Trang 4 của 9 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 CuốiCuối
Kết quả 31 tới 40 của 87
    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    C5-00 flash OK
    Code:
    ATF Software Version v7.65
    ATF Lightning FBUS Flash Started...
    Number of Image Files: 5
    Processing Image File :
     C:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_prd.core.fpsx
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed    : 650000Hz
    Algorithm Sending Speed    : 6500000Hz
    Program Sending Speed      : 13000000Hz
    Message Reading Speed      : 98000Hz
    Number of Blocks :  453
    Entry Point:  0x01F0
    Page Format : -1
    MAX PAGE : 0x00040000
    Changing MODE : FLASH
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
                      TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded First Time
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
    Number of Sub Blocks 7  (0x07)
      1  SYSTEM_ASIC_ID 01
         Block Length  : 21  (15)
         BB ASIC Index : 0  (00)  CMT
         ID DWORD    0 : 00000003
         ID DWORD    1 : 00000226
         ID DWORD    2 : 00010007
         ID DWORD    3 : 600C1921
         ID DWORD    4 : 02031104
      2  ROM_ID 15
         Block Length  : 5  (05)
         ID DWORD    0 : 00000C35
      3  ROM_ID 15
         ID DWORD    0 : 00000C30
      4  PUBLIC_ID 12
         ID DWORD    0 : 1F70000B
         ID DWORD    1 : 9C9C0344
         ID DWORD    2 : 28770D32
         ID DWORD    3 : 6CC1A0F6
         ID DWORD    4 : 693C5E0A
      5  ASIC_MODE_ID 13
         Block Length  : 2  (02)
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Block Length  : 17  (11)
         Hash          :  91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
      7  ROM_ID 15
         Block Length  : 9  (09)
         CRC         0 : E693EF0D
         CRC         1 : AC22615B
    Checksum           87
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
    Boot File - Version  011.016.00
    Boot File - Revision 0x0003 (3)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    SearchForBootstrap_DCT5  : No Error - 0 (0x00)
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
     MessageID  : 06
     SubBlocks  : 06
     1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
       Block Length      : 0B
       BB ASIC Index     : CMT  00
       Device Type       : RAM  05
       Device Index      : 00
       Manufacturer Code : 0000 -> Flash
       Device ID         : 0000 -> not detected
       Extended/Fixed ID : 0000
       Revision ID       : 0000
     2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
       Block Length      : 0B
       Device Type       : MMC  04
       Device Index      : 00
       Device ID         : 0000 -> BAD FLASH TYPE
       Revision ID       : 0000
     3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
       Block Length      : 0B
       Device Type       : NOR  00
       Device Index      : 00
       Manufacturer Code : 0020 ->
       Device ID         : 0040 -> Type not in database
       Revision ID       : 0031
     4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
       Block Length      : 0B
       Device Index      : 01
       Manufacturer Code : 0000 -> SPANSION
       Device ID         : 0001 -> not used
       Revision ID       : 0000
     5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
       Block Length      : 0B
       Device Type       : MuxOneNAND  03
       Device Index      : 00
       Revision ID       : 0031
     6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
       Block Length      : 09
       Data              : XSR 1.6
     Checksum   : 54
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
    Flash Descriptor
       Device ID         : 0040
       Revision ID       : 0000
       Size              : 10000000 (256 MB)
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
    Algorithm File - Version  011.016.00
    Algorithm File - Revision 0x0003 (3)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
       PAPUB_KEYS_HASH_RESP_BB5 2A
       BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
        Partition Blocks :   1
         1   PARTITION_INFO_BB5
                BB ASIC Index     : 0x00 CMT
                Device Type       : 0x03 MuxOneNAND
                Device Index      : 0x00
                Partition Version : 00020000
                Spare             : FFFFFFFF
                Num Partitions    : 00000004
                Partition    1
                  Attribute       : 00000002  RO
                  Start Address   : 000A0000
                Partition    2
                  ID              : 00000004  DEMANDONOS
                  Start Address   : 03140000
                Partition    3
                  ID              : 00000008  FILESYSTEM
                  Attribute       : 00000001  RW
                  Start Address   : 0AE40000
                Partition    4
                  Start Address   : 0F640000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000030A000000000004000000020314000007D0000000000008000000010AE40000048000000000000A000000010F640000003C000036
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength  :  0x4F  (79)
    ERASE Blocks :  0x02  (2)
         0   ERASE_AREA_BB5 0x12
                Block Length     : 0x1B (27)
                Device Index     : 0x00
                   0             : 00020000-0003FFFF
                   1             : 00060000-004DFFFF
                   2             : 008E0000-0AE3FFFF
         1   FORMAT_PARTITION_BB5 0x19
                Block Length     : 0x2F (47)
                Device Index     : 0x00
                Format Info ID   : 0x02000000
                Format Info      : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
    Erase_SendEraseBlock_BB5_NAND
    Task in Progress... Please Wait...
    Erase_SendFormatPartition_BB5_NAND
    Successfully erased..
