Trang 9 của 9 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9
Kết quả 81 tới 87 của 87
    Thành viên chính thức phung77's Avatar
    Oct 2009
    585 TRẦN HƯNG ĐẠO-PHAN THIẾT
    lumia 510 flash tiếng việt ok by atf
    1. DO NOT USE THE PHONE"S BATTERY
    2. Connect the Soldered TP Connections to ATF Box
    3. Disconnect the USB Cable and Wait until the
    the ATF Software will tell you to Connect the USB.
    Interface Reset OK!
    eMMC Access Type: SECTOR MODE
    eMMC Supported Voltage Range:
    3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
    3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
    CID : 1501004D344731464203EE101286
    CSD : D02701320F5903FFF6DBFFE78A404057
    eMMC Boot Information
    Revision 1.5 (for MMC v4.41)
    BOOT PARTITION : USER AREA
    PARTITION ACCESS : R/W USER PARTITION
    PERM_BOOT_CFG_PROT : DISABLED
    PWR_BOOT_CFG_PROT : DISABLED
    eMMC FirmW UPDATE : DISABLED
    EMMC CACHE SIZE : 0 KB
    SUPER PAGE SIZE : 2560 KB
    HC ERASE GROUP SIZE: 512 KB
    USER AREA SIZE : 3909091328 BYTES
    BOOT PARTITION SIZE: 1024 KB
    RPMB PARTITION SIZE: 128 KB
    Lumia 505/510 Detected
    eMMC Device Information
    Manufacturer ID: SAMSUNG
    Device Type : Embedded BGA
    Application ID : 00
    Product Name : M4G1FB
    Product Rev : 0.3
    Product SN : EE101286
    Manufactured : January 2012
    Card Specific Data
    CSD_STRUCTURE : Extended
    SPEC_VERS : Version 4.1/4.2/4.3
    TAAC : 13 ns
    TRANS_SPEED : 4000000 KHz
    READ_BL_LEN : 512 Bytes
    C_SIZE : HIGH CAPACITY
    WP_GRP_ENABLE : YES
    WRITE_BL_LEN : 512 Bytes
    CONTENT_PROT_APP : NO
    PERM_WRITE_PROTECT: NO
    TMP_WRITE_PROTECT : NO
    Extended CSD Saved:
    1501004D344731464203EE101286_404B482C.ext_csd
    Backup Directory:
    C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
    Writing MBR...
    Write Success!
    Writing DBL...
    Write Success!
    Writing OSBL...
    Write Success!
    BOOT Images Written Successfully!
    Total Elapsed Time 00:01:13
    file của bạn hậu đăng
    chuyên:UNLOCK-REPAIR BOOT-NẠP TIẾNG VIỆT ALL PHONE
    Oct 2009
    6700s flash tv ok
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00020000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 000A0000
    Partition 2
    ID : 00000004 DEMANDONOS
    Start Address : 03400000
    Partition 3
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 0B540000
    Partition 4
    Start Address : 0F640000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 0002000A000003360000000000040000000203400000081400 0000000008000000010B540000041000000000000A00000001 0F640000003C000098
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x4F (79)
    ERASE Blocks : 0x02 (2)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x1B (27)
    Device Index : 0x00
    0 : 00020000-0003FFFF
    1 : 00060000-004DFFFF
    2 : 008E0000-0B53FFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B0003000006000000 4DFFFF120B000300008E00000B53FFFF5E
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033
    Successfully Erased...
    Total blocks to write : 420
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : SOS+PMML
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [B1302F79239A2431E816565B36374B1F676A23AC]
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : SOS*UPDAPP
    >> CMT Rootkey Hash CERT : SOS*DSP0
    >> CMT Rootkey Hash CERT : LDSP
    >> CMT Rootkey Hash CERT : SOS*ISASW
    >> CMT Rootkey Hash CERT : SOS+CORE
    >> CMT Rootkey Hash CERT : SOS+ROFS1
    ImagePath: C:\FILE FLASH NOKIA\6700s+RM-576+v071.004+VIETNAM+Full\6700s RM-576 v071.004 VIETNAM Full\RM-576\
    ImageFilename: rm576_071.004_17.01_Vietnam_prd.rofs2.fpsx
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 07800000-0A73FFFF
    ERASE_REQUEST_BB5 : 5001120B000300078000000A73FFFFDC
    Total blocks to write : 130
    >> CMT Rootkey Hash CERT : SOS+ROFS2
    ImageFilename: RM576_ENO_11w02v0.049_APE.fpsx
    StartErase_DCT5...
