Trang 5 của 14 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 CuốiCuối
Kết quả 41 tới 50 của 135
  1. #41
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định Octopus Box v 1.6.3 Release Notes
    * GT550 – added Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Repair IMEI
    * P500, P503, P509 – added Unlock, Write Firmware, Repair IMEI, Repair BT, Repair Security, Read/Write/Repair NVM
    * GT540 – added support for new security revision
    Note! For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of GT540 with new security, you need to write firmware "GT540-FOR-UNLOCK.oct" from the support area and click on the "Unlock" ("Repair Security", "Repair IMEI", "Repair BT") button.
    Note! For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of P500/P503/P509, you need to write firmware "P500-FOR-UNLOCK.oct"/"P503-FOR-UNLOCK.oct"/"P509-FOR-UNLOCK.oct" from the support area and click on the "Unlock" ("Repair Security", "Repair IMEI", "Repair BT") button.
    [/B]
  2. #42
    Jan 2009
    Mặc định Octopus Box v 1.6.5 - X-mas update :)
    Octopus Box v 1.6.5 is out! We have added world's first support for LG E900h!
    Octopus Box v 1.6.5 Release Notes:
    * E900h – added world's first Unlock, Write Firmware, Repair IMEI, Repair BT address, Repair Security
    * Improved writing firmware procedure for P500, P503, P509
    * Added new skin - Christmas
    Download latest installer from official site here
    _________________
    Grip it while it’s hot!
    BR,
    Octopus Team
  3. #43
    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    Version 1.6.6 – added world's first support for P500h! Octopus Box v. 1.6.6 is out! We have added world's first support for P500h!
    Octopus Box v. 1.6.6 Release Notes:
    • P500h – added world's first Unlock, Write Firmware, Repair IMEI, Repair BT, Repair Security, Read/Write/Repair NVM;
    • GX300 - fixed "Write EEPROM" function.
    Note! For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of P500h, you need to write firmware "LGP500h-FOR-UNLOCK.oct" from the support area and click on the "Unlock" ("Repair Security", "IMEI fix", "Repair BT") button.
    Download link:
    _________________
    BR,
    Octopus Team
    www.hungphongmobile.com
    www.giaimadienthoai.com
    <marquee ><font size=3 color=cyan><b> HungPhongMobile™ Service Center</b></font></marquee>
    <a href="ymsgr:sendIM?phongnhabr" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=phongnhabr&m=g&t=2&l=us border=0" border="0" /></a>
    <a href="ymsgr:sendIM?hp_unlockonline" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=hp_unlockonline&m=g&t=2&l=us border=0" border="0" /></a>
  4. #44
    Jan 2009
    Mặc định Octopus Box v 1.6.7 - back from vacations!
    Octopus Box v 1.6.7 is out! We have added support for LG T300, LG KM553, and world's first support for LG GS205!
    Octopus Box v 1.6.7 Release Notes:
    * T300 – added Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash;
    * GS205 – added world's first Unlock (direct and by reading codes), Read Phone Lock Code, Write Firmware, Read/Write EEPROM, Repair IMEI, Format Filesystem
    * KM553 – added Unlock (by Read codes), Write Firmware, Read/Write EEPROM
    * E900, E900h – Added Read/Write/repair NVM and Factory reset functions
    Note! To connect E900 and E900h in normal mode follow the next steps:
    1. Disconnect the cable and power on the phone.
    2. In call window input ##634# and click "call" button. After this, "MFG" application will be avaliable in the list of application.
    3. Execute MFG and input password 277634#*# - You will enter Engineer menu.
    4. Go to Engineer menu –> Port settings –> USB switching and select "QC COMPOSITE".
    5. After rebooting, connect the cable and install drivers.
    _________________
    BR,
    Octopus Team
  5. #45
    Mar 2007
    Octopus Box v 1.6.8 - LG GU295g, S310, T310, P520 support added!
    Octopus Box v 1.6.8
    is out! We have added support for LG T310, LG T310i, LG T310N, LG P520, and world's first support for LG GU295g and LG S310!
    Octopus Box v 1.6.8 Release Notes:
    • GU295g – added world's first Unlock, Write Firmware, Repair IMEI, Repair Bluetooth address, Repair Security, Read/Write/Repair NVM
    • S310 – added world's first Unlock, Repair IMEI
    • T310, T310i, T310N, P520 – Unlock (by Read codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write full flash
    _________________
    BR,
    Octopus Team
  6. #46
    Mar 2007
    Octopus Box v 1.6.9 - LG A310, GU200, T310GO support added!
    Octopus Box v 1.6.9 is out! We have added support for LG GU200, LG GU200a, LG GU200b, LG GU200e, LG T310GO, and world's first support for LG A310!
