    Added world's first support for C399 and C397 and more!
    Octoplus/Octopus Box LG Software v1.6.4 Release Notes
    Added support for the following models:
    - C399 - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B/C), Read/Write/Repair EEPROM, Repair BT Address, Repair Wi-Fi MAC Adress, Read/Write Full Flash, Read Phone Info.
    - C397 - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Read/Write EEPROM, Repair BT Address, Repair Wi-Fi MAC Adress, Read/Write Full Flash, Read Phone Info (all operations in Test Mode).
    - P655H, P655K - improved Read NVM operation.
    Added support for KDZ files (now is possible to convert flashing DZ and KDZ files) for:
    - Optimus L3:
    - E400, E400b, E400F, E400g, E400GO, E400r
    - E405, E405F
    - Optimus L5:
    - E610, E610GO, E610V
    - E612, E612F, E612G
    - E615, E615f
    - E617G
    - Optimus L7:
    - P700
    - P705, P705F, P705G, P705GO
    - P708G
    All supported operations are described in details in Software manual ("Cable & Manual" button in Software).
    ! Please Note: Support for C397 is added in Test Mode only - before perfoming the Unlock or Repair IMEI operations, don't forget to create a backup of EEPROM. Also, is won't be superfluous to read Full flash.
    Download Octoplus/Octopus Box LG v1.6.4
    Nov 2010
    Octoplus/Octopus Box LG Software v1.6.5 Release Notes
    • Added support for the following models:
    - D852G - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair/Reset Security, Write Security Backup, Root/Unroot Device, Read Full Flash (Dump NAND).
    - D850, D850PR - added Reset Security, improved Unlock and Repair IMEI operations (improved flash initializing process).
    - D851, D851TN, D851WH - added Reset Security, improved Unlock and Repair IMEI operations (improved flash initializing process).
    - D852 - added Reset Security, improved Unlock and Repair IMEI operations (improved flash initializing process).
    - D855, D855AR, D855K, D855P, D855P, D855TR - added Reset Security, improved Unlock and Repair IMEI operations (improved flash initializing process).
    - P710 - added Read Security.
    - P712 - added Read Security.
    - P713, P713GO, P713TR - added Read Security.
    - P714 - added Read Security.
    - P715 - added Read Security.
    - P716 - added Read Security.
    • Improved Write Firmware and Write Full Flash operations (released bypassing "bad" blocks on phone's flash chip) for the next devices:
    - A390
    - A395
    - A399
    - C297
    - C299
    - C397
    - C399
    • All supported operations are described in details in Software manual ("Cable & Manual" button in Software).
    More info and discussion are HERE
    Jan 2007
    Octoplus/Octopus Box LG v1.6.6 - LG D315, D370 world's 1st support!
    Octoplus/Octopus Box LG v1.6.6 is out!
    Added world's first support for LG D315, D370, D373 and many more!
    Octoplus/Octopus Box LG Software v1.6.6 Release Notes
    - D315 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root Device, Unroot Device, Read Full Flash (Dump NAND).
    - D315K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root Device, Unroot Device, Read Full Flash (Dump NAND).
    - D315S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root Device, Unroot Device, Read Full Flash (Dump NAND).
    - D315H - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root Device, Unroot Device, Read Full Flash (Dump NAND) (all operations in Test Mode).
    - D315I - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root Device, Unroot Device, Read Full Flash (Dump NAND) (all operations in Test Mode).
    - D370 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D370TR - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D373 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D373EU - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - E475F - added Repair IMEI C, Repair Security, Repair NVM, support for KDZ files (thanks to Mr. Brunobbtj).
    Added support for KDZ files (now is possible to convert to flashing TOT and KDZ files) for:
    - Optimus L1 II:
    - E410, E410b, E410c, E410g, E410f, E410i
    - E411f, E411g
    - E415, E415f, E415g
    - E420, E420F
    - Optimus L3 II:
    - E425, E425C, E425F, E425G, E425J
    - E430, E430GO
    - E431G
    - E435, E435F, E435G, E435K
    - Optimus L7 II:
    - P710
    - P712
    - P714
    - P715
    - P716
    Download Octoplus/Octopus Box LG v1.6.6
    Find out more at: Octoplus Box - flashing, software repair and unlocking of LG, Samsung, Sony Ericsson and other devices
    Administrators ThanhHaMobile™'s Avatar
    Dec 2006
    Hoa Phượng Đỏ
    Chu y Octoplus/Octopus Box LG v1.6.7 - LG D165 world's 1st support!
    Octoplus/Octopus Box LG v1.6.7 is out!
    Added world's first support for LG D165, support for LG AS870 and many more!
