Trang 14 của 16 Đầu tiênĐầu tiên ... 4 5 6 7 8 9 10 11 12 13 14 15 16 CuốiCuối
Kết quả 131 tới 140 của 159
  1. #131
    Jan 2007
    TF v11.82 Update!! Public Discussion Thread:
    Release Date: November 28, 2014
    Firmware Version Required : 11.0.00
    ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
    ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
    ATF 11.82
    *** GET THIS UPDATE VIA AUTO-UPDATE SEVER ***
    Or Download Manually Here:
    http://174.120.45.27/current_exe/AdvanceBox.exe
    [Bug Fixes]
    1. Window Phone "Extra File Loaded" Bug In Flashing --- FIXED
    2. Auto Update Feature of EXE now FIXED
  2. #132
    Nov 2010
  3. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thaigsm181 (19-12-2014)
  4. #133
    Jan 2007
    Release Date: December 21, 2014
    ATF 11.88
    What's Cooking?
    Lumia WP8/WP8.1 BOOT Repair via USB is now Supported for Retail Lumia Phones:
    Lumia 920 (RM-820, RM-821, RM-867)
    Lumia 820 (RM-824, RM-825)
    Lumia 620 (RM-846)
    Lumia 928 (RM-860)
    Lumia 1020 (RM-875, RM-876, RM-877)
    Lumia 720 (RM-885, RM-887)
    Lumia 925 (RM-892, RM-893, RM-910, RM-955)
    Lumia 520 (RM-913, RM-914, RM-915, RM-917)
    Lumia 625 (RM-941, RM-942, RM-943)
    Lumia 1320 (RM-994, RM-995, RM-996)
    Lumia 525 (RM-997, RM-998)
    The procedure is very simple, just Flash the Phone like you Normally would without clicking any more additional options. ATF will detect your phone's current STATE and will perform the necessary Tasks to Revive it.
    Please make sure that YOU MUST USE ONLY the 'Nokia Emergency Connectivity" Drivers because as for now, any other 9008 drivers such as Qualcomm and Zeus (Sony) it not supported for USB BOOT Repair.
    You must also click "UPDATE IMPORTANT FILES" so that you will be able to download the MPRG Loaders that will be used for USB BOOT Repair.
    More will come after a short Holiday Leave.
    If you find problems with ATF 11.88 (Because it was done very quickly)
    Then Please do not use it.
    B.R.
    X-Shadow
  5. ( namnhatrang ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    HQDuan_GSM (05-01-2015), tranvantinh (25-12-2014)
  6. #134
    Jan 2007
    ===>>> ATF eMMC Test Point Finder Tutorial <<<===
    Reserved #1 : How to make tp cable
    Very Simple TP Cable Schematics
    Sample of Home Made Cable
    Reserved #2 : How to find CLK and CMD
    Please Take Note of the Following Items before Attempting to Find CLK and CMD:
    1. Make sure you connect Positive (+) and Negative (-) Terminals Properly and Correctly.
    2. Make sure POWER BUTTON is ALWAYS PRESSED
    3. DO NOT Connect USB Cable to Phone
    3. Allow at least 2 Tries per possible Location on the PCB
    4. DO NOT Exert Too Much Force on the Resistors as they may COME OFF!!!
    5. For Exynos Based Phones, you can only Find CLK using this method. CMD Can be found using another Method.
    6. Not all Phones have exposed CLK or CMD Locations on the PCB.
    7. Not all Phones are supported with this NEW TP FINDER Method. ATF Team will continue to improve it via UPDATES.
    STEP 1: Connect Power Positive (+) and Negative (-) to the Phone's Battery Terminal
    STEP 2: Make Sure Power Button is Always Pressed. Use Rubber Band or Tie Cables.
    STEP 3: Setup ATF Software settings such as REPEAT and INTERVAL for your convenience
    REPEAT <--- Number of Times TP Finder will Loop Itself Automatically
    INTERVAL <--- Delay in Seconds before the next TP Finder Operation will Start
    STEP 4: Start Connecting Test Point PIN to Resistors/TP Pads on the Phone's PCB around the eMMC Area.