    Time Taken to Erase : 00:00:00
    Flashing Speed: 15.00 Mhz
    Processing  : rm645_071.005_prd.core.fpsx
    Total blocks to write : 453
    >>  CMT Rootkey Hash CERT : ADA
    >>  CMT Rootkey Hash CERT : KEYS
    >>  CMT Rootkey Hash CERT : PRIMAPP
    >>  CMT Rootkey Hash CERT : RAP3NAND
    >>  CMT Rootkey Hash CERT : SOS+PMML
    >>  CMT Rootkey Hash CERT : PASUBTOC
    >>  CMT Rootkey Hash CERT : PAPUBKEYS
    >>  CMT Rootkey Hash CERT : GENIO_INIT
    >>  CMT Rootkey Hash CERT : SOS*UPDAPP
    >>  CMT Rootkey Hash CERT : SOS*DSP0
    >>  CMT Rootkey Hash CERT : LDSP
    >>  CMT Rootkey Hash CERT : SOS*ISASW
    >>  CMT Rootkey Hash CERT : SOS+CORE
    >>  CMT Rootkey Hash CERT : SOS+ROFS1
    ContinueFlash_DCT5 Complete
    Continue Flash Complete :  : No Error - 0 (0x00)
    Time Taken to Flash  : 00:00:23
     C:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    CMT Type : BB5
    Number of Blocks :  5
    Entry Point:  0x012C
    Page Format : -1
    MAX PAGE : 0x00000E00
    NO PARTITION DATA FOR THIS IMAGE...
    StartErase_DCT5...
    BlockLength  :  0x0E  (14)
    ERASE Blocks :  0x01  (1)
                Block Length     : 0x0B (11)
                Device Index     : 0x00
                   0             : 0A040000-0AE3FFFF
    Processing  : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
    Total blocks to write : 5
    >>  CMT Rootkey Hash CERT : SOS+ROFS3
    Time Taken to Flash  : 00:00:00
     C:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_02.01_Euro2_prd.rofs2.fpsx
    CMT Type : BB5
    Number of Blocks :  168
    Entry Point:  0x012C
    Page Format : -1
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 06D40000-0A03FFFF
    Processing  : rm645_071.005_02.01_Euro2_prd.rofs2.fpsx
    Total blocks to write : 168
    >>  CMT Rootkey Hash CERT : SOS+ROFS2
    Time Taken to Flash  : 00:00:10
     C:\Program Files\Nokia\Phoenix\Products\RM-645\rm645_071.005_U000.000_prd.uda.fpsx
    CMT Type : BB5
    Number of Blocks :  6
    Entry Point:  0x012C
    Page Format : -1
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 0AE40000-0F63FFFF
    Processing  : rm645_071.005_U000.000_prd.uda.fpsx
    Total blocks to write : 6
     C:\Program Files\Nokia\Phoenix\Products\RM-645\RM645_ENO_10wk48v0.001.fpsx
    CMT Type : BB5
    Program Sending Speed      : 6500000Hz
    Number of Blocks :  13
    Entry Point:  0x012C
    Page Format : -1
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 004E0000-008DFFFF
    Processing  : RM645_ENO_10wk48v0.001.fpsx
    Total blocks to write : 13
    >>  CMT Rootkey Hash CERT : SOS*ENO
    Total Flash Write Time (Flashing Only) : 00:00:35
    Total Flashing Time (Booting + Erase + Flashing) : 00:00:36
    Status_BB5 STATUS_REQUEST_BB5..
    1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000003
              Additional Bad    :  00000003
              Correctable ECC   :  00000000
    FlashInfo.RestartMode : 2
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    MCU Version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    IMEI Plain : 3534320XXXXXXXXXXX
    IMEI Spare : A35379XXXXXXXXXX
    IMEI SV    : 3353792XXXXXXXXXX
    Phone Model: Nokia C5-00
    Product Serial Number: 06BF135AA
    Product Code         : 0591909
    Module Code          : 0204492
    Basic Production Code: 0591907
    Default SN Type      : 0
    PPM Version          : V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
    HW Version           : 6501
    RFIC Version         : |Vapaus_5.1 | Mikki_1.1
    DSP Version          : ICPR82_11w16
    AHNE Version         : 11
    APE SW Core Version  : 071.005
    APE Variant Version  : 071.005071.005.02.01071.005.C00.01
    APE Test Version     : 10wk48v0.001_APEONLY
    Retu Version         : 35
    Tahvo Version        : 00
    APE HW Version       : 256
    APE ADSP SW Version  : 256
       ********   Reading SimLock   ********
    CONFIG KEY:  0000000000000000
    PROVIDER KEY:  2440700000000000
    Provider  :  AT&T;U.S.A. (3650)
    Counters  :  0/3  ,  0/10
       Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
       Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
    SP Lock Status :  Not Locked
    SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST             : PASSED
    SECURITY_TEST           : PASSED
    SECURITY_CODE          : ENCRYPTED
    PHONE_MODE              : TEST MODE
    Report Post
    Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  2. ( GIALAI_GSM ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    HoangThong_hotrokythuat4 (05-11-2011), minhchienmobi (05-11-2011)
    Super Moderator TuệNguyễn's Avatar
    TP Hồ Chí Minh
    Flash 5630d RM-431 từ 012.020 lên 013.009 bằng USB chỉ mất 16 giây
    Code:
     rm431_013.009_prd.core.fpsx
    CMT Type : BB5
    Number of Blocks :  430
    Entry Point:  0x01DA
    Page Format : -1
     rm431_013.009_C14.01_SILVER_prd.rofs3.fpsx
    CMT Type : BB5
    Number of Blocks :  24
    Entry Point:  0x00DF
    Page Format : -1
     rm431_013.009_19.01_Vietnam_prd.rofs2.fpsx
    CMT Type : BB5
    Number of Blocks :  131
    Entry Point:  0x00DF
    Page Format : -1
     rm431_013.009_U000.000_prd.uda.fpsx
    CMT Type : BB5
    Number of Blocks :  40
    Entry Point:  0x00D9
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
     If Flashing DOES NOT Start in 5 Seconds,
     Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
         ID DWORD    4 : 02011104
      2  ROM_ID 15
         ID DWORD    0 : 00000C34
      3  ROM_ID 15
      4  PUBLIC_ID 12
         ID DWORD    0 : 28100201
         ID DWORD    1 : 58320344
         ID DWORD    2 : 95D7AC7B
         ID DWORD    3 : C3DDC6C0
         ID DWORD    4 : 261FCF46
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
         Hash          :  25 B9 77 A0 55 BE 9B 5D EC 0C 38 A2 A2 79 C6 95
      7  ROM_ID 15
         CRC         0 : 3E273BF6
         CRC         1 : 37BE26FA
     START FLASHING
    RawLoaderExtract: rm431_013.009_prd.core.fpsx
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2nd.fg
    Secondary Loader Sent....
