Trang 16 của 16 Đầu tiênĐầu tiên ... 6 7 8 9 10 11 12 13 14 15 16
Kết quả 151 tới 159 của 159
  1. #151
    Jan 2007
    ATF Nokia Direct IMEI v12.40 Update!! 31 JUL 2015!!
    Release Date: July 31, 2015
    Firmware Version Required : 11.0.10 or 11.0.12
    ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
    ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
    Nokia Android Total Updates
    1. Boot Repair via USB for Nokia X, X+, XL, XL 4G via "Qualcomm HS-USB Diagnostics 9006" Interface ONLY
    * Boot repair is done via "eMMC Drive" Tab. You can use regular .mmc files to repair the BOOT.
    * You can download .mmc repair files from here:
    GSM-Forum - View Single Post - <<<<<< All Lumia/Android Dead Boot Repair Files -[Added Lumia 540, 1320, 925] >>>>>>
    *** VERY IMPORTANT ***
    * "Qualcomm HS-USB Diagnostics 9008" <-- NINE-ZERO-ZERO-EIGHT is still NOT SUPPORTED for USB ONLY BOOT REPAIRS
    * You still need JTAG or eMMC Connection to repair 9008 aka "Nokia Emergency Connectivity"
    * ONLY NINE-ZERO-ZERO-SIX (9006) is supported for USB BOOT REPAIR (Dead due to bad custom rom etc...)
    * Again... 9006 is not 9008...
    2. Factory Phone Identity Programming for Nokia X, X+, XL, XL 4G and X2
    * Factory Method Repair/Restore Blank or "null" IMEI due to erased EFS (modem_st1, modem_st2, modem_fsg)
    * Factory Method Repair/Restore Bluetooth MAC
    * Factory Method Repair/Restore WLAN MAC
    * Factory Method Full Restore RF Tunings and other Baseband Configuration (NV + QCN Items)
    * Factory Programming is done via the "Factory" tab under "IMEI and Simlocks"
    * It will use Specially Made USB Drivers from:
    C:\AdvanceBox Turbo Flasher\Driver\NOKIA_ANDROID_FACTORY\
    and
    C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\
    Watch Here to Learn How to Install these USB Drivers!
    http://*********/Bn9W72OTef8
    3. Improved Identity Backup (IMEI Simlocks etc) for Nokia X, X+, XL, XL 4G and X2
    * Does not need USB Debugging Enabled
    Some Nokia/Microsoft Lumia Updates
    Boot Repair via eMMC Connection + eMMC Firmware Update Support
    *** Make sure you backup first 512MB of eMMC USER AREA Before Performing eMMC Firmware Update ***
    Lumia 540 DS [RM-1040] 02074.10000.15174.44001 - First In The World
    Lumia 540 DS [RM-1041] 02074.10000.15174.44001 - First In The World
    Lumia 1320 [RM-994] 3056.40200.1407.0004 - First In The World
    Lumia 1320 [RM-995] 3056.40000.1401.1001 - First In The World
    Lumia 1320 [RM-996] 3056.40200.1407.0002 - First In The World
    Lumia 925 [RM-892] 3051.50009.1451.1 - First In The World
    Lumia 925 [RM-893] 3051.50009.1451.1 - First In The World
    Lumia 925 [RM-910] 3051.50009.1424.0004 - First In The World
    Lumia 925T [RM-955] 3051.50009.1424.0002 - First In The World
    Bonus Update:
    USB Boot Repair for GT-i9505 Lollipop 5.0.1 !!! - First In The World
    Find it at "ATF Plus" ----> "Factory Boot"
    Factory Boot now supports "Qualcomm" or "Nokia Emergency Connectivity" Drivers
    Various USB Driver Updates:
    Updated "Nokia Emergency Connectivity" Drivers
    C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\EmergencyDownl oadDriver.msi
    New "Nokia Android Factory Drivers"*
    Updated Nokia X Drivers*
    * Unsigned Drivers MAY NOT Work with Win8 and Win10 64-Bit Machines
    Mediafire
  2. ( namnhatrang ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    dotrong_dt1 (04-08-2015), toilatoi3000 (07-06-2016)
  3. #152
    Jan 2007
    [B]ATF v12.50 Update!! 28 OCT 2015!![/B]
    Release Date: October 28, 2015
    ATF Box USB Driver Required: 2.12.06 - Windows 10 (32-bit and 64-bit) - Available in Windows Driver Update Server
    ATF Box USB Driver Required: 2.12.06 - Windows 8.1 (32-bit and 64-bit) - Available in Windows Driver Update Server
    ATF Box USB Driver Required: 2.12.06 - Windows 8 (32-bit and 64-bit) - Available in Windows Driver Update Server
    ATF Box USB Driver Required: 2.12.06 - Windows 7 (32-bit and 64-bit) - Available in Windows Driver Update Server
    Official Windows 10 32-bit/64-bit Support
    We have now provided SIGNED 32-bit and 64-bit Drivers for Windows 10 Operating System.