    Wait for Message "Please Check Another Location..." before trying other TP Locations
    On ATF BIG Chrome Box, change TP Location when GREEN LED will Power OFF
    On ATF Nitro/Lightning Box, change TP Location when BLUE LED will Power OFF
    In this Example, I tried all the Locations that were marked with RED
    DO NOT TRY TO TP a CAPACITOR, it is NEVER CORRECT
    Capacitors are BROWN in COLOR
    Resistors are BLACK in COLOR
    ONLY TRY TO TP Resistors and Test Point Pads around eMMC Area
    When a correct Test Point is Found, you will see similar Message Below.
    The message also shows you the PINOUT of ATF RJ-45 Socket for the proper connection of the Test Point Found.
    If Test Point is not Found Around the eMMC Area, you can try looking for it around the CPU Area.
  7. #135
    Jan 2007
    ATF EMMC Pin Finder v11.92 Update!!
    Release Date: February 3, 2015
    Firmware Version Required : 11.0.10
    ATF 11.92
    What's Cooking?
    ALL FIRST-IN-THE-WORLD SOLUTIONS COMING from the INVENTORS of eMMC Test Point Programming.
    Find DATA for Qualcomm Based CPU Now Supported
    Find CMD for Exynos Based CPU Now Supported
    Find DATA for Exynos Based CPU Now Supported
    Find Vcc for Exynos Based CPU Now Supported
    Find DATA for Marvell PXA Based CPU Now Supported
    Find Vcc for Marvell PXA Based CPU Now Supported
    Find DATA for Broadcom Based CPU Now Supported
    Find Vcc for Broadcom Based CPU Now Supported
    Added Sampling Rate Multiplier
    Added "Save Samples" Option
    The procedure to find eMMC Test Points without physically
    removing eMMC is a FIRST-IN-THE-WORLD INNOVATION by
    ATF Team.
    For More Information about this process, please refer to this link:
    Discuss Here:
    will be able to download the latest Files that will be used for 11.92.
    B.R.
    X-Shadow
    Release Date: January 30, 2015
    [New ATF Box Firmware]
    LogiCore 11.0.10
    * Added FIRST-IN-THE-WORLD eMMC Test Point Finder/Locator Engine
    * Improved eMMC Read/Write Speeds
    * Added more VCCIO Level Adjustments options
    [ATF Plus]
    * Added Find eMMC TP - eMMC Test Point Finder 1.0
    * Absolutely FIRST-IN-THE-WORLD Feature which allows you to Locate the eMMC
    Programming Test Points WITH-OUT Removing the eMMC Chip from the PCB.
    * Supports Qualcomm, Marvell PXA and Broadcom CPU for CMD and CLK Detection
    * Supports Exynos for CLK Test Point Detection
    * Other CPUs will be supported soon
    For More Information, Check here:
    ===>>> ATF eMMC Test Point Finder Tutorial <<<=== - GSM-Forum
    [GENERAL UPDATES]
    --> Added all variants of Microsoft Lumia 330 in Nokia.ini
    ATF JTAG 1.0.13 Build 5935
    Firmware Version Required : LogiCore 11.0.10
    Change Log
    --> Uses new ATF Firmware LogiCore 11.0.10
    --> Adjusted eMMC Read/Write Timeouts
  8. #136
    Jan 2007
    ATF Gold v12.00 Update!! 27 FEB 2015!!
    ATF is Now ALL-IN... Are You IN?
    ATF Team is Celebrating our 5th Year Anniversary for the First ATF Chrome Metal Box (Launched February 2010).
    To Celebrate this Special Event, we are Now Launching a Very Special Limited Edition 5-Year Anniversary GOLD BOX.
    Unique Aesthetic Features Includes:
    High Quality Gold Plated Aluminum Case (Fingerprint Proof)
    Double Coated White Front and Back Panels (Stain Proof)
    Limited Edition White Metallic Sticker Label (We Just Changed the Color...)