    Octoplus/Octopus Box LG Software v1.6.7 Release Notes
    - D165 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D165AR - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D165F - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D165G - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND).
    - AS870 - added Direct Unlock, Repair IMEI, Read/Repair MEID / AKEY / SSD_A / SSD_B / OTKSL / SPC, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Write Firmware, Repair Bluetooth Adress, Read Full Flash, Reset Screen Lock (including Reset Pattern, Pin, Password and Google locks)(all operations in test mode).
    - L-02E - added Read Security.
    - L-05D - added Read Security.
    - P875, P875H - added Read Security.
    - MS870 - added Read Security.
    - VS870 - added Read Security.
    - VS930 - added Read Security.
    Nếu cần liên hệ, xin vui lòng ... liên hệ theo thông tin ở dưới đây!
    CUNG CẤP THIẾT BỊ CHẠY PHẦN MỀM CHÍNH HÃNG
    • Repair Boot - Unlock giải mã - mở mạng - mở mã pass người dùng - sửa lỗi phần mềm, nạp tiếng Việt, chuyển đổi ngôn ngữ cho các dòng máy Mobile • CUNG CẤP & TƯ VẤN SỬ DỤNG THIẾT BỊ CHẠY PHẦN MỀM MOBILE CHUYÊN DỤNG • CUNG CẤP SẢN PHẨM DUNG DỊCH PHÁ KEO IC, BÃO HÒA TẢN NHIỆT IC, KEO DẪN ĐIỆN, THIẾC BỘT, CHÌ XẢ MỐI HÀN, DAO PHÁ KEO • KEO DÁN MÀN HÌNH CẢM ỨNG iPHONE, iPAD, LAPTOP, GIA CỐ CPU CÁC LOẠI ...
    ThanhHaMobile™ Service Center
    Số: 411 Tô Hiệu (ngay ngã tư An Dương, đối diện siêu thị HONDA Hương Giang) - Hải Phòng.
    ĐT: Gphone 0225.609.239 - 0983.717.628 - 0912.050.858.
    • Tài khoản Anypay Viettel số: 0987 250 552
    • Tài khoản giao dịch: DongAbank - Chủ tài khoản: Nguyễn Đức Thanh
      Mã số TK: 0104365048 chi nhánh Lê Chân - Hải Phòng.
    • Tài khoản giao dịch: Agribank (NNPTNT) - Chủ tài khoản: Ngô Thị Thu Hà
      Mã số TK: 2112205015281 chi nhánh Lê Chân - Hải Phòng.
    • Tài khoản giao dịch: VietCombank - Chủ tài khoản: Ngô Thị Thu Hà
      Mã số TK: 0031001023873 chi nhánh Lê Chân - Hải Phòng.
    Nov 2010
    <b>
    Octoplus/Octopus Box LG v1.6.8 - another world*s 1st update!
    Octoplus/Octopus Box LG v1.6.8 is out!
    Added world*s first support for LG D830, D838 and many more!
    Octoplus/Octopus Box LG Software v1.6.8 Release Notes
    - D830 - added world*s first Direct Unlock, Repair IMEI, Read/Repair/Reset Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND).
    - D838 - added world*s first Direct Unlock, Repair IMEI, Read/Repair/Reset Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND) (thanks to Mr. Goguzhan).
    - F350K - added world*s first Direct Unlock, Repair IMEI, Read/Reset Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write NVM, Read Full Flash (Dump NAND) (all operations in Test Mode).
    - F350L - added world*s first Direct Unlock, Repair IMEI, Read/Reset Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write NVM, Read Full Flash (Dump NAND) (all operations in Test Mode).
    - F350S - added world*s first Direct Unlock, Repair IMEI, Read/Reset Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write NVM, Read Full Flash (Dump NAND) (all operations in Test Mode).
    • Improved Repair NVM operation for:
    - D500, D500BK, D500BKGO1
    - D505
    • Improved Unlock and Repair IMEI operations (error codes: ZXLCALSZXC, ZXLCALSZXD) for:
    - D850, D850PR
    - D852, D852G
    - D855, D855AR, D855K, D855P, D855TR
    Download Octoplus/Octopus Box LG v1.6.8
    Find out more at: www.octoplusbox.com
    </b>
    Jan 2007
    Octoplus LG v1.6.9 - world's first support for LG D620J and more!
    Octoplus/Octopus Box LG v1.6.9 is out!
    Added world's first support for LG D620J and support for D957, D959BK, C398!
    Octoplus/Octopus Box LG Software v1.6.9 Release Notes
    - D620J - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND).
    - D957 - added Direct Unlock, Repair IMEI, Read Security, Repair Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Root/Unroot Device.