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Manufacturer Code : 00EC ->
       Device ID         : 0040 -> KAT00F00RA
       Revision ID       : 0121
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0040
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XSR17_alg.fg
    Algorithm Loader Sent...
    FUR control Ok
     START READING RPL DATA
    IMEI: 359350021926817
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    RPL Backup was Successful...
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\359350021926817\359350021926817_101917.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     8B5237A1F5B38048C11FB4A6B04AE1CDD3C480E2
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-431\
    ImageFilename: rm431_013.009_prd.core.fpsx
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                  Start Address   : 03400000
                Partition    3
                  Start Address   : 0A880000
                Partition    4
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000033600000000000400000002034000000748000000000008000000010A88000004DC00000000000A000000010F640000003C000066
    StartErase_DCT5...
                Device Index     : 0x00
                   2             : 008E0000-0A87FFFF
                Device Index     : 0x00
    ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B00030000060000004DFFFF120B000300008E00000A87FFFF2B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033
    Total blocks to write : 430
    ImageFilename: rm431_013.009_C14.01_SILVER_prd.rofs3.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 09A80000-0A87FFFF
    ERASE_REQUEST_BB5 : 5001120B00030009A800000A87FFFF9E
    Total blocks to write : 24
    ImageFilename: rm431_013.009_19.01_Vietnam_prd.rofs2.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 06480000-09A7FFFF
    ERASE_REQUEST_BB5 : 5001120B0003000648000009A7FFFFE2
    Total blocks to write : 131
    ImageFilename: rm431_013.009_U000.000_prd.uda.fpsx
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 0A880000-0F63FFFF
    ERASE_REQUEST_BB5 : 5001120B0003000A8800000F63FFFFDC
    Total blocks to write : 40
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000002
              Additional Bad    :  00000002
    FlashInfo.RestartMode : 1
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:16
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V ICPR82_09w36.3 22-09-09 RM-431 (c) Nokia
    CONFIG KEY    :  0000000000000000
    PROVIDER KEY  :  2440700000000000
    NETWORK NAME  :  Nokia Default;Finland
    LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
    SIMLOCK TABLE :
    SIMLOCK STATE :  Not Locked
    SUPER_DONGLE_TEST  : PASSED
    Unlock-repair boot-repair imei-repair emmc-nạp Tiếng Việt all smart phone
    ĐC: 159/7/2 Đường TTH07 Phường Tân Thới Hiệp Q12 TPHCM
    ĐT: 0903135569 - Skype: tuenguyen.79
    Dec 2009
    GIALAI
    flash X2-01 OK bằng USB chỉ 13 giây
    Code:
    Number of Image Files: 3
     rm709__08.63.mcusw
    CMT Type : BB5
    Number of Blocks :  504
    Entry Point:  0x01F2
    Page Format : -1
    MAX PAGE : 0x0000E000
     rm709__08.63.ppm_v
    CMT Type : BB5
    Number of Blocks :  125
    Entry Point:  0x0113
    Page Format : -1
     rm709__08.63.image_v_059C2X8
    CMT Type : BB5
    Number of Blocks :  526
    Entry Point:  0x0147
    Page Format : -1
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
    Number of Sub Blocks 6 (0x06)
      1  SYSTEM_ASIC_ID 01
         ID DWORD    0 : 00000000
         ID DWORD    1 : 00000000
         ID DWORD    2 : 22000509
         ID DWORD    3 : 200C0000
      2  EM_ASIC_ID 02
         ID DWORD    0 : 00005361
      3  PUBLIC_ID 12
         ID DWORD    1 : 001CEC33
         ID DWORD    2 : 15102E48
         ID DWORD    3 : 3076E40C
         ID DWORD    4 : E3721E6F
      4  ASIC_MODE_ID 13
         Mode Id       : 00
      5  ROOT_KEY_HASH 14
         Hash          :  1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
      6  ROM_ID 15
         CRC         0 : DE56D582
         CRC         1 : BDDE7A3A
     START FLASHING
    RawLoaderExtract: rm709__08.63.mcusw
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_usb2nd.fg
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Device ID         : 0030 -> Type not in database
       Revision ID       : 0131
       Block Length      : 0B
       Device Index      : 01
       Manufacturer Code : 0010 ->
       Device ID         : 0011 -> Type not in database
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0131
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       Size              : 08000000 (128 MB)
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_XSR16_usbalg.fg
    FUR control Ok
    IMEI: 358277041520646
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\358277041520646\358277041520646_43030.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     37955B6FC432998EF0DB240E332228384D19ED09
    ImagePath: D:\FLASH FILE\FILE NOKIA\X2-01 RM-709\08.63\
    ImageFilename: rm709__08.63.mcusw
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Certificate 5
      ASIC Index  : CMT  0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
    Partition Info
                Device Index      : 0x00
                Partition Version : 00010000
                Spare             : FFFFFFFF
                Partition    1
                  Start Address   : 00020000
                Partition    2
                  Start Address   : 02A00000
                Partition    3
                  Start Address   : 07540000
                Partition    4
                  Start Address   : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000025E0000000000080000000102A0000004B400000000000A0000000107540000006000000000000B0000000107B40000001800000D
    StartErase_DCT5...