    Windows 10 will automatically download the new ATF Drivers from the Windows Driver
    Update Server if your PC is connected to the Internet.
    You can also manually install them from the usual location:
    C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\
    Few Improvements:
    1. Fixed WinXP Incompatibility with "Qualcomm HS-USB Diagnostics 9006" Boot Repair.
    2. Updated WinUSB 32-bit and 64-bit drivers for Nokia Lumia and Android devices.
    DOWNLOAD HERE:
    ATF V12.50 Full Installer
  4. #153
    Jan 2007
    ATF Lumia 950 XL DS WinPhone 10 Full Flashing !!! - FIRST IN THE WORLD
    INFO: You need ATF Software Version 12.55 so that you can flash Lumia 950, 950 XL and 550 Windows 10 Phones. You can download it via the AUTOUPDATE SERVER!
    Flash Files for Lumia Phones will be made available on ATF UPDATE 12.60 this month. We will integrate a firmware search engine and download accelerator for this update. If you need specific flash files right now for 950, 950XL and 550 phones, please post your preferred PRODUCT CODE or COUNTRY VARIANT and I will post the links.
    ATF Lumia 950 XL DS WinPhone 10 Full Flashing!
    Also check out other Lumia WinPhone 8.0/8.1/10 Phones Flashed by ATF:
    Microsoft Lumia 430 DS - Fully Tested
    Microsoft Lumia 435 DS - Fully Tested
    Nokia Lumia 520 - Fully Tested
    Nokia Lumia 530 - Fully Tested
    Nokia Lumia 620 - Fully Tested
    Nokia Lumia 625 - Fully Tested
    Nokia Lumia 630 - Fully Tested
    Nokia Lumia 638 - Fully Tested
    Nokia Lumia 720 - Fully Tested
    Nokia Lumia 735 DS - Fully Tested
    Nokia Lumia 810 - Fully Tested
    Nokia Lumia 820 - Fully Tested
    Nokia Lumia 822 - Fully Tested
    Microsoft Lumia 830 - Fully Tested
    Nokia Lumia 920 - Fully Tested
    Nokia Lumia 925 - Fully Tested
    Nokia Lumia 928 - Fully Tested
    Microsoft Lumia 929 - Fully Tested
    Microsoft Lumia 930 - Fully Tested
    Microsoft Lumia 950 XL (WP10) - Fully Tested
    Nokia Lumia 1020 - Fully Tested
    Nokia Lumia 1320 - Fully Tested
    Nokia Lumia 1520 - Fully Tested
    Microsoft Lumia 950 XL DS WinPhone 10 Flashed Successfully with ATF
    Here are the Screenshot:
    Here is the Flashing Logs:
    Code:
     Windows Phone 8/8.1/10 Flashing Started
    Loading Flash Files Please Wait...