    - D959BK - added Direct Unlock, Repair IMEI, Read Security, Repair Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Root/Unroot Device.
    - C398 - added Direct Unlock, Read Codes, Repair IMEI (A/B/С), Read/Write/Repair EEPROM, Repair BT Address, Repair Wi-Fi MAC Address, Read/Write Full Flash, Read Phone Info.
    Download Octoplus/Octopus Box LG v1.6.9
    Jan 2007
    Octoplus LG v1.7.0 released! One more World's First release!
    Octoplus/Octopus Box LG v1.7.0 is out!
    Added world's first support for LG D170, D175F, D180F, D285, D285F, D285G, D320AR, D325, D325F, D325F8, D325G8, D375, D375AR, D380, D385, D415RDGO and more!
    Octoplus/Octopus Box LG Software v1.7.0 Release Notes
    - D170 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D175F - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D180F - added world's first Repair IMEI, Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write NVM, Read Security, Write Security backup, Read Full Flash (Dump NAND).
    - D285 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D285F - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D285G - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D320AR - added world's first Repair IMEI, Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write NVM, Read Security, Write Security backup, Read Full Flash (Dump NAND).
    - D325 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D325F - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D325F8 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D325G8 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D375 - added world's first Repair IMEI, Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write NVM, Read Security, Write Security backup, Read Full Flash (Dump NAND).
    - D375AR - added world's first Repair IMEI, Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write NVM, Read Security, Write Security backup, Read Full Flash (Dump NAND).
    - D380 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D385 - added world's first Repair IMEI (A/B), Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D415RDGO - added world's first Repair IMEI, Direct Unlock, Repair BT Address, Repair Wi-Fi, Read/Write/Repair NVM, Read/Repair Security, Write Security backup, Read Full Flash (Dump NAND).
    - D400 - added Repair Security, Repair NVM.
    - D400H - added Repair Security, Repair NVM.
    - D400HN - added Repair Security, Repair NVM.
    - D400N - added Repair Security, Repair NVM.
    - D405 - added Repair Security, Repair NVM.
    - D405H - added Repair Security, Repair NVM.
    - D405N - added Repair Security, Repair NVM.
    - D405TR - added Repair Security, Repair NVM.
    Reminder! Unlimited Unlock and Repair IMEI of all supported Sony phones is FREE!!! for SE Unlimited Activation owners.
    Download Octoplus/Octopus Box LG v1.7.0
    Jan 2007
    Octoplus/Octopus Box LG v1.7.1 - world's 1st and exclusive update!
    Octoplus/Octopus Box LG v1.7.1 is out!
    Added world's first support for LG LS990, support for D800T and additional support for a wide range of supported devices!
    Octoplus/Octopus Box LG Software v1.7.1 Release Notes
    - LS990 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Repair 3G/4G, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup,
    - LS990 - Root/Unroot Device, Read Full Flash (Dump NAND), Read/Repair MEID / AKEY / SSD_A / SSD_B / OTKSL / SPC (thanks to Mr. Cemalefеndi).
    - D800T - added Direct Unlock, Repair IMEI, Read/Repair Security, Write Security Backup, Repair Wi-Fi MAC Address, Repair BT Address, Read/Write QCN, Read/Write/Repair NVM,
    - D800T - Root/Unroot Device, Reset Screen Lock (including Reset Password, Pin, Pattern, Face, Google locks).
    - D800 - added world's first Read/Write QCN, Reset Security.
    - D800P - added world's first Read/Write QCN, Reset Security.
    - D801, D801BK, D801WH, D801Z - added world's first Read/Write QCN, Reset Security.
    - D802, D802T, D802TA, D802TR - added world's first Read/Write QCN, Reset Security.
    - D803, D805, D806 - added world's first Read/Write QCN, Reset Security.
    - D820 - added world's first Read/Write QCN, improved Repair 3G/4G operation.
    - D820BK - added world's first Read/Write QCN, improved Repair 3G/4G operation.
    - D821 - added world's first Read/Write QCN, improved Repair 3G/4G operation.
    Also added world's first Read/Write QCN and improved Unlock and Repair IMEI operations for a great number of devices of the following series:
    - G3, G pro 2, G2, G Flex, G2 mini, L90, L80, L80 Dual, L70, L70 Dual, L65, L65 Dual, L40, L40 Dual, F70.
    Download Octoplus/Octopus Box LG v1.7.1
    Jan 2007
    [/URL]
    Octoplus/Octopus Box LG v1.7.2 is out!