    BlockLength  :  0x90  (144)
    ERASE Blocks :  0x03  (3)
                Block Length     : 0x2B (43)
                Device Index     : 0x00
                   0             : 00000000-0001FFFF
                   1             : 00020000-000203FF
                   2             : 00060000-012FFFFF
                   3             : 01300000-01DFFFFF
                   4             : 02600000-029FFFFF
                Device Index     : 0x00
                Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
         2   FORMAT_PARTITION_BB5 0x19
                Device Index     : 0x00
                Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B00030000020000000203FF120B00030000060000012FFFFF120B0003000130000001DFFFFF120B00030002600000029FFFFF11
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
    Total blocks to write : 504
    >>  CMT Rootkey Hash CERT : UPDAPP
    >>  CMT Rootkey Hash CERT : MCUSW
    >>  CMT Rootkey Hash CERT : MCUSW1
    >>  CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm709__08.63.ppm_v
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 01E00000-025FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
    Total blocks to write : 125
    ImageFilename: rm709__08.63.image_v_059C2X8
    StartErase_DCT5...
    BlockLength  :  0x3F  (63)
                Device Index     : 0x00
                   0             : 02A00000-0753FFFF
                Device Index     : 0x00
                Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
    Total blocks to write : 526
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000000
              Additional Bad    :  00000000
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:13
    Elapsed Time: 5 Seconds...
    Elapsed Time: 10 Seconds...
    Elapsed Time: 15 Seconds...
    Elapsed Time: 20 Seconds...
    Elapsed Time: 25 Seconds...
    Elapsed Time: 30 Seconds...
    Elapsed Time: 35 Seconds...
    Elapsed Time: 40 Seconds...
    Elapsed Time: 45 Seconds...
    Elapsed Time: 50 Seconds...
    Elapsed Time: 55 Seconds...
    Elapsed Time: 60 Seconds...
    Elapsed Time: 65 Seconds...
    Elapsed Time: 70 Seconds...
    SW: V 08.63 25-03-11 RM-709 (c) Nokia
    SIMLOCK TABLE :
    SECURITY_CODE          : 12345
                   SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FACTORY SET TO : Full Factory Set
     OK
    FACTORY SET TO : User Data
     OK
    FACTORY SET TO : Leave Factory
     OK
    FACTORY SET TO : Service Center
     OK
    FACTORY SET TO : Software Upgrade
     OK
    FACTORY SET TO : Production Tune
     OK
    RESET LIFE TIMER TO : 0000:00
     OK
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Dec 2009
    GIALAI
    X2-01 Total Flashing Time (Erase + Flashing) : 00:00:11
    Code:
     rm709__08.63.mcusw
    CMT Type : BB5
    Entry Point:  0x01F2
    Page Format : -1
     rm709__08.63.ppm_v
    CMT Type : BB5
    Entry Point:  0x0113
    Page Format : -1
    CMT Type : BB5
    Entry Point:  0x0147
    Page Format : -1
    []: Found 1 active devices.
    [X2-01 USB Phonet]: Opening Connection
    [X2-01 USB Phonet]: Port opened OK!
    IMEI: 358645040293920
    SIMLOCK TABLE :
     START FULL PM BACKUP
    Please Wait...
    Reading : PM 0~400... OK!
     FULL PM Backup Saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\358645040293920\USB_FULL_BACKUP_V 08.63 25-03-11 RM-709 (c) Nokia_358645040293920_Not Locked_50114.pm
    Reading battery value  : 3975 mV
    Rebooting Phone...
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  PUBLIC_ID 12
         ID DWORD    1 : 00666613
         ID DWORD    2 : 9D93DF5B
         ID DWORD    3 : 3AEFD352
         ID DWORD    4 : 839EF207
      4  ASIC_MODE_ID 13
         Mode Id       : 00
      5  ROOT_KEY_HASH 14
      6  ROM_ID 15
         CRC         0 : DE56D582
         CRC         1 : BDDE7A3A
     START FLASHING
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0131
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0131
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    FUR control Ok
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\358645040293920\358645040293920_50129.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
    ImagePath: D:\Flash file\File nokia\X2-01 RM-709\08.63\
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Certificate 5
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                Partition    3
                Partition    4
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
                Device Index     : 0x00
    StartErase_DCT5...
                Device Index     : 0x00
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000001
    Flashing Done...
