Trang 3 của 14 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 ... CuốiCuối
Kết quả 21 tới 30 của 135
  1. #21
    Hỗ Trợ Kĩ Thuật HoangThong_hotrokythuat4's Avatar
    Jan 2009
    Octopus Box v. 1.4.3 is out! We have added support for KF390, KF390GO, KF390Q, KS365, GS500f and CF360GO!
    Octopus Box v. 1.4.3 Release Notes:
    * KF390, KF390GO, KF390Q – added Direct Unlock, Repair IMEI, Repair BT, Repair Security, Write Firmware, Read/Write/Repair NVM
    * KS365 – added Unlock (Direct and by reading codes), Write Firmware, Read/Write EEPROM, Repair IMEI
    * GS500f – added Unlock (by reading codes), Write Firmware, Read/Write EEPROM
    * CF360GO – added Direct Unlock, Write Firmware, Read/Wite GDFS
  2. #22
    Jan 2009
    Octopus Version 1.4.4 – Added world's first support for LG L04B and LG GT370!
    Octopus Box v. 1.4.4 is out! We have added support for LG L04B and LG GT370!
    Octopus Box v 1.4.4 Release Notes:
    * L04B – added world first Direct Unlock, Repair Security, Write/Repair NVM
    * GT370 – added world first Unlock (by reading codes), Write Firmware, Read/Write EEPROM
  3. #23
    Jan 2009
    Octopus Box v. 1.4.5 is out! We have added world first support for GX300 and SH150!
    Octopus Box v. 1.4.5 Release Notes:
    * GX300 – added world first Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash
    * SH150 – added world first Unlock (for SW210713 firmware versions), Write Firmware, Read/Write/Repair NVM
  4. #24
    Jan 2009
    Octopus Box v 1.4.6 is out! We have added support for GX200 and world's first support for SH150A and KH1400!
    Octopus Box v 1.4.6 Release Notes
    * SH150A – added world's first Unlock (SW15A709 version), Write Firmware, Read/Write/Repair NVM
    * KH1400 – added world's first Unlock (KW140710 and KW140714 versions), Write Firmware, Read/Write/Repair NVM
    * GX200 – added Unlock (Direct and by Read codes), Write Firmware, Format filesystem, Repair IMEI, Read EEPROM/Full flash
  5. #25
    Jan 2009
    Octopus Box v. 1.4.7 is out! We have added world's first support for KH1000 and KH3100!
    Octopus Box v. 1.4.7 Release Notes:
    * KH1000 – added world's first Unlock (KW100616 version), Write Firmware, Read/Write/Repair NVM
    * KH3100 – added world's first Unlock (KW310908 and KW310909 versions), Write Firmware, Read/Write/Repair NVM
    * Added Multi-skin support
    * Changed buttons icons
    * Improved unlock procedure for GS100, GS101, GS101a, GS101GO, GS102, GS105, GS105GO, GS106, GS106a, GS107, GS107a, GS107b and GS108
    * Improved connection procedure for KG190 and KG195
  6. #26
    Jan 2009
    Octopus Box v. 1.4.8 is out! We have added support for KF750GO, KF755c, KF755d, CF360GO1, GU230GO, KP109a, and world's first support for SH410, SH400 and LV7400!
    Octopus Box v. 1.4.8 Release Notes:
    * SH410 – added world's first Unlock (SW410803 and SW410807 versions), Write Firmware, Read/Write/Repair NVM
    * SH400 – added world's first Unlock (SW400809 and SW400810 versions), Write Firmware, Read/Write/Repair NVM
    * LV7400 – added world's first Write Firmware, Read/Write/Repair NVM
    * KF750GO, KF755c, KF755d – added Unlock, Write firmware, Read/Write GDFS, Repair BlueTooth address
    * CF360GO1 – added Unlock, Write firmware, Read/Write GDFS
    * GU230GO – added Unlock via USB/UART, Write firmware via USB/UART, Repair IMEI, Read/Write EEPROM via USB/UART, Read/Write Full flash via USB/UART
    * KP109a – added Unlock (Direct and by Reading codes), Write Firmware, Read/Write EEPROM, Repair IMEI
    * Released Read codes support for GW620, GW620F, GW620R, GW620G and GW620GO
    * Released support in LG A2 language editor for the following models:
    o KF750GO, KF755c, KF755d – Read LP from phone/Write LP to phone/Translate LP
    * Added new skins - "Fallout style" and "Wood"
  7. #27
    Jan 2009
    Octopus Box v 1.4.9 is out! We have added support for KP330, TU330, KG810, MG810c, MG810d, KP109b, GM360, GM360GO, GM360i, and world's first support for KH8200!
    Octopus Box v 1.4.9 Release Notes
    * KH8200 – added world's first Unlock (KW820905 and KW820907 versions), Write Firmware, Read/Write/Repair NVM
    * KP330, TU330 – added Direct Unlock, Write firmware, Repair IMEI, Repair BlueTooth address, Read/Write/Repair NVM
    * KG810, MG810c, MG810d – added Unlock (direct and by reading codes), Write Firmware, Read/Write Full Flash, Read/Write EEPROM, Repair IMEI
    * KP109b – added Unlock (direct and by reading codes), Write Firmware, Read/Write EEPROM, Repair IMEI
    * GM360, GM360GO, GM360i – added Unlock (by reading codes), Write Firmware, Read/Write EEPROM
    * Improved unlock procedure for KH2100 (added direct unlock for KW210720 version)
    * Added new skins - "HeroesStyle" and "Terminal4bit"
  8. #28
    Jan 2009
    V. 1.5.0 – world's first support for KH3900, KH8000, KH8600, SH860, SU410 and more!
    Congratulations on the 50th update of Octopus Box.