    Device Index : 0x00
    0 : 004E0000-008DFFFF
    ERASE_REQUEST_BB5 : 5001120B000300004E0000008DFFFF05
    Total blocks to write : 14
    >> CMT Rootkey Hash CERT : SOS*ENO
    ImageFilename: rm576_071.004_UBlack507.000_prd.uda.fpsx
    StartErase_DCT5...
    Device Index : 0x00
    0 : 0B540000-0F63FFFF
    ERASE_REQUEST_BB5 : 5001120B0003000B5400000F63FFFF0F
    Total blocks to write : 17
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000003
    Additional Bad : 00000003
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 1
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:19
    (Booting time is NOT Included)
    Oct 2009
    lumia 525 treo logo flash ok
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    IMEI: 359182059023690
    Version: 1.1.1.3
    Product Code: 059V486
    Module Code: 0205952
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6137.1.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100130000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02010F011C00
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.15
    Flash App Implementation Version: 1.28
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: 25C0C84AECBD154F817825B24D4EB4BCF5E606E66228BD6A77 997ACC54710C5E
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    Finished Sending all DATA BLOCKS!
    Exiting FLASH Mode via REBOOT...
    Exit FLASH Mode Successful!
    Flashing Done!
    Oct 2009
    lumia 625h treo logo flash done
    Windows Phone 8 Flashing Started
    Loading Flash Files Please Wait...
    Windows Phone 8 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    IMEI: 356691054546623
    Version: 1.1.1.3
    Product Code: 059T4N6
    Module Code: 0205641
    Blocks Returned: 0x08 Blocks
    Block ID 0x04 : 00ECE000
    Block ID 0x05 : Nokia.MSM8227.P6083.1.2
    Card Size: 0x00ECE000
    Secure FFU Mode :
    UEFI App: FLASH APP
    ROOT_KEY_HASH: 3676E9A0045A7EF8417B8E0E0677CED5F9DD47799826AEAE75 F7081818DE716E
    Flashing Done!
    Total Flashing Time : 00:03:36
    Oct 2009
    lumia 610 treo logo flash done
    Windows Phone Flashing Started
    AMSS File Found:
    RM835_13w10_1_prod_generic_amss.esco
    WPOS File Found:
    RM835_13101_prod_269_01_boot.esco
    USER AREA ERASE File Found:
    RM835_13w10_1_prod_generic_user_area_erase.esco
    WARNING: OSBL File is not Loaded
    WARNING: MODEM ADSP File is not Loaded
    Windows Phone Lumia Flasher
    1. Press and Hold the VOLUME UP button
    2. Connect it to the USB Port while still Pressing
    3. Continue to Press the VOLUME UP button for 8 more
    seconds
    Sending AMSS Certificate
    HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717
    Certificate Size: 449 Bytes
    Status : WRITE AMSS CERTIFICATE SUCCESS
    Sending AMSS Data Blocks
    (Please Wait for 25 Seconds...)
    Status : AMSS WRITE SUCCESS
    Sending WPOS Certificate
    Certificate Size: 1460 Bytes
    Status : WRITE WPOS CERTIFICATE SUCCESS
    Sending WPOS Data Blocks
    [BLOCK 1 0x00000000~0x00FFFFFF]
    Data Size: 0x01000000 Bytes
    SHA-256 : FE9B11B8AFB2B216112555B8832BA9A4
    ---------- : AE5AE2491DB1C1AB78E5C40A5EDD317D
    Status : WPOS WRITE SUCCESS
    [BLOCK 2 0x01000000~0x0151D3FF]
    Data Size: 0x0051D400 Bytes
    SHA-256 : B050C1167AD97B37DBF09A97354102D3
    ---------- : 704FF304A5E08A2C417BA9CCF9CA5FA7
    [BLOCK 3 0x0155D400~0x01FFFFFF]
    Data Size: 0x00AA2C00 Bytes
    SHA-256 : 02119F9529BDE46521FD688646BEDFFF
    ---------- : CE9C9EC9EA31AF2BEB926318AD7E5E9F
