Trang 13 của 16 Đầu tiênĐầu tiên ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CuốiCuối
Kết quả 121 tới 130 của 159
  2. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    dinhduymobile (03-10-2014)
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    Link download => ATF_v11.60_Full_Installer
  4. ( THIÊN UY™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    gamoi.gsm (24-07-2014)
  5. #3
    Nov 2010
    YOU NEED TO UPDATE TO ATF 11.69 or HIGHER BEFORE FLASHING Lumia 930 and other WP 8.1 Phones.
    Download ATF version 11.69 EXE Here:
    AdvanceBox.exe version 11.69 <-------- Download and put in C:\AdvanceBox Turbo Flasher\
    Also Download Nokia.ini Update here:
    Nokia.ini <------- Download and put in C:\AdvanceBox Turbo Flasher\Nokia\
    ATF First In The World Lumia 930 WinPhone 8 Full Flashing!
    Also check out other Lumia WinPhone 8 Phones Flashed by ATF:
    ATF First In The World Lumia 520 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 620 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 625 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 630 WinPhone 8.1 Full Flashing!
    ATF First In The World Lumia 638 4G WinPhone 8.1 Full Flashing!
    ATF First In The World Lumia 720 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 810 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 820 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 822 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 920 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 925 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 928 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 930 WinPhone 8.1 Full Flashing!
    ATF First In The World Lumia 1020 (Nokia 909) WinPhone 8 Full Flashing!
    ATF First In The World Lumia 1320 WinPhone 8 Full Flashing!
    ATF First In The World Lumia 1520 WinPhone 8 Full Flashing!
    You Can Download Flash Files Here:
    Nokia Product Code Listing for Care Suite Download - (Nokia 530, 636, 638, 930 Added)
    Microsoft Lumia 930 WinPhone 8.1 Flashed Successfully with ATF 11.69...
    Here are the Screenshot:
    Here is the Flashing Logs:
    Code:
    Windows Phone 8 Flashing Started
    Loading Flash Files Please Wait...
    Windows Phone 8 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    Basic Phone Information
    SW Version : 02061.00066.14252.51003
    IMEI Plain : 353633062907440
    HW Version : 2002
    Product Code : 059W0D5
    Basic Product Code: 059V7M4
    Module Code : 0206071
    PSN Number : CCP679930
    Manufacturer ID : RM-1045_1034
    Operator Name : 000-PH
    Phone Version : BuildDate : Jun 5 2014 , BuildType : Release , HelloString : NCSd for WP8 , Version : 4.5
    Security Mode : Restricted
    Simlock Information
    SIMLOCK STATE : Not Locked
    Booting Flash Mode Initiated...
    Please wait upto 15 Seconds for HW Reset
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x09 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x1F : 01
    Block ID 0x02 : 00240000
    Block ID 0x03 : 03A3E000
    Block ID 0x05 : Nokia.MSM8974.P6180.2.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 01001F0000
    Block ID 0x20 : 010000000100000004
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02021D023500
    UEFI App: FLASH APP
    Flash App Protocol Version: 2.29
    Flash App Implementation Version: 2.53
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: 800EEB508F7BBDF12A19262621FD837297A3B062FE2A7078C0 F3167E57F21217
    Sending Image Signatures...
    Image Signatures Accepted!
    Erasing Data Partition...
    Data Partition Erased Successfully
    Preparing Buffers for DATA LOOP...
    Allocating System RAM OK!
    Start Sending DATA BLOCKS...
    Finished Sending all DATA BLOCKS!
    Exiting FLASH Mode via REBOOT...
    Exit FLASH Mode Successful!
    Flashing Done!
    Total Flashing Time : 00:04:32
    Here is our Test Phone...
    Good Looking ORANGE COLOR...
    FLASHING The Phone...