    SIMLOCK TABLE :
    SECURITY_CODE          : 349761
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
     OK
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    TP Hồ Chí Minh
    N8 Chạy tiếng viêt bằng USB chỉ với 3 giây
    Code:
    Number of Image Files: 1
     RM-596_111.030.0609_19.01_Vietnam_79u_prd.rofs2.fpsx
    CMT Type : BB5
    Number of Blocks :  140
    Entry Point:  0x00F4
    Page Format : -1
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  EM_ASIC_ID 02
      4  PUBLIC_ID 12
         ID DWORD    0 : 10C00016
         ID DWORD    1 : 4FA70344
         ID DWORD    2 : 476BAB39
         ID DWORD    3 : D0DAEC3D
         ID DWORD    4 : 4310CCA1
      5  ASIC_MODE_ID 13
         Mode Id       : 00
      6  ROOT_KEY_HASH 14
      7  ROM_ID 15
         CRC         0 : E693EF0D
         CRC         1 : AC22615B
     START FLASHING
    RawLoaderExtract: RM-596_111.030.0609_19.01_Vietnam_79u_prd.rofs2.fpsx
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Device ID         : 0050 -> Type not in database
       Revision ID       : 0031
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0050
       Revision ID       : 0000
       Size              : 20000000 (512 MB)
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    FUR control Ok
    IMEI: 355944042138073
    Reading : PARTNERC... OK!
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\355944042138073\355944042138073_84904.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     D172C32473AE199B213465ABB3853246F9631231
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-596\
    ImageFilename: RM-596_111.030.0609_19.01_Vietnam_79u_prd.rofs2.fpsx
    NO RESTORE CERTIFICATE BLOCK FOUND...
    NO PARTITION BLOCK FOUND...
    StartErase_DCT5...
                Device Index     : 0x00
                   0             : 09F40000-0DA7FFFF
    ERASE_REQUEST_BB5 : 5001120B00030009F400000DA7FFFF2F
    Total blocks to write : 140
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
              Num Bad Blocks    :  00000008
              Additional Bad    :  00000008
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:03
    SW: V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia
    SIMLOCK TABLE :
    Executive Administrator TUYHOAGSM™'s Avatar
    Oct 2007
    TP.Tuy Hòa
    Arrow Nokia 603 mở mã bảo vệ ok
    20:47:05 : ================================================
    20:47:05 : Basic Phone Information
    20:47:06 : ================================================
    20:47:06 : MCU Version: V 79u_sr1_11w34_2 05-09-11 RM-779 (c) Nokia
    20:47:06 : IMEI Plain : 358647044001770
    20:47:06 : IMEI Spare : A358647044001770
    20:47:06 : IMEI SV : 33586470440017705F
    20:47:06 : Phone Model: Nokia 603
    20:47:06 : Category : Classic Phone
    20:47:06 : Phone Type : RM-779
    20:47:06 :
    20:47:06 : Extended Phone Information
    20:47:06 : Product Serial Number: CVF880659
    20:47:06 : Product Code : 059M3J8
    20:47:06 : Module Code : 0204943
    20:47:06 : Basic Production Code: 059G4W3
    20:47:06 : Long Production SN : 0
    20:47:07 : MCU SW Version : V 79u_sr1_11w34_2 05-09-11 RM-779 (c) Nokia
    20:47:07 : HW Version : 0503
    20:47:07 : RFIC Version : |Alli_4.b.1
    20:47:07 : DSP Version : 79u_sr1_11w34_1
    20:47:07 : Content : 111.020.0310.U08.01
    20:47:07 : APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
    20:47:07 : AHNE Version : 21
    20:47:07 : APE SW Core Version : 111.020.0310
    20:47:08 : Variant Version : 111.020.0310111.020.0310.15.01111.020.0310.271.01
    20:47:08 : APE Test Version : rm779_ENO_11wk32_v0.036
    20:47:08 : RETU Version : 40
    20:47:08 : TAHVO Version : 00
    20:47:08 : APE HW Version : 256
    20:47:08 : APE ADSP SW Version : 256
    20:47:08 : Wireless LAN ID : 94:3A:F0:0E:B5:13
    20:47:08 : Bluetooth ID : 94:3A:F0:0E:183
    20:47:08 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII
    20:47:08 :
    20:47:08 : ================================================
    20:47:08 : Simlock Information
    20:47:08 : CONFIG KEY : 0000000000000000
    20:47:08 : PROVIDER KEY : 2440700000000000
    20:47:08 : NETWORK NAME : Nokia Default;Finland
    20:47:08 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    20:47:08 : SIMLOCK TABLE :
    20:47:08 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:08 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:08 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:08 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:08 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:08 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:09 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    20:47:09 : SIMLOCK STATE : Not Locked
    20:47:09 :
    20:47:09 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    20:47:09 : SIMLOCK_TEST : PASSED
    20:47:09 : SECURITY_TEST : PASSED
    20:47:09 : SECURITY_CODE : ENCRYPTED
    20:47:09 : PHONE_MODE : LOCAL
    20:47:10 :
    20:47:14 :
    20:47:14 : Make sure you have installed the
    20:47:14 : COMPLETE Flash Package for this Phone...
    20:47:14 :
    20:47:14 : Goto "Settings" --> "Nokia Settings" and verify that
    20:47:14 : the Folder where you installed your Flash Files are
    20:47:14 : in the "PRODUCT PATH TO SCAN" List...
    20:47:25 :
    20:47:25 : FACTORY SET TO : Full Factory Set
    20:47:27 : OK
  8. #7
    Oct 2007
    TP.Tuy Hòa
    Arrow Unlock N75 ok by ATF
    20:59:09 : ================================================
    20:59:09 : Basic Phone Information
    20:59:09 : MCU Version: V 06wk15v45.1 17-10-07 RM-128 (c) Nokia.