    Windows Phone 8/8.1/10 Lumia Flasher
    If the Phone is ALIVE
     1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
     1. Connect Phone to the USB Port
     2. Press and Hold the VOLUME DOWN and POWER Buttons
     3. Wait until the Phone Vibrates Shortly...
     4. Stop Pressing the Buttons...
    If the Phone is DEAD BOOT
     2. Install Correct Drivers:
     "Nokia Emergency Connectivity" Located at:
    Basic Phone Information
    SW Version : 01078.00027.15506.02003
    IMEI Plain : 351832071215140
    IMEI2 Plain : 351832071215157
    Phone Type : RM-1116
    HW Version : 4031
    Product Code : 059X5W2
    Basic Product Code: 059W743
    Module Code : 0206453
    PSN Number : C204702AU
    Operator Name : 000-88
    Phone Version : BuildDate : Dec 12 2015 , BuildType : Release , HelloString : NCSd for WP10 , Version : 8.4
    Manufacturer ID : RM-1116_11284
    Security Mode : Restricted
    Extended Phone Information
    Public ID : B44E0FDFB4B0F7501AA852BF8D4E547DFB141387
    Wireless Lan 0 ID: 38:F2:3E:8D:5C:10
    Wireless Lan 1 ID: 38:F2:3E:8D:5C:11
    Wireless Lan 2 ID: 38:F2:3E:8D:5C:12
    Wireless Lan 3 ID: 38:F2:3E:8D:5C:13
    Bluetooth ID : 38:F2:3E:8B:9F:E4
    Simlock Information
    SIMLOCK STATE : Not Locked
    Booting Flash Mode Initiated...
    Please wait upto 15 Seconds for HW Reset
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x09 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x1F : 01
    Block ID 0x02 : 00240000
    Block ID 0x03 : 03A3E000
    Block ID 0x05 : Microsoft.MSM8994.P6211.2.1
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 01000F0000
    Block ID 0x20 : 010000000100000004
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 020229024B00
    UEFI App: FLASH APP
    Flash App Protocol Version: 2.41
    Flash App Implementation Version: 2.75
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: 427D8FD5A7F227820D5B11BF8C6F7670C0A0622CC61BA95AAEE18F7517FC0B77
    Query PUBLIC ID...
    PUBLIC_ID: B44E0FDFB4B0F7501AA852BF8D4E547DFB141387
    Query eMMC Info...
    EMMC Manufacture ID: HYNIX
    EMMC Product SN : 1466C875
    EMMC_SIZE: 32 Gigabytes
    Query Battery Charge Status...
    BATTERY CHARGE_STATUS: 99%
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    Finished Sending all DATA BLOCKS!
    Exiting FLASH Mode via REBOOT...
    Exit FLASH Mode Successful!
    Flashing Done!
    Total Flashing Time : 00:08:42
    Here is our Test Phone...
    FLASHING The Phone...
    BOOT Repair Tests will follow
    BR
    X-Shadow
  5. #154
    Jan 2007
    ATF USB Dead Boot Repair v12.60 Update!! Public Discuss Thread: [HR][/HR]
    Release Date: February 5, 2016
    Introducing the EASIEST Method to DOWNLOAD the NEWEST Lumia Firmware Files... NaviSearch!
    Lumia Firmware Search and Download
    * Very Simple Interface, select via Variant List or Product Code List
    * Complete Variant Packs (Product Codes) of all Lumia phones including Lumia 950 XL, 950 and 550.
    * Download via ATF Built-in Downloader or Export Download List to your favorite Download Managers
    * Download STOP and RESUME Function
    * Automatically verifies Downloaded File Checksum
    * File Download is done in the background... You can flash phones etc while downloading files.