    Octopus Box v 1.6.9 Release Notes:
    • A310 – added world's first Unlock, Write Firmware, Repair IMEI, Repair Bluetooth Address, Repair Security, Read/Write/Repair NVM, Factory Reset
    • GU200, GU200a, GU200b, GU200e – added Unlock (direct and by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash, Repair IMEI
    • T310GO – Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write full flash
    • Released full support for A310 in LG Qualcomm Language Editor: Read LP from phone/Write LP to phone/Translate LP
    Attention: For Unlock, Security Repair, IMEI Repair and Bluetooth Address Repair of A310 with new security you need to write firmware "A310-FOR-UNLOCK" from the support area and press the "Unlock" (or "Repair security", "IMEI fix", "Repair BT") button.
    _________________
    BR,
    Octopus Tea
  7. #47
    Thành viên mới QUANGDUNG_MOBI's Avatar
    Nov 2010
    Octopus Box v 1.7.0 - LG Quantum (C900) and LG Scarlet II (GM600) supported!
    Octopus Box v 1.7.0 is out! We have added support for LG GM600 and world's first support for LG C900, LG C900B, LG C900k!
    Octopus Box v 1.7.0 Release Notes :
    C900, C900B, C900k – added world's first Unlock, Write Firmware, Repair IMEI, Repair Bluetooth Address, Repair Security, Read/Write/Repair NVM, Factory Reset
    GM600 – Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM
    Attention: To connect C900, C900B and C900k in normal mode You need:
    unlock all mobile yahoo:quangdung54@ymail.com
  8. #48
    Service unlock online Unlockđtdđ hp's Avatar
    Aug 2010
    Octopus Box v 1.7.3 - bit of everything Octopus Box v 1.7.3 is out! We have added support for LG GU290V, LG KP501N, LG KP501GO, LG KP502GO, and support for world's first LG T315i!
    Octopus Box v 1.7.3 Release Notes:
    • T315i – added world's first Unlock, Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash
    • GU290V – added Unlock, Write Firmware, Repair IMEI, Repair Bluetooth Address, Repair Security, Read/Write/Repair NVM
    • KP501N, KP501GO, KP502GO – added Unlock, Read/Write EEPROM, Write Firmware
    • LV7400 – added Direct Unlock for LV740914 version
    • KU9100 – added Direct Unlock for KU910906 version
    • KH6500 – added Direct Unlock for KW650810 version
    • KH1200 – added Direct Unlock for new revision of KW120612
    • GW550, GW550h – added Direct Unlock and Read codes support for some new versions
    • GB100, GB101, GB102, GB105, GB106, GB107, GB108, GB109 – added Direct Unlock
    • Improved Octopus card updater, added TOP GX4 cards support
    _________________
    BR,
    Octopus Team
  9. #49
    Thành viên mới vinhgsm_hue's Avatar
    Jan 2011
    Octopus Box Software V1.7.4
    GW370, GW370b, GW382f, GR500FGO, GT505e – added Unlock, Write Firmware, Read/Write GDFS
    C310 – added Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash, Repair IMEIs
    Added Language Editor for the following LG A2-based models: GW370, GW370b, GW382f, GR500FGO, GT505e – added Read LP from phone/Write LP to phone/Translate
    C320 – added unlock for "BS/LGC320/V10b" boot-loader's version
    Octopus Box Downloads - Software, Drivers, Manual
  10. #50
    Executive Administrator TUYHOAGSM™'s Avatar
    Oct 2007
    TP.Tuy Hòa
    Arrow Octopus Box v 1.7.5 - LG C100, LG C105, LG SU630 and more..
    Octopus Box v 1.7.5 is out! We have added support for LG С100, LG С105, LG SU630 and direct unlock for some versions of LG SH400, LG KU9100, LG KH2200, LG KH2700 and LG GW550!
    * C100, C105 – added Unlock (by reading codes), Write Firmware, Read/Write/Repair EEPROM, Read/Write Full Flash
    * SU630 – added Unlock, Safe Write Firmware, Repair Bluetooth address, Read/Write/Repair NVM
    * SH400 – added Direct Unlock for SW400806 and SW400808 versions
    * KU9100 – added Direct Unlock for KU910912 version
    * KH2200 – added Direct Unlock for KW220814 and KW220817 versions
    * KH2700 – added Direct Unlock for KW270810 version
    * GW550 – added Direct Unlock for some new versions
    Note! Added extended manuals for some Qualcomm and A2-based phones.
    Note! In the next updates "safe write firmware" option (skipping boot write) will be added for a wide range of phone models.
    Download latest installer from official site HERE
  1. LG-F240S update 4.4.2 ok by octopus
    By taotaai in forum Octopus/Octoplus Box
    Bài viết cuối: 10-05-2014, 15:35
  2. octopus báo lỗi maximum update
    By yeuiphone2012 in forum Octopus/Octoplus Box
    Trả lời: 33
    Bài viết cuối: 10-06-2013, 22:10
  3. Octopus Box LG v2.1.2 new update!
    By ThanhHaMobile™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 26-05-2012, 01:10
  4. Octopus box update - ver. 1.0.7
    By HoangThong_hotrokythuat4 in forum Octopus/Octoplus Box
    Bài viết cuối: 15-01-2010, 08:11
  5. Octopus Box Software update - V1.0.2 is out!
    By TuấnPhát_GSM in forum Octopus/Octoplus Box
    Bài viết cuối: 09-12-2009, 17:16