    20:59:09 : IMEI Plain : 354815013212033
    20:59:09 : IMEI Spare : A354815013212030
    20:59:09 : IMEI SV : 33548150132120310F
    20:59:10 : Phone Model: Nokia N75
    20:59:10 : Category : Imaging Phone
    20:59:10 : Phone Type : RM-128
    20:59:10 :
    20:59:10 : ================================================
    20:59:10 : Extended Phone Information
    20:59:10 : Product Serial Number: YHA196312
    20:59:10 : Product Code : 0545060
    20:59:10 : Basic Production Code: 0545057
    20:59:11 : MCU SW Version : V 06wk15v45.1 17-10-07 RM-128 (c) Nokia.
    20:59:11 : HW Version : 4202
    20:59:11 : RFIC Version : 17141715
    20:59:11 : DSP Version : chx_06wk14v54
    20:59:11 : LCD Version : 8621376
    20:59:12 : Camera : 1028
    20:59:12 : APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
    20:59:12 : AHNE Version : 30
    20:59:13 : APE SW Core Version : V 20.1.172 30-10-07 RM-128 (C)Nokia
    20:59:13 : Variant Version : V 20.1.172-71.04 30-10-07 RM-128 (C)Nokia
    20:59:13 : RETU Version : 15
    20:59:13 : TAHVO Version : 22
    20:59:13 : APE HW Version : 1
    20:59:13 : APE ADSP SW Version : 256
    20:59:13 : Bluetooth ID : 00:19:79:34:65:0F
    20:59:15 :
    20:59:15 : ================================================
    20:59:15 : Simlock Information
    20:59:15 : CONFIG KEY : 0000000000000000
    20:59:15 : PROVIDER KEY : 3101700000000000
    20:59:15 : NETWORK NAME : North Sight Communications Inc. ;United States
    20:59:15 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    20:59:15 : SIMLOCK TABLE :
    20:59:15 : Block [1] 1:Close
    20:59:15 : Block [2] 1:Close
    20:59:15 : Block [3] 1:Close
    20:59:15 : Block [4] 1:Close
    20:59:15 : Block [5] 1:Close
    20:59:15 : Block [6] 1:Close
    20:59:15 : Block [7] 1:Close
    20:59:15 : Block [8] 1:Close
    20:59:15 : SIMLOCK STATE : LOCKED
    20:59:15 :
    20:59:15 : SIMLOCK_TYPE : PA_SL1
    20:59:16 : SIMLOCK_TEST : PASSED
    20:59:16 : SECURITY_TEST : PASSED
    20:59:16 : SECURITY_CODE : 12345
    20:59:17 : PHONE_MODE : LOCAL
    20:59:17 : DCC ID : NOT USED
    20:59:17 :
    20:59:22 :
    20:59:22 : Detected Sp type: SL1 (SLPA)
    20:59:22 : Level Calculated codes
    20:59:22 : 1 : 026817547080092
    20:59:22 : 2 : 796720790281475
    20:59:22 : 3 : 990978097742456
    20:59:23 : 4 : 552795041714560
    20:59:23 : 5 : 703127066966608
    20:59:23 : 6 : 708781660214960
    20:59:23 : 7 : 291457994293733
    20:59:23 :
    20:59:23 : Sending SP code: #pw+291457994293733+7#
    20:59:23 : Sending FBUS Command
    20:59:23 : FBUS Command Sent
    20:59:23 : OK: code accepted
    20:59:23 :
    20:59:24 :
    20:59:24 : ================================================
    20:59:24 : Basic Phone Information
    20:59:24 : MCU Version: V 06wk15v45.1 17-10-07 RM-128 (c) Nokia.
    20:59:24 : IMEI Plain : 354815013212033
    20:59:24 : IMEI Spare : A354815013212030
    20:59:24 : IMEI SV : 33548150132120310F
    20:59:24 : Phone Model: Nokia N75
    20:59:24 : Category : Imaging Phone
    20:59:24 : Phone Type : RM-128
    20:59:24 :
    20:59:24 : Extended Phone Information
    20:59:25 : Product Serial Number: YHA196312
    20:59:25 : Product Code : 0545060
    20:59:25 : Basic Production Code: 0545057
    20:59:36 : RFIC Version : 17141715
    20:59:36 : DSP Version : chx_06wk14v54
    20:59:36 : LCD Version : 8621376
    20:59:37 : Camera : 1028
    20:59:37 : APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
    20:59:37 : AHNE Version : 30
    20:59:37 : APE SW Core Version : V 20.1.172 30-10-07 RM-128 (C)Nokia
    20:59:37 : Variant Version : V 20.1.172-71.04 30-10-07 RM-128 (C)Nokia
    20:59:37 : RETU Version : 15
    20:59:37 : TAHVO Version : 22
    20:59:38 : APE HW Version : 1
    20:59:38 : APE ADSP SW Version : 256
    20:59:38 : Bluetooth ID : 00:19:79:34:65:0F
    20:59:39 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA II, WCDMA V
    20:59:39 :
    20:59:39 : ================================================
    20:59:39 : Simlock Information
    20:59:39 : CONFIG KEY : 0000000000000000
    20:59:39 : PROVIDER KEY : 3101700000000000
    20:59:39 : NETWORK NAME : North Sight Communications Inc. ;United States
    20:59:39 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    20:59:39 : SIMLOCK TABLE :
    20:59:39 : Block [1] 1:Open
    20:59:39 : Block [2] 1:Open
    20:59:39 : Block [3] 1:Open
    20:59:39 : Block [4] 1:Open
    20:59:39 : Block [5] 1:Open
    20:59:39 : Block [6] 1:Open
    20:59:39 : Block [7] 1:Open
    20:59:39 : Block [8] 1:Open
    20:59:39 : SIMLOCK STATE : Not Locked
    20:59:39 :
    20:59:39 : SIMLOCK_TYPE : PA_SL1
    20:59:40 : SIMLOCK_TEST : PASSED
    20:59:40 : SECURITY_TEST : PASSED
    20:59:40 : SECURITY_CODE : 12345
    20:59:41 : PHONE_MODE : LOCAL
    20:59:41 : DCC ID : NOT USED
    20:59:41 :
    20:59:41 :
    20:59:41 : Successfully done.