    Special Activations Included (ALL-IN):
    39 ATF JTAG Credits : Pre-Installed
    49 ATF Network Credits : Pre-Installed
    Outstanding Box Features:
    * It's GOLD
    * USB 2.0 HS 480mbps
    * Fastest JTAG Read/Write Speeds for Qualcomm CPUs (30 Mhz)
    * Built-In VBATT Power Supply for Powering Phones during JTAG Procedures (4.20V on RJ-45 PIN 1)
    * Fastest eMMC Read/Write Speeds for Any CPU for 1-BIT @ SDR 15 Mhz
    * Built-In eMMC Single Power Supply (3.00V on RJ-45 PIN 2)
    * First in the WORLD eMMC Pinout Finder for Supported CPUs
    * Built-In Micro SD Card Slot for:
    ---> Multi-Lingual SD Password Bruteforce (ATF is still the ONLY Box who can do this...)
    ---> SD Card "Force Format"
    ---> Samsung SDC Unbrick Creator using Official Samsung TAR.MD5 BL Flash Files
    ---> SD Card Low Level Read/Write (Operating System Bypass)
    * SPI ISP Chip Programming with Built-In Power Supply
    * Still the Fastest Nokia FBUS Flasher for 5 YEARS and Counting!
    Bonus Material:
    Free Preview of ATF Professional eMMC Tool 3.0 (APeT 3.0)
    * Removes Permanent WP Bit on ALL Samsung Brand eMMC (First in The World)
    ---> Fixes "Unable to find a bootable Option." on Nokia/Microsoft Lumia Phones (WITHOUT IMEI AND SIMLOCK DATA LOSS)
    ---> Fixes "eMMC is Read Only you cannot update your System" on Huawei Phones (WITHOUT IMEI AND SIMLOCK DATA LOSS)
    * Field Firmware Update on Selected Samsung Brand eMMC
    ---> Fully Repairs eMMC Firmware Bugs such as:
    ------> No Name eMMC "000000" Bug
    ------> Read/Write Disabled Bug
    ------> eMMC Firmware Erased/Corrupted Bug
    Currently Supported Samsung eMMC Models for Field Firmware Update (FFU)
    ***** DO NOT CROSS FLASH WRONG EMMC MODEL WITH NON MATCHING PART NUMBERS *****
    ***** THIS WILL KILL YOUR EMMC 100% AND IT WILL BECOME USELESS AND DEAD *****
    BGA-169/153
    NAME : PART NUMBER : Can be found on...
    L5U00M : KML5U000HM-B505 : GT-i8262
    M4G1FB : KLM4G1FE3B-B001 : ZTE U970/N970/V970/U930...
    M8G1WA : KLM8G1WE4A-A001 : GT-i9082, GT-i9082L
    MAG4FB : KLMAG4FE4B-B002 : GT-i747, GT-i747m, GT-i9305, GT-P6800, SCH-i935v, SCH-i535, SGH-T999, SCH-R530, SCH-R530c
    SJS00M : KMSJS000KM-B308 : GT-S5302, GT-S7500, GT-S6500D, Huawei G300...
    VTU00M : KMVTU000LM-B503 : GT-N7100, GT-i9300
    VUS00A : KMVUS000LA-B304 : GT-N7100, GT-i9300
    BGA-162
    K8U00M : KMK8U000VM-B410 : China Phones
    KJS00M : KMKJS000VM-B309 : SGH-T769,
    NJS00M : KMNJS000ZM-B205 : Huawei G520-0000
    * Write Official Samsung TAR.MD5 Files via eMMC Connection
    ---> Now you can Repair Boot of any NEW Samsung Phone based on Qualcomm, Exynos, Broadcom,
    Marvell and Spreadtrum CPUs by just using OFFICIAL Samsung BL Flash Files. NO MORE
    WAITING FOR PRODUCT SUPPORTERS TO MAKE BOOT REPAIR PACKAGES!!!
    * Improved eMMC Test Point Finder 1.5
    ---> Now Supports Newest Qualcomm APQ8084 Phones (SM-N910F, N9109W, N910A, N915D, N9108V, N9100, G901F)
    ATF Professional eMMC Tool 3.0 Removes the time to wait for other JTAG/eMMC Boxes to Support Your NEW Samsung Phone.
    Just think about this Scenario when Customer Brings you an Unsupported NEW Phone for Boot Repair...
    1. Disassemble the Phone and Locate the eMMC Pinout using ATF eMMC Test Point Finder
    2. Download Official Samsung TAR.MD5 BL Flash File or ALL-IN-ONE Flash File from the Internet
    3. Write this flash file via eMMC Connection using ATF eMMC Tool
    Now Phone Boot is Repaired!
