Kết quả 1 tới 10 của 15
    Thành viên chính thức N9210i's Avatar
    Jan 2006
    Bên kia sông Đuống
    Mặc định SmartMoto v1.19 and Smart-Clip v2.24
    With this release we add M1000 to supported models list.
    Số 02 - Minh Khai - Từ Sơn - Bắc Ninh
    0241.760017 - 0912.912.567
    anhtuc2112@yahoo.com
    V.I.P Start307's Avatar
    Oct 2005
    SmartMoto v1.19 & Smart-Clip v2.24
    Dear users,
    We are pleased to announce the release of new version of SmartMoto v1.19 and Smart-Clip v2.24
    Unlock procedure for M1000
    Models with boot versions up to 0.6.1.2 could be unlocked simply by pressing "Unlock" button on Smart-Clip. (standard unlock procedure for P2K models)
    Boot version 0.6.1.2 needs to be unlocked via Remove RSA option.
    1. Power the phone ON;
    2. Connect the phone to a powered clip;
    3. Launch SmartMoto;
    4. Press Search button in SmartMoto;
    5. Program should detect the handset;
    6. Go to Unlock tab;
    7. Press Remove RSA;
    8. Phone enters boot mode, message "Waiting" appears on the bottom of the screen;
    9. Press 1 and 2 keys simultaneously in upper part of the handset and SmartMoto will continue the process;
    10. Program will show a popup window with description of procedure to follow:
    * Remove phone battery
    * Ensure that USB cable is plugged to the phone
    * Press phone keys 1 and 2 simultaneously
    * While holding Button 1 and Button 2, insert battery
    * Release button 1 and 2
    * Message "Waiting" should appear on the bottom of phoneТs display
    * Press and release phone keys 1 and 2 simultaneously once more
    * Message "Waiting" should disappear, press 'OK' to continue
    11. SmartMoto finishes removing RSA, the handset turns ON;
    12. Now phone requires being unlocked with Unlock button of Smart-Clip;
    * Connect the phone to the powered clip
    * Press UNLOCK button on the clip
    * Phone reloads. Within 5-10 seconds message "Waiting" appears on the bottom of the phoneТs display
    * Press 1 and 2 keys simultaneously in upper part of the handset. Message "Waiting" disappears, phone enters boot mode (if you don't press these 2 keys during message "Waiting" is displayed, the clip will give red E/G led and you will have to start with step 1 again)
    * After 1 and 2 keys have been pressed E/G green led will blink and phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
    Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
    * Green E/G led glows.
    13. The cell phone is unlocked.
    Models with higher boot version will require Testpoint procedure to be unlocked.
    Please be aware that TP procedure for M1000 and data cable differs from other P2K models.
    Testpoint unlock procedure for M1000
    1. Disassemble the phone;
    2. Connect USB-data cable;
    3. Connect Testpoint A to Testpoint B;
    4. Press Button 1 and Button 2 simultaneously;
    5. While holding Button 1 and Button 2 insert battery;
    6. Release Button 1 and Button 2 for 1 second;
    7. Press and release again Button 1 and Button 2 simultaneously;
    8. Press Search button in SmartMoto;
    9. SmartMoto should detect УS Blank Paragon POGФ or УS Blank Rainbow POGФ;
    10. Disconnect Testpoint;
    11. Go to Unlock tab of SmartMoto.
    12. Select required model from the list;
    13. Press Unlock via Testpoint;
    14. Assemble the handset, itТs ready for use.
    M1000 data cable pinout
    Please note. Testpoint schematics are moved to SmartMoto section at www.boot-loader.com. Use the testpoint for your specific phone model and follow the step-by-step instruction strictly. Please note that with some models there is a single contact that should be grounded, others have two contacts that should be connected to each other
    If you wish to receive news on updates immediately, please subscribe to our SMS notification system.
    Smart-Clip ON!
    Best Regards
    GSMServer team
    www.smart-clip.com
    www.GsmServer.com
    www.boot-loader.com
    www.smart-unlocker.com
    Start LTD Add: 307 Đoàn văn Bơ P13 Q4 TpHCM: 9430140
    V.I.P nguyenms's Avatar
    Sep 2005
    Nha Trang
    Thanks for info!
    NGUYENNGUYEN_mobile
    9b Lê Thánh Tôn - Nha Trang
    ĐT: 058-521928 0913.492.475
    __nguyennguyen_mobile@yahoo.com__
    Thành viên chính thức phuongtrinhmb's Avatar
    Jan 2006
    thanks bro info
    pho_nui_59@yahoo.com
    Làm lại từ đầu
    Thành viên mới vanngoantokyo's Avatar
    Feb 2006
    thanks a lot
    Thành viên chính thức quachhuy's Avatar
    Mar 2006
    Ai có giao diện của Smart Moto 1.19 ko? Sao em ko cài được giao diện này.. Giúp em với..
    Thành viên tích cực lahantran's Avatar
    Feb 2006
    Trích Được post bởi quachhuy
    Không cài được là sau hả bạn giao diện Tiếng việt đó hả. hay chương trình bạn cài o được. nói rõ hơn đi
    Vào Smart-clip.com Dơnload về Cào OK mà.
    Vitimiti@yahoo.com
    DĐ: 0908862955
    Mar 2006
    Uh. Mình update phiên bản mới nhất Smart Clip 2.24 OK, nhưng khi mình vào Smart Moto thì nó đòi phải cài bản mới nhất là 1.19(trong khi đó mình đã có 1.18 rồi), tên file có đuôi *.msi chỉ đọc chứ ko cho Intall.. Giúp mình với.. Bạn gửi cho mình giao diện Smart Moto được ko? Gấp lắm..
    Thành viên tích cực messi's Avatar
    Feb 2006
    Trời đất!Bạn đã biết cách update lên 2.24,mà lại không biết download cái Smart Moto 1.19 về mà dùng sao?2 cái nó nằm kế nhau luôn mà!
    http://www.smart-clip.com
    Thành viên mới hoangkimma's Avatar
    Jul 2006
    dùng USB mà không cần hộp smart clip được ko mấy huynh.em có chương trình smart moto 1.23 mà chẳng bít dùng.mấy huynh giúp đệ nha!
  1. Hướng dẫn sử dụng S-Card, Smart-Clip + SmartMoto
    By saigonmobile in forum Smart Clip
    Trả lời: 16
    Bài viết cuối: 15-03-2010, 09:28
  2. Trả lời: 0
    Bài viết cuối: 13-12-2007, 21:24
  3. Trả lời: 2
    Bài viết cuối: 12-01-2007, 16:18
  4. SmartMoto v1.22 and Smart-Clip v2.26
    Bài viết cuối: 17-09-2006, 00:08
  5. SmartMoto v1.22 and Smart-Clip v2.26
    By Thợ Học Nghề in forum Smart Clip
    Bài viết cuối: 20-06-2006, 14:23