    21:02:38 :
    21:02:38 : FACTORY SET TO : Full Factory Set
    21:02:39 : OK
  9. #8
    Dec 2009
    GIALAI
    C3-00 flash OK
    Code:
     rm614__04.45.mcusw
    CMT Type : BB5
    Number of Blocks :  525
    Entry Point:  0x01F2
    Page Format : -1
     rm614__04.45.ppm_v
    CMT Type : BB5
    Number of Blocks :  130
    Entry Point:  0x0113
    Page Format : -1
     rm614__04.45.image_v_0597641
    CMT Type : BB5
    Number of Blocks :  222
    Entry Point:  0x0147
    Page Format : -1
    2. Insert USB.
    BootFlashMode_DCT5
     BootRom Verified!
      1  SYSTEM_ASIC_ID 01
      2  EM_ASIC_ID 02
      3  PUBLIC_ID 12
         ID DWORD    1 : 00233818
         ID DWORD    2 : 733AE657
         ID DWORD    3 : FDE693A4
         ID DWORD    4 : 8B4B403D
      4  ASIC_MODE_ID 13
         Mode Id       : 00
      5  ROOT_KEY_HASH 14
      6  ROM_ID 15
         CRC         0 : DE56D582
         CRC         1 : BDDE7A3A
     START FLASHING
    RawLoaderExtract: rm614__04.45.mcusw
     MessageID  : C1
     SubBlocks  : 06
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 01
       Revision ID       : 0000
       Block Length      : 0B
       Device Index      : 00
       Device ID         : 0030 -> K5W1G13ACB
       Revision ID       : 0321
       Block Length      : 09
       Data              :
    Flash Descriptor
       Device ID         : 0030
       Revision ID       : 0000
       VPP Info          : 0000
       Erase10s          : 1E
       Block1s           : 32
       BErase1s          : 02
       Reserved0         : 00
       Reserved1         : 00
       Reserved2         : 00
    FUR control Ok
    IMEI: 353760042912099
     Plain RPL saved to:
     C:\AdvanceBox Turbo Flasher\Nokia\Backup\353760042912099\353760042912099_72447.rpl
    Pabub KEY Request
        BB Asic Index   : 00
    CMT PAPUBKEYS HASH:
     697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
    ImagePath: D:\Flash file\File nokia\C3-00 RM-614\04.45\
    ImageFilename: rm614__04.45.mcusw
    Certificate 1
      ASIC Index  : CMT  0
    Certificate 2
      ASIC Index  : CMT  0
    Certificate 3
      ASIC Index  : CMT  0
    Certificate 4
      ASIC Index  : CMT  0
    Certificate 5
      ASIC Index  : CMT  0
    Partition Info
                Device Index      : 0x00
                Spare             : FFFFFFFF
                Partition    1
                Partition    2
                Partition    3
                Partition    4
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
                Device Index     : 0x00
    Total blocks to write : 525
    ImageFilename: rm614__04.45.ppm_v
    StartErase_DCT5...
                Device Index     : 0x00
    Total blocks to write : 130
    ImageFilename: rm614__04.45.image_v_0597641
    StartErase_DCT5...
                Device Index     : 0x00
                Device Index     : 0x00
    Total blocks to write : 222
              Block Length      :  0F
              BB ASIC Index     :  00
              Device Type       :  03
              Device Type       :  00
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:10
    Elapsed Time: 75 Seconds...
    Elapsed Time: 80 Seconds...
    SW: V 04.45 04-08-10 RM-614 (c) Nokia
    SIMLOCK TABLE :
    SECURITY_CODE          : 21528479
                   SL3 Phone detected
     OK
     OK
     OK
     OK
     OK
     OK
    ERROR: Life timer Reset Failed
    Scanning USB Ports...
    MCU Version: V 04.45 04-08-10 RM-614 (c) Nokia
    IMEI Plain : 353760042912099
    IMEI Spare : A353760042912090
    IMEI SV    : 33537600429120913F
    Phone Model: Mo       C3-00
    Category   : Entry Phone
    Phone Type : RM-614
    Product Serial Number: DSJ156202
    Product Code         : 0594046
    Module Code          : 0204418
    Basic Production Code: 0587486
    PPM SW Version       : V 04.45 04-08-10 RM-614 (c) Nokia             V
    BT MCM Version       : 4217-v352
    MCU SW Version       : V 04.45 04-08-10 RM-614 (c) Nokia
    HW Version           : 1000
    RFIC Version         : 9
    LCD Version          : SEIKO
    Content Pack Version : Content: v_0597641 V 04.45 04-08-10 RM-614 (c) Nokia
    Wireless LAN ID      : D4:CB:AF:16:04:76
    Bluetooth ID         : D4:CB:AF:14:F3:07
                   Simlock Information
    SIMLOCK TABLE :
    PHONE_MODE              : TEST
              Dynamic Camera Configuration
    DCC ID  : NI00BC0000040102F201
    DCC Ver: 001006
    Status   : OK
     OK
     OK
     OK
     OK
     OK
     OK
    Changing Phone Mode...