    In this update we have added support for U960 and world's first support for KH3900, KH8000, KH8600, SH860, and SU410!
    We are working hard to keep Octopus Box one of the most updated and therefore one of the most trusted solution for servicing LG phones on the market.
    Proud owners of Octopus Box have already experienced its fast and in most cases world first updates.
    We also encourage you to try Octopus Box in action with LG BL40, GW620 phones ABSOLUTELY FREE of charge!
    That's our gift to GSM-Forum community. You can get it from official web.
    Octopus Box v 1.5.0 Release Notes:
    * KH3900 – added world's first Unlock (KW390007 version), Write Firmware, Read/Write/Repair NVM, Repair BT Address
    * KH8000 – added world's first Unlock (KW800913 version), Write Firmware, Read/Write/Repair NVM, Repair BT Adress
    * KH8600 – added world's first Unlock (KW860906 and KW860907 versions), Write Firmware, Read/Write/Repair NVM
    * SH860 – added world's first Unlock (SW860906 version), Write Firmware, Read/Write/Repair NVM
    * SU410 – added world's first Unlock (SU410905 version), Write Firmware, Read/Write/Repair NVM, Repair BT Address
    * Added support for U960 in LG Qualcomm language editor - Writing LP to phone/Translating LP
    * Added English-Thai dictionary for LG Qualcomm and LG A2 language editors (thanx to nongmobile)
    * Added Thai interface language (thanx to nongmobile)
    * Improved unlock procedure for SH150A (added direct unlock for KW210720 version)
    * Improved unlock and repair IMEI procedure for GM200 and GM205
    * Added new skins - "Golden" and "Nautilus"
    * Added free codereader for LG BL40, BL40e, BL40f, BL40g, GW620, GW620R, GW620F, GW620G, GW620GO
  9. #29
    Jan 2009
    Octopus Box v. 1.5.1 Release Notes:
    * GS505 – added world's first Unlock, Write Firmware, Repair IMEI, Repair BT Address, Repair Security, Read/Write/Repair NVM, Factory Reset;
    * GS505 – added world's first support in LG Qualcomm language editor: Read LP from Phone/Write LP to Phone/Translate.
    Note! For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of GS505 you need to write firmware "GS505-FOR-UNLOCK.oct" from the support area and click the corresponding button.
  10. #30
    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    Mặc định Version 1.5.2 – Added world's first support for GD570!
    Octopus Box v. 1.5.2 is out! We have added support for SH490, KU4000, MG161a, MG165a and world's first support for GD570!
    Octopus Box v. 1.5.2 Release Notes:
    • GD570 – added world's first Unlock, Write Firmware, Repair IMEI, Repair BT Address, Repair Security, Read/Write/Repair NVM, Factory Reset;
    • SH490, KU4000 – added Direct Unlock, Write Firmware, Read/Write/Repair NVM;
    • MG161a, MG165a – added Unlock (direct and by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash, Repair IMEI;
    • GD570 – added world's first support in LG Qualcomm language editor: Read LP from phone/Write LP to phone/Translate LP;
    • Added Writing firmware for U960;
    • Improved Unlock for KH2700 (added direct unlock for KW270806 firmware version).
    Note! For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of GD570 you need to write firmware "GD570-FOR-UNLOCK.oct" from the folder "FOR UNLOCK AND REPAIR" from the support area and click the corresponding button.
    Video manual:
    Download link:
    www.hungphongmobile.com
    www.giaimadienthoai.com
    <marquee ><font size=3 color=cyan><b> HungPhongMobile™ Service Center</b></font></marquee>
    <a href="ymsgr:sendIM?phongnhabr" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=phongnhabr&m=g&t=2&l=us border=0" border="0" /></a>
    <a href="ymsgr:sendIM?hp_unlockonline" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=hp_unlockonline&m=g&t=2&l=us border=0" border="0" /></a>
  11. ( hungphongmobile™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    HoangThong_hotrokythuat4 (11-10-2010)
  1. LG-F240S update 4.4.2 ok by octopus
    By taotaai in forum Octopus/Octoplus Box
    Bài viết cuối: 10-05-2014, 15:35
  2. octopus báo lỗi maximum update
    By yeuiphone2012 in forum Octopus/Octoplus Box
    Trả lời: 33
    Bài viết cuối: 10-06-2013, 22:10
  3. Octopus Box LG v2.1.2 new update!
    By ThanhHaMobile™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 26-05-2012, 01:10
  4. Octopus box update - ver. 1.0.7
    By HoangThong_hotrokythuat4 in forum Octopus/Octoplus Box
    Bài viết cuối: 15-01-2010, 08:11
  5. Octopus Box Software update - V1.0.2 is out!
    By TuấnPhát_GSM in forum Octopus/Octoplus Box
    Bài viết cuối: 09-12-2009, 17:16
