Trang 6 của 14 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 CuốiCuối
Kết quả 51 tới 60 của 135
  1. #51
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định Octopus Box v 1.7.6 - world's first support for LG KU4300 and LG SU430
    Octopus Box v 1.7.6 is out! We have added world's first support for LG KU4300 and LG SU430 and direct unlock for some versions of LG SH170, SH650!
    Octopus Box v 1.7.6 Release Notes
    * KU4300 – added world's first Unlock, SAFE write firmware, Repair BT, Read/Write/Repair NVM
    * SU430 – added world's first Direct unlock, SAFE write firmware, Repair BT, Read/Write/Repair NVM
    * Added SAFE flashing option for GT540
    * Added repair EEPROM for KF510
    * Added safe writing firmware procedure for KU9600 and SU960
    * Added direct unlock for SW170707 and SW170710 versions of SH170
    * Added direct unlock for SW650807 version of SH650
    * Added extended manuals for a wide range of models
    Download latest installer from official site here
    http://www.youtube.com/watch?v=eJaiA8-ZOHA
    _________________
    Grip it while it’s hot!
    BR,
    Octopus Team
  2. #52
    Hỗ Trợ Kĩ Thuật HoangThong_hotrokythuat4's Avatar
    Jan 2009
    Mặc định Octopus Box v 1.7.8 - this is not a joke!
    Octopus Box v 1.7.8 is out! We have added support for LG P350, LG P350GO, LG E720, LG E720b, LG A110!
    Octopus Box v 1.7.8 Release Notes
    * P350 – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read / Write / Repair NVM
    * P350GO – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read / Write / Repair NVM
    * E720 – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read / Write / Repair NVM
    * E720b – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read / Write / Repair NVM
    * A110 – added Unlock (direct and by codes reading), Write Firmware, Repair IMEI, Read / Write EEPROM, Read/Write Full Flash
    Note! In order to unlock, repair Security / IMEI / Bluetooth address of P350 or P350GO you need to write special firmware "LGP350-LGP350GO-FOR-UNLOCK.oct" from the support area. Only after that you can use the above mentioned functions.
    Note! In order to unlock, repair Security / IMEI / Bluetooth address of E720 or E720b you need to write special firmware "LGE720-LGE720b-FOR-UNLOCK.oct" from the support area. Only after that you can use the above mentioned functions.
    http://octopusbox.com/files/softs/in...opus_1.7.8.exe
    CTy TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    Địa chỉ : 693 Đường 3 tháng 2 Phường 6 Quận 10 Tp. Hồ Chí Minh
    Điện Thoại : 08.9572152 - 08.8.57.57.07 - 0903303717
    www.saigonmobile.vn
  3. ( HoangThong_hotrokythuat4 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tathanhvinh (02-04-2011)
  4. #53
    Thành viên chính thức langtutimhoa_tlphaibiet's Avatar
    Apr 2011
    upppppppppppppppp
  5. #54
    Jan 2009
    Mặc định Octopus Box v 1.8.0 is out - L03C, KU9200 and more!
    Octopus Box v.1.8.0 is out! We have added support LG P350G, world's first support for LG L03C, LG KU9200 and improved code reading for LG S310!
    Octopus Box v.1.8.0 Release Notes:
    L03C – added world's first Direct unlock, Repair Security, Read/Write/Repair NVM
    KU9200 – added world's first Direct Unlock, Safe Write Firmware, Repair Bluetooth address, Read/Write/Repair NVM
    P350G – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    S310 – improved Code Reading
    Note! In order to unlock, repair Security/IMEI/Bluetooth address of P350G you need to write special firmware "LGP350-LGP350G-LGP350GO-FOR-UNLOCK.oct" from the support area. Only after that you can use the above mentioned functions.
    Download Octopus Box v1.8.0 installer
    _________________
    Grip it tight!
    BR,
    Octopus Team
  6. #55
    Jan 2009
    _________________
    Grip it tight!
    BR,
    Octopus Team
  7. #56
    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    Octopus Box v 1.8.1 - public discussion thread Octopus Box v.1.8.1 is out! We have added support LG P505, LG P505R, LG P506, LG P506GO and direct unlock for some versions of LG KU9100, LG SH150!
    Octopus Box v.1.8.1 Release Notes:
    • P505 — added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    • P505R — added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    • P506— added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    • P506GO added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    • KU9100 — added Direct unlock for KU910907 version
    • SH150 — added Direct unlock for SW150706 version
    • Added extended manuals for a wide range of models
    Note! You need to write special firmware "LGP505-LGP505R-FOR-UNLOCK.oct" from the support area in order to unlock, repair Security/IMEI/Bluetooth address of P505, P505R with new security. Only after that press "Unlock" ("Repair security", "IMEI fix", "Repair BT") button.