    *** FOR NOW, NaviSearch is only Enabled for LUMIA PHONES. It will Enabled in the future for older BB5 Phones ***
    New Phones Supported for Dead Boot Repair via USB Cable Only
    (Most of these Models are First in the World)
    Lumia 950 XL (RM-1085)
    Lumia 950 XL DS (RM-1116)
    Lumia 950 (RM-1104)
    Lumia 950 (RM-1105)
    Lumia 950 (RM-1118)
    Lumia 550 (RM-1128)
    Lumia 550 (RM-1127)
    Lumia 640 LTE DS (RM-1113)
    Lumia 640 DS DTV (RM-1109)
    Lumia 640 DS (RM-1077)
    Lumia 640 LTE DS (RM-1075)
    Lumia 640 (RM-1073)
    Lumia 640 LTE (RM-1072)
    Lumia 640 XL DS (RM-1067)
    Lumia 640 XL (RM-1066)
    Lumia 640 XL LTE (RM-1062)
    Lumia 1030 (RM-1052)
    Lumia 1030 (RM-1051)
    Lumia 1030 (RM-1050)
    Lumia 820 (RM-826)
    Lumia 625 (RM-943)
    Official Download Link
    ATF V12.60 Full Installer
  6. #155
    Jan 2007
    ATF 12.66 AutoUpdate
    Release Date: February 15, 2016
    ** YOU CAN ONLY DOWNLOAD THIS VIA THE AUTO-UPDATE SERVER **
    eMMC Tool 5.00 (PRO)
    --> Added Support for eMMC Flashing (Direct Write) for Samsung Exynos 7 Octa 7580 Based Phones
    Check Tutorial Here for SM-J700:
    Samsung SM-J700F/H/K/M/P/8 BOOT Repair via eMMC Flashing - GSM-Forum
    Samsung SM-J7008
    Samsung SM-J700F
    Samsung SM-J700H
    Samsung SM-J700K
    Samsung SM-J700M
    Samsung SM-J700P
    8/F/H/K/M/P
    Samsung SM-A310F
    Samsung SM-A310M
    Samsung SM-A310N0
    Samsung SM-A310Y
    Samsung SM-A5108
    Samsung SM-A510F
    Samsung SM-A510K
    Samsung SM-A510L
    Samsung SM-A510M
    Samsung SM-A510S
    Samsung SM-A510Y
    Samsung SM-A710F
    Samsung SM-A710K
    Samsung SM-A710L
    Samsung SM-A710M
    Samsung SM-A7100
    Samsung SM-A710S
    Samsung SM-A710Y
    Samsung SM-G903F
    Samsung SM-G903FD
    Samsung SM-G903M
    Samsung SM-G903W
    Samsung SM-T670
    Samsung SM-T677A
    Samsung SM-T677K
    Samsung SM-T677L
    Samsung SM-T677V
    --> Now you can Repair DEAD BOOT Repair these phones via eMMC Connection.
    --> Just Download the NEWEST Firmware from
    www.s-a-m-m-o-b-i-le.com and WRITE it
    --> to your phone via eMMC Connection. This will repair both BOOT1 and BOOT2
    --> Partitions.
    Image Tool - Samsung Unbrick Image Creator 3.0
    --> Added Support for 4 More Exynos CPUS:
    Samsung Exynos 5 Hexa 5260
    Samsung Exynos 4 Quad 4415
    Samsung Exynos 3 Quad 3475
    --> Now you can Create SD Card Unbrick files for phones Based on these CPUs.
    Lumia 950 (RM-1104)
    Lumia 950 (RM-1105)
    Lumia 950 (RM-1118)
    Lumia 550 (RM-1128)
    Lumia 550 (RM-1127)
    Lumia 640 (RM-1073)
    Lumia 820 (RM-826)
    Lumia 625 (RM-943)
    Who will buy this if you can get more in ATF?
    __________________________________________________ ________________________
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    ATF USB Dead Boot Repair v12.66 Update
    The Master Piece
  7. #156
    Jan 2007
    Samsung SM-J7008
    Samsung SM-J700F
    Samsung SM-J700H
    Samsung SM-J700K
    Samsung SM-J700M
    Samsung SM-J700P
    8/F/H/K/M/P
    Samsung SM-A310F
    Samsung SM-A310M
    Samsung SM-A310N0
    Samsung SM-A310Y
    Samsung SM-A5108
    Samsung SM-A510F
    Samsung SM-A510K
    Samsung SM-A510L
    Samsung SM-A510M
    Samsung SM-A510S
    Samsung SM-A510Y
    Samsung SM-A710F
    Samsung SM-A710K
    Samsung SM-A710L
    Samsung SM-A710M
    Samsung SM-A7100
    Samsung SM-A710S
    Samsung SM-A710Y
    Samsung SM-G903F
    Samsung SM-G903FD
    Samsung SM-G903M
    Samsung SM-G903W
    Samsung SM-T670
    Samsung SM-T677A
    Samsung SM-T677K
    Samsung SM-T677L
    Samsung SM-T677V
    --> Partitions.