    [BLOCK 4 0x02000000~0x02FFFFFF]
    SHA-256 : 4CB42C62FA6E45819480C845CA5669E9
    ---------- : DAAC934E2AEA0B654B3607F1E638B2D8
    [BLOCK 5 0x03000000~0x03FFFFFF]
    SHA-256 : 1C7700AE8EDABCFF7BD53F7C986EBA01
    ---------- : AECE82E11551A14CB55BF4EFE82E7154
    [BLOCK 6 0x04000000~0x04FFFFFF]
    SHA-256 : AD2B507CBCA4A85BEEE8BF9E908F1DCE
    ---------- : D1513889583206006B01B8F4B49E8883
    [BLOCK 7 0x05000000~0x05FFFFFF]
    SHA-256 : 840CB3184C35E173D840DE1A8BD14ABC
    ---------- : 10AF2CE34D072A521D0EF7616909A154
    [BLOCK 8 0x06000000~0x06FFFFFF]
    SHA-256 : 183885AEC54D7BBB65632DD01F5572E6
    ---------- : 7041A8B63BC4A1DD651A7BD3B34A5A7F
    [BLOCK 9 0x07000000~0x07FFFFFF]
    SHA-256 : D74A62C0E88618F79782FE4909517609
    ---------- : ED2BB2636E8A726C4E479A0C52B54199
    [BLOCK 10 0x08000000~0x08FFFFFF]
    SHA-256 : EA62AEC3C61F7EC006BD12D1E685AA53
    ---------- : 97B21E9489B6156FAFA88F4DF24E6818
    [BLOCK 11 0x09000000~0x09FFFFFF]
    SHA-256 : 911D615B00A148D6DB272200254C5A58
    ---------- : C27A19A21EDF9106E11023B673AC5496
    [BLOCK 12 0x0A000000~0x0AFFFFFF]
    SHA-256 : AD9D8BE8A7E03ACDF105703B6E8E7852
    ---------- : 3D33AF6EE23241A5E2DFBDFCFF1C50F3
    [BLOCK 13 0x0B000000~0x0BFFFFFF]
    SHA-256 : B42D5D271149398874BD1AADA2E96736
    ---------- : 2AD5621BC57AAF452AEA80C97812DF87
    [BLOCK 14 0x0C000000~0x0CFFFFFF]
    SHA-256 : 1D3F3513EAC00FA84B040A4990589F5C
    ---------- : 8E2AD0A348EDFC878643513C1F75809E
    [BLOCK 15 0x0D000000~0x0DFFFFFF]
    SHA-256 : D1749B42FA3A098320A36B4F9A004F36
    ---------- : 18FADACCD9AFB3B5A01A5E68B8FF38A7
    [BLOCK 16 0x0E000000~0x0EFFFFFF]
    SHA-256 : D362D617716CFA1B0E3C548A94EB8ADF
    ---------- : 5CE153BE0AAD8F8C8233622129740AA1
    [BLOCK 17 0x0F000000~0x0FFFFFFF]
    SHA-256 : 98AA2D9FA06E596353B960EE0E78ABAE
    ---------- : B3A96CBECF19C3AC68D160089E6676F7
    [BLOCK 18 0x10000000~0x10FFFFFF]
    SHA-256 : 450CA6ABC6FF9FB392A533EC6595F4D5
    ---------- : B2C064D9E4BA0DD11824DF6BA5E032FC
    [BLOCK 19 0x11000000~0x11FFFFFF]
    SHA-256 : 69DEF5E5BDE54C53DCEA7A1500E81242
    ---------- : 4DDA7C4FCE1C1164EEBA65A28686CAF1
    [BLOCK 20 0x12000000~0x12FFFFFF]
    SHA-256 : 811FD279F40BCDDADB9E44F57E1EDC68
    ---------- : 5DF4671378CF9951BD1B3A4BFD756E6F
    [BLOCK 21 0x13000000~0x13FFFFFF]
    SHA-256 : 67457D02122CD9992F0EBBE4A9C925A7
    ---------- : 6751C38E2C481D6D4F9050D86865BE74
    [BLOCK 22 0x14000000~0x14BE7BFF]
    Data Size: 0x00BE7C00 Bytes
    SHA-256 : 76C835FF4B692A8EB06DEB67D3A7DF10
    ---------- : 251053607C479EE0F2E5351ACD829953
    Sending USER AREA ERASE Certificate
    Certificate Size: 396 Bytes
    Status : WRITE ERASE CERTIFICATE SUCCESS
    Erasing USER AREA
    Status : ERASE SUCCESS
    Flashing Done!
    Total Flashing Time (Erase + Flashing) : 00:02:09
    Thành viên mới kutam_qb's Avatar
    Apr 2011
    quá dễ cho thăng bán dế
    thanh tâm
  7. ( kutam_qb ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    dinhduymobile (02-10-2014)
  8. #7
    Thành viên mới vuducdong1983's Avatar
    Jul 2016
    Xin hỏi Nokia Lumia 520, báo lỗi "Unable to find bootable option. Press any key to shut down" thì có sửa được không? Nếu sửa được thì hết bao nhiêu? Và ở Hà Nội có ai sửa dịch vụ cái này không ạ? Thanks
  1. Trả lời: 43
    Bài viết cuối: 07-08-2014, 09:15
  2. Trả lời: 91
    Bài viết cuối: 13-08-2013, 17:42
  3. Trả lời: 2
    Bài viết cuối: 27-09-2012, 17:43
  4. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  5. Trả lời: 7
    Bài viết cuối: 29-01-2011, 20:26