    Note! You need to write special firmware "LGP506-LGP506GO-FOR-UNLOCK.oct" from the support area in order to unlock, repair Security/IMEI/Bluetooth address of P506, P506GO with new security. Only after that press "Unlock" ("Repair security", "IMEI fix", "Repair BT") button.
    Download Octopus Box v.1.8.1
    _________________
    Grip it tight!
    BR,
    Octopus Team
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  8. #57
    Executive Administrator TUYHOAGSM™'s Avatar
    Oct 2007
    TP.Tuy Hòa
    Arrow Octopus Box v.1.8.2 — Added support KU9500, SU950, LG900G, T325G!
    Octopus Box v.1.8.2 is out! We have added support KU9500, SU950, LG900G, T325G!
    Octopus Box v.1.8.2 Release Notes
    * KU9500 — added Unlock, Safe Write Firmware, Repair Bluetooth address, Read/Write/Repair NVM
    * SU950 — added Unlock, Safe Write Firmware, Repair Bluetooth address, Read/Write/Repair NVM
    * LG900G — added Unlock (by codes reading) via USB, Read/Write EEPROM via USB, Read/Write Full Flash via USB, Write Firmware via USB, Phone Repair after unsuccessful flashing
    * T325G — added Unlock, Write Firmware, Read/Write/Repair EEPROM
    * SH210 — added Direct Unlock for new revision SW210713 version
    * GW300, GW300GO, GW300FD, GW305 — Improved codes reading procedure
    Note! In order to unlock LG900g you need to write special firmware "LG900G-to-GW300-FOR-UNLOCK" from the support area and then input unlocking code.
    Download Octopus Box v.1.8.2
  9. #58
    Dec 2009
    GIALAI
    Octopus Box v.1.8.3. Some useful features added Octopus Box v.1.8.3 is out! We have added new features for LG S310, SU630 and P500!
    Octopus Box v.1.8.3 Release Notes:
    • S310 – added Read/Write/Repair EEPROM.
    • SU630 – added direct unlock for SU630910 version.
    • P500 – added direct unlock for old boot.
    • CU720, TU720 – improved unlocking procedure.
    • KF600 – fixed write firmware procedure.
    • KU990i, KC610 – fixed Message box in unlocking procedure.
    • Fixed minor bugs in cards updater.
    Download Octopus Box v1.8.3
    _________________
    Grip it tight!
    BR,
    Octopus Team
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  10. #59
    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định Octopus Box v 1.8.4 - check this out!
    Octopus Box v.1.8.4 is out! We have added Repair IMEI/EEPROM for LG GS290, GS390, KM570, GM360, GT350 and GS500-series and world's first support for LG P999 G2x!
    Octopus Box v.1.8.4 Release Notes:
    Р999 – added world's first Unlock, Repair IMEI, Repair Bluetooth address, Read/Write/Repair NVM.
    Added Repair IMEI и Repair EEPROM for the following models:
    GM360, GM360i, GM360GO
    GS290, GS290N, GS290GO, GS290NGO
    GS390, GS390GO
    GS500, GS500v, GS500f, GS500g, GS500GO
    GT350, GT350i, GT350F, GT350GO
    KM570, KM570F
    GD570, GS505, GR700 – improved Repair Security (added bad blocks correction).
    GW300, GW300GO, GW300FD, GW305, LG900G – improved Read Codes.
    P500 – fixed Repair NVM bug.
    Fixed minor bugs in text messages and manuals.
    Note! You need to use new Micro USB cable to Unlock, Repair IMEI, Repair Bluetooth address, Read/Write/Repair NVM in P999. Cable schematic is available in the manual (press "Cable & Manual" button).
    Download Octopus Box v1.8.4
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
  11. #60
    Thành viên mới ngohoang_mobile's Avatar
    Sep 2008
    lai có lúa nũa rồi thak
  1. LG-F240S update 4.4.2 ok by octopus
    By taotaai in forum Octopus/Octoplus Box
    Bài viết cuối: 10-05-2014, 15:35
  2. octopus báo lỗi maximum update
    By yeuiphone2012 in forum Octopus/Octoplus Box
    Trả lời: 33
    Bài viết cuối: 10-06-2013, 22:10
  3. Octopus Box LG v2.1.2 new update!
    By ThanhHaMobile™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 26-05-2012, 01:10
  4. Octopus box update - ver. 1.0.7
    By HoangThong_hotrokythuat4 in forum Octopus/Octoplus Box
    Bài viết cuối: 15-01-2010, 08:11
  5. Octopus Box Software update - V1.0.2 is out!
    By TuấnPhát_GSM in forum Octopus/Octoplus Box
    Bài viết cuối: 09-12-2009, 17:16