    BOOT Repair Tests will follow follow
    BR
    X-Shadow
  6. ( toilatoi142001 ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    dinhduymobile (03-10-2014), thaigsm181 (19-12-2014)
  7. #4
    Jan 2007
    ATF JTAG WP8 FFU Flasher v1.0.11 Update! Public Discussion Thread:
    Release Date: September 3, 2014
    Firmware Version Required : LogiCore 11.0.00
    Change Log
    --> Added Lumia WP8 JTAG Flasher
    -----> Uses Official Nokia FFU (Flash File) to Repair BIG BOOT of Lumia WP8 Phones
    -----> You can easily match Product Code of Phone to FFU File you want to be Written as BOOT
    -----> Very Similar to BB5 FBUS Flashing
    -----> Allows you to Customize which Partitions Should be written
    -----> Allows you to Select Turbo JTAG Speed setting 30 Mhz for Super Fast Speed
    *** JTAG FFU Flasher is EQUAL to BIG BOOT FILE Repair ***
    *** But now you can MATCH PRODUCT CODE of your PHONE! ***
    Supported Phones for WP8 JTAG FFU Flasher
    Lumia 520 - RM-914
    Lumia 520 - RM-915
    Lumia 520T - RM-913
    Lumia 521 - RM-917
    Lumia 525 - RM-998
    Lumia 526 - RM-997
    Lumia 620 - RM-846
    Lumia 625 - RM-941
    Lumia 625 - RM-942
    Lumia 625 - RM-943
    Lumia 720 - RM-885
    Lumia 720T - RM-887
    Lumia 820 - RM-824
    Lumia 820 - RM-825
    Lumia 820 - RM-826
    Lumia 920 - RM-820
    Lumia 920 - RM-821
    Lumia 920 - RM-822
    Lumia 920T - RM-867
    Lumia 925 - RM-892
    Lumia 925 - RM-893
    Lumia 925 - RM-910
    Lumia 925T - RM-955
    Lumia 928 - RM-860
    Lumia 1020 - RM-875
    Lumia 1020 - RM-876
    Lumia 1020 - RM-877
    Lumia 1320 - RM-994
    Lumia 1320 - RM-995
    Lumia 1320 - RM-996
    You can DOWNLOAD AFP Files for FFU Flashing via ATFJ.exe built-in Downloader.
    Look for it at "Settings" ----> "Updates"
    *** Check on Link Below about how to download FFU Files for your Phone's Product Code
    Nokia Product Code Listing for NaviFirm+ Download - (Nokia 530, 636, 638, 930 Added)
    *** Check on Link Below to see Tutorial About FFU Flashing via ATF JTAG
    http://www.advance-box.com/ffu_flasher/
    Other Changes:
    --> Added Detection of eMMC BOOT Settings
    --> Automatically Fixes CSD WP Bits if set.
    --> Automatically Saves CSD and EXT_CSD into 'Logs\eMMC\' Folder
    --> Automatically Saves LOG Files to 'Logs\' Folder
  8. #5
    Jan 2007
    ATF v11.70 Update!! Public Discussion Thread:
    Release Date: September 30, 2014
    Firmware Version Required : 11.0.00
    ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
    ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
    ATF Network NEW SERVERS
    --> Uses Secure OpenSSL
    --> Automatically Installs OpenSSL DLLs for 32-bit and 64-bit Machines
    --> Optional "Add ATF Servers to Windows hosts File" button
    --> Fixed BroadCom Authorize Phone
    --> Fixed Auto Update Files
    *** ALL ATF Software Below 11.70 WILL NO LONGER WORK WITH ATF NETWORK ***
    *** SO FROM NOW ON, PLEASE USE ONLY 11.70 and NEWER ATF SOFTWARE ***
    Added Nokia Lumia WP8.1 and Android Dead Boot Repair via eMMC (September 2014 Files)
    <<<<<< ALL NOKIA LUMIA/ANDROID DEAD BOOT REPAIR FILES - Direct Links >>>>>>
    (ALL First In The World)
    Lumia 630 RM-974 01061.00057.14212.40007 4-WIRES ONLY
    Lumia 630 RM-976 01061.00042.14174.39005 4-WIRES ONLY
    Lumia 630 DS RM-977 01061.00042.14174.39006 4-WIRES ONLY
    Lumia 630 DS RM-978 01061.00066.14235.36003 4-WIRES ONLY
    Lumia 630 DS RM-979 01061.00042.14174.39001 4-WIRES ONLY
    Lumia 635 RM-975 01061.00074.14271.30100 4-WIRES ONLY
    Lumia 636 4G RM-1027 01061.00064.14233.03001 4-WIRES ONLY
    Lumia 638 4G RM-1010 01061.00062.14216.44001 4-WIRES ONLY
    Lumia 530 RM-1017 01068.00023.14295.43001 4-WIRES ONLY
    Lumia 530 RM-1018 01068.00023.14295.43002 4-WIRES ONLY
    Lumia 530 DS RM-1019 01068.00023.14295.43003 4-WIRES ONLY
    Lumia 530 DS RM-1020 01068.00023.14295.43002 4-WIRES ONLY
    Lumia 929 RM-927 1028.3566.1417.0047 4-WIRES ONLY
    Lumia 930 RM-1045 02061.00066.14353.31008 4-WIRES ONLY
    Lumia 930 RM-1087 02061.00066.14353.31002 4-WIRES ONLY
    Lumia 1520 RM-937 1028.3562.1402.0018 4-WIRES ONLY
    Lumia 1520 RM-938 1028.3562.1402.0001 4-WIRES ONLY
    Lumia 1520 RM-939 1028.3562.1402.0002 4-WIRES ONLY
    Lumia 1520 RM-940 1028.3562.1407.1001 4-WIRES ONLY
    (For Demonstration Purposes Only... ALL SM-G7102 can be UNBRICKED via SDC)