    No need to blah blah in forum "Please Support this Phone XX-XXX"... You can do the JOB on your OWN! - FEEL THE REAL POWER
    Simple FAQ about APeT 3.0:
    Q: Can I use Large ALL-IN-ONE TAR.MD5 Files which I downloaded freely from Internet?
    A: Yes, just as long as the ALL-IN-ONE File have complete BOOTLOADERS Inside.
    Q: Where can I find official TAR.MD5 BL (BOOTLOADER) Files?
    A: You can find them on Paid GSM File Servers. (You Pay them for a Reason)
    Q: I don't want to PAY... Will ATF Team upload these BL Files in their Server for End Users to Download?
    A: Yes, but as of now we are still busy COLLECTING BL Files.
    Q: Will writing Official TAR.MD5 erase my EFS, Modemst1, modemfsc etc?
    A: No, it will just flash the phone like ODIN but via eMMC Connection.
    Q: Will writing Official TAR.MD5 FIX my efs.img.ext4, modemst1, modemfsc, mdm1m9kefs1 etc?
    A: No, other steps are needed to fix them after a Successful BOOT Repair.
    Q: Will writing official TAR.MD5 revive my phone which was killed by Wrong Unlocking Methods?
    A: Depends on Phone Model and Security Level. We found newer phones have difficulty reviving after Wrong Unlocking Methods.
    Q: Can I use TAR backups made by other tools?
    A: No. If the TAR is NOT OFFICIAL, ATF will NOT support it.
    Q: Will it fix MBR, GPT, PIT problems like when a Brand New BLANK eMMC is used?
    A: Yes, it has a "Re-Partition" Option like ODIN... Provided you have the correct PIT File for your Phone.
    Q: So NEW Samsung Phones are Supported... But how about OLDER Samsung Phones?
    A: Currently only Samsung Android Phones using GUID Partition Tables are supported.
    Q: Will ATF Professional eMMC Tool (APeT) always be FREE for ALL ATF End Users?
    A: For Now Yes... But further research on newer More Expensive Phones might require us to charge a small fee for practical reasons.
    Q: I always have problems connecting eMMC on Phone PCB, what do you think is my Problem?
    A: If the problem is not your SKILL, then it is your eMMC Power Adapter. Try to use Original SmartGSM 4-in-1 V2 Adapters.
    Who will buy this if you can get more in ATF?
    __________________________________________________ ________________________
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
    DOWNLOAD HERE:
    ATF_v12.00_Full_Installer.rar
  9. #137
    Jan 2007
    * It's GOLD
    Bonus Material:
    BGA-169/153
    BGA-162
    DOWNLOAD HERE:
  10. #138
    Jan 2007
    ATF Autoupdate 12.03 - March 3, 2015
    ATF Auto-Update 12.03
    March 3, 2015
    eMMC Tool 3.01
    ---> Added Support For Texas Instrument OMAP 4430, 4460, 4470 CPU for direct TAR.MD5 write via eMMC Connection.
    ---> Now writes Absolute Partition Sizes as reported in GPT or PIT.
    * Fixed BUG on Detection of SK Hynix, Toshiba and Sa.nDisk eMMCs
    * It's GOLD
    Bonus Material:
    BGA-169/153
    BGA-162
    Philippine: Gsmph
  11. #139
    Jan 2007
    March 3, 2015
    eMMC Tool 3.01
    * It's GOLD
    Bonus Material:
    BGA-169/153
    BGA-162
    Philippine: Gsmph
  12. #140
    Jan 2007
    ATF Auto-Update 12.05
    March 4, 2015
    eMMC Test Point Finder 1.6
    ---> Added Support For Spreadtrum CPU for Detecting CMD, CLK, DATA, VccQ and Vcc in eMMC Test Point Finder.
    * ATF Nitro and Lightning Boxes Needs SmartGsm 4-in-1 Adapter to find eMMC Test Points on Spreadtrum Based Phones.
    More Information About TP Finder Cable Here:
    http://forum.gsmhosting.com/vbb/f609/atf-emmc-test-point-finder-tutorial-1908984/
    March 3, 2015
    eMMC Tool 3.01
    * It's GOLD
    Bonus Material:
    BGA-169/153
    BGA-162
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