    (Wait for 10 seconds)
    Successfully set to : Normal
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
  10. #9
    Oct 2007
    TP.Tuy Hòa
    Thumbs up Nạp tiếng việt N9 = usb ok by ATF
    Code:
     DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_005-OEM1-958_ARM.bin
    CMT Type :
    CMT Algorithm :
    Secondary Sending Speed    : 0Hz
    Algorithm Sending Speed    : 0Hz
    Program Sending Speed      : 0Hz
    Message Reading Speed      : 0Hz
    Entry Point:  0x003F
    Page Format : -1
    MAX PAGE : 0x00000580
                 BB5 MEEGO / HARMATTAN FLASHER
    1. Turn OFF Phone and wait 10 Seconds...
    2. Connect the USB Cable to the PHONE Micro USB Port
    3. Connect the USB Cable to the PC USB Port
    TIPS & INFORMATION:
     1. To Turn OFF the Phone, PRESS and HOLD the POWER
        button for at least 10 Seconds...
     2. Battery Charging will still work on "DEAD" Phones.
     3. Factory Reset will make Flashing 15 minutes longer
        and it will Totally Erase the User Data and Remove
        the Phone Lock + Security Code as well...
     4. Skip ADL Chk will Cold Flash the Device.
    Waiting For Phone on USB PORT/s...
    REQUIRED MODE: BOOTLOADER MODE  PHONET MODE
    Sending APE-ALGORITHM: SUCCESSFUL
    Nokia Bootloader/PhoNet Found!
    REQUIRED MODE: PHONET MODE
    Battery Voltage Test: PASSED
     Ready to Flash Images to Device...
    Processing Image: cert-sw
    Processing Image: cmt-2nd
    Processing Image: cmt-algo
    Processing Image: cmt-mcusw
    Processing Image: xloader
    Processing Image: secondary
    Processing Image: kernel
    Processing Image: rootfs
     All Images were Succssfully Uploaded!
     Software Update Done
    [Nokia N900 USB Phonet]: Opening Connection
    [Nokia N900 USB Phonet]: Port opened OK!
    Rebooting Phone...
    Total Flashing Time (Erase + Flashing) : 00:03:09
  11. #10
    V.I.P ThanhTuMobile's Avatar
    Aug 2007
    Sông Vàm Cỏ Đông LộcGiang-ĐứcHoà-Long An
    3110c Lắp sim vào máy đòi nhập mã hạn chế điện thoại
    Code:
              Box Successfully Initialized
    VBATT Powering Down <<<<
    VBATT Powering Up   >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    MCU Version: V 07.30 07-05-09 RM-237 (c) Nokia.
    IMEI Plain : 356418029050014
    IMEI Spare : A356418029050010
    IMEI SV    : 33564180290500127F
    Phone Model: Nokia 3110c
    Phone Type : RM-237
    Booting Phone via FBUS...
    BOOTING BB5 Phone...
                      TIME STARTS HERE
    CMT Hardware : 010C192101001101
    CMT PUBLIC ID : 0E80021500787C56ABA22AD8A6C9905E5FF5CA82
    CMT ROOTHASH : BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM_ID : 191EC665DFAAF68F
    Send Loader...
    Custom Loader Running!
    Restarting phone, please wait .. .
    SET BSI Load Done
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Phone Type : RM-237
    Product Serial Number: MPF687397
    Product Code         : 0514949
    Module Code          : 0203291
    Basic Production Code: 0542523
    PPM SW Version       : V 07.21 05-11-08 RM-237 (c) Nokia.            V
    BT MCM Version       : 06cc-P9.1
    MCU SW Version       : V 07.30 07-05-09 RM-237 (c) Nokia.
    HW Version           : 5005
    RFIC Version         : 17211721
    DSP Version          : ICPR61_08w10
    Content Pack Version : Content: c_tr V 07.30 07-05-09 RM-237 (c) Nokia.
    AHNE Version         : 11
    RETU Version         : 32
    TAHVO Version        : 53
    Bluetooth ID         : 00:22:FC:25:32:68
    CS Type              : GSM900, GSM1800, GSM1900
                   Simlock Information
    SIMLOCK TABLE :
    MMC_SD_PASSWORD 1:
    PHONE_MODE              : LOCAL
        SL1/SL2 Simlock  RPL Stand Alone Edition
    Generating Simlock Data RPL...
    -> OK: Simlock RPL accepted
    SET BSI Load Done
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Phone Type : RM-237
    HW Version           : 5005
    AHNE Version         : 11
    RETU Version         : 32
    TAHVO Version        : 53
                   Simlock Information
    SIMLOCK TABLE :
    MMC_SD_PASSWORD 1:
                 SL1/SL2 Phone detected
    PHONE_MODE              : LOCAL
    Successfully done.
    KHÔNG THAY ĐỔI THÌ CHẤP NHẬN CHẤP NHẬN THÌ KHÔNG THAY ĐỔI
    VẠN NGƯỜI QUEN CÓ MẤY NGƯỜI THÂN KHI LÌA TRẦN CÓ MẤY NGƯỜI ĐƯA
  1. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  2. Trả lời: 91
    Bài viết cuối: 13-08-2013, 17:42
  3. Trả lời: 2
    Bài viết cuối: 27-09-2012, 17:43
  4. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