    Lumia 950 (RM-1104)
    Lumia 950 (RM-1105)
    Lumia 950 (RM-1118)
    Lumia 550 (RM-1128)
    Lumia 550 (RM-1127)
    Lumia 640 (RM-1073)
    Lumia 820 (RM-826)
    Lumia 625 (RM-943)
    Philippine: Gsmph
    The Master Piece
  8. #157
    Jan 2007
    ATF USB Dead Boot Repair v12.67 Update!! Public Discuss Thread: [HR][/HR]
    ATF 12.67 AutoUpdate
    Release Date: February 26, 2016
    This update addresses ATF Nitro/Lightning New Box Activation Problems due to bad DNS in certain countries.
    Nothing else was changed.
    Download this update if you have Activation Problems ONLY.
    B.R.
    X-Shadow
    Samsung SM-J7008
    Samsung SM-J700F
    Samsung SM-J700H
    Samsung SM-J700K
    Samsung SM-J700M
    Samsung SM-J700P
    8/F/H/K/M/P
    Samsung SM-A310F
    Samsung SM-A310M
    Samsung SM-A310N0
    Samsung SM-A310Y
    Samsung SM-A5108
    Samsung SM-A510F
    Samsung SM-A510K
    Samsung SM-A510L
    Samsung SM-A510M
    Samsung SM-A510S
    Samsung SM-A510Y
    Samsung SM-A710F
    Samsung SM-A710K
    Samsung SM-A710L
    Samsung SM-A710M
    Samsung SM-A7100
    Samsung SM-A710S
    Samsung SM-A710Y
    Samsung SM-G903F
    Samsung SM-G903FD
    Samsung SM-G903M
    Samsung SM-G903W
    Samsung SM-T670
    Samsung SM-T677A
    Samsung SM-T677K
    Samsung SM-T677L
    Samsung SM-T677V
    --> Partitions.
    [B]
    Lumia 950 (RM-1104)
    Lumia 950 (RM-1105)
    Lumia 950 (RM-1118)
    Lumia 550 (RM-1128)
    Lumia 550 (RM-1127)
    Lumia 640 (RM-1073)
    Lumia 820 (RM-826)
    Lumia 625 (RM-943)
  9. #158
    Jan 2007
    down cái này intall xong update lên
  10. #159
    Jan 2007
    ATF v12.70 Update!! 31 MAR 2017!!
    B.R.
    X-Shadow
    Samsung SM-J7008
    Samsung SM-J700F
    Samsung SM-J700H
    Samsung SM-J700K
    Samsung SM-J700M
    Samsung SM-J700P
    8/F/H/K/M/P
    Samsung SM-A310F
    Samsung SM-A310M
    Samsung SM-A310N0
    Samsung SM-A310Y
    Samsung SM-A5108
    Samsung SM-A510F
    Samsung SM-A510K
    Samsung SM-A510L
    Samsung SM-A510M
    Samsung SM-A510S
    Samsung SM-A510Y
    Samsung SM-A710F
    Samsung SM-A710K
    Samsung SM-A710L
    Samsung SM-A710M
    Samsung SM-A7100
    Samsung SM-A710S
    Samsung SM-A710Y
    Samsung SM-G903F
    Samsung SM-G903FD
    Samsung SM-G903M
    Samsung SM-G903W
    Samsung SM-T670
    Samsung SM-T677A
    Samsung SM-T677K
    Samsung SM-T677L
    Samsung SM-T677V
    --> Partitions.
    Lumia 950 (RM-1104)
    Lumia 950 (RM-1105)
    Lumia 950 (RM-1118)
    Lumia 550 (RM-1128)
    Lumia 550 (RM-1127)
    Lumia 640 (RM-1073)
    Lumia 820 (RM-826)
    Lumia 625 (RM-943)
    Philippine: Gsmph
    The Master Piece
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