    Added world's first support for LG D120, D120AR, D120F, D120G, D120J, D125, D125F, D125G, D127F, D150, D157, D157F, D290, D290G, D290N, D290TR, D295, D295F, D213K, support for D213, D213AR, D213C, D213CF, D213CJ, D213F, D213N, D213TR, D221, D221C, D225, D227, D228 and more!
    Octoplus/Octopus Box LG Software v1.7.2 Release Notes
    - D120 - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash (thanks to mr. hotgsm.net).
    - D120AR - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D120F - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D120G - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D120J - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D125 - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D125F - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D125G - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D127F - added world's first Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D150 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repai NVM, Read/Write QCN, Read Full Flash (dump NAND).
    - D157 - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN, Read Full Flash (dump NAND).
    - D157F - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN, Read Full Flash (dump NAND).
    - D290 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
    - D290G - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
    - D290N - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
    - D290TR - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security Backup, Read/Write NVM, Read/Write QCN,Read Full Flash (dump NAND).
    - D295 - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repair NVM, Read/Write QCN, Read Full Flash (dump NAND).
    - D295F - added world's first Direct Unlock, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security Backup, Read/Write/Repair NVM, Read/Write QCN, Read Full Flash (dump NAND).
    - D213K - added world's first Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repai EEPROM, Read info, Read Full Flash.
    - D213 - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213AR - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213C - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213CF - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213CJ - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213F - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213N - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D213TR - added Direct Unlock, Read Codes, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read info, Read Full Flash.
    - D221 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D221C - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D225 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D227 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    - D228 - added Direct Unlock, Read Codes, Repair IMEI (A/B), Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read info, Read Full Flash.
    • Also added world's first Read/Write QCN for the next devices:
    - MS500
    - D505
    - D605
    - P655H, P655K
    - P659, P659BK, P659BKGo, P659H
    - MS659
    - D520, D520BK
    - LS720, VM720
    [YOUTUBEHD]f6oSbOllF-k[/YOUTUBEHD]
    [YOUTUBEHD]s7aLx_QJDaw[/YOUTUBEHD]
    [YOUTUBEHD]cYRdEN5ldq0[/YOUTUBEHD]
    Download Octoplus/Octopus Box LG v1.7.2
    Jan 2007
    [/URL]
    Octoplus/Octopus Box LG v1.7.3 is out!
    Added world's first support for support for LG D631, VS985, F340K, F340L, F340S and more!
    Octoplus/Octopus Box LG Software v1.7.3 Release Notes
    - D631 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Repair Security, Write Security backup, Read/Write/Repair NVM, Read Full Flash (Dump NAND), Read/Write QCN (thanks to mr. tech_man).
    - VS985 - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Repair 3G/4G, Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Root/Unroot Device, Read Full Flash (Dump NAND), Read/Repair MEID / AKEY / SSD_A / SSD_B / OTKSL / SPC (thanks to Mr. Cemalefеndi).
    - F340K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security backup, Read/Write NVM, Read Full Flash, Read/Write QCN (all operations in Test Mode).
    - F340L - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security backup, Read/Write NVM, Read Full Flash, Read/Write QCN (all operations in Test Mode).
    - F340S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read Security, Write Security backup, Read/Write NVM, Read Full Flash, Read/Write QCN (all operations in Test Mode).
    - E960,
    - E970, E970P,
    - E971, E973,
    - E975, E975G, E975K, E975R, E975T, E975W,
    - E976, E977, E987,
    - L-01E,
    - L21,
    - F180K, F180S, F180L,
    - E980, E980H, E980P,
    - E981H,
    - E985, E985T,
    - E986, E988, E989,
    - F220K, F220L, F220S,
    - F310L,
    - F240K, F240L, F240S,
    - L-04E.
    [YOUTUBEHD]pD6TeFVinWQ[/YOUTUBEHD]
    Download Octoplus/Octopus Box LG v1.7.3
  1. Octoplus Box Samsung new update!
    By ThanhHaMobile™ in forum Octopus/Octoplus Box
    Trả lời: 194
    Bài viết cuối: 13-11-2025, 21:55
  2. Octoplus/Octopus Suite new update!
    Trả lời: 52
    Bài viết cuối: 11-10-2018, 23:44
  3. Octoplus/Octopus Box Samsung v1.3.6 - starring Galaxy Tab 3 7.0!
    By toilatoi142001 in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 05-10-2013, 10:08
  4. Octoplus/Octopus Box LG v1.2.2 - LG E981H, and much more...
    By thanhtunggialai™ in forum Octopus/Octoplus Box
    Bài viết cuối: 02-08-2013, 22:21
  5. Octoplus/Octopus Shell Software update!
    Bài viết cuối: 02-07-2013, 16:58