    Samsung SM-G7102 Galaxy Grand 2 4.4.2 G7102XXUBNH6 4-WIRES ONLY
    *** Take note that "via eMMC" Files are 100% FREE and NO NEED ACTIVATION!
    eMMC Tool 2.8 PRO
    --> Added CPU Type: "QUALCOMM HALT Type 1"
    -----> Very Usefull for NEW Samsung Phones with MSM8974, MSM8226.
    -----> Requires only 4 WIRES to Solder to the Phone
    -----> NO NEED TO Solder anything to VccQ and Vcc
    -----> Tested on SM-G7102 and SM-G7106
    --> Added CPU Type: "QUALCOMM HALT Type 2"
    -----> Very Usefull for Phones detected as QHUSB_DLOAD/VIP_05C6&PID_9008
    *** Make sure both RED (CLK) and YELLOW (RCLK) are Connected Together in order to
    *** for these new Qualcomm Halt Types to WORK.
    For Phones with new eMMC 4.5 and RCLK Support, please make sure you use
    YELLOW (RCLK) on the correct TP to ensure correct timing. Example on phone
    like SM-P605.
    Samsung Unbrick Image Creator 2.2
    --> Fixed Bug about not allowing 8GB cards for 8GB Phones
    --> Added APQ8060 and APQ8060A Support for SDC Image Creator
    ----> Tested on SCH-i200 - Unbricked via SDC
    *** Not ALL APQ8060/APQ8060A Phones are supported for SDC Unbrick
    *** Only Phones with GUID Partition Tables are supported
    New SDC Files Added:
    GT-I9200_4.4.2_8GB_I9200XXUDNF1.sdc
    GT-I9205_4.2.2_8GB_I9205XXUAMG7.sdc
    GT-N7105_4.4.2_N7105XXUFND3.sdc
    SM-G7102_4.4.2_8GB_G7102XXUBNH6.sdc
    SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc
    SM-G7102_4.4.2_8GB_G7102XXUBNG8.sdc
    SM-G900M_4.4.2_16GB_G900MUBU1ANCE.sdc
    SM-N900_4.4.2_32GB_N900ZSUDNF3.sdc
    SM-N9005_4.4.2_32GB_N9005XXUFNF4.sdc
    SM-N900A_4.3_32GB_N900AUCUBMJ5.sdc
    SM-P605_4.4.2_16GB_P605XXUCNG1.sdc
    Download Them via 4Shared
    SAMSUNG SDC FILES by Linus H. - 4shared
    [Nokia Android]
    --> Added New VID/PID for newer Nokia Android Phones
    --> Automatically BLOCKS V2 Flash Files when V1 LIVE Phone is Detected
    [BB5 Updates]
    --> Faster Nokia BB5 SL3 Authorize Phone
    ATF JTAG 1.0.12 Build 5634
    *** ALL ATFJ Software Below 1.0.12 WILL NO LONGER WORK WITH ATF NETWORK ***
    *** SO FROM NOW ON, PLEASE USE ONLY 1.0.12 and NEWER ATFJ SOFTWARE ***
    Change Log
    --> Uses new ATF Servers
    --> Added Support for APQ8060/APQ8060A CUSTOM Read Write eMMC
    --> Added Support for External 4.0v Power on VBATT for Phones which need Battery during JTAG
    ----> Very Useful for APQ8060/APQ8060A Samsung LTE Phones
    ----> Just Connect RJ-45 PIN 1 (VBATT) to Battery (+) of Phone
    --> Fixed HALT Timing for newer MSM8225/MSM8225Q SOC Revisions
    ----> This will now work on Nokia X, XL and X+ which was "No Devices Found" Before
    --> Added ALL BOOT Versions for BOOT REPAIR Nokia X, XL and X+ (via JTAG)
    Added for Nokia (All First In The World):
    Nokia X RM-980 [10.0.3] [FULL BOOT]
    Nokia X RM-980 [11.1.1] [FULL BOOT]
    Nokia X RM-980 [1.1.2.2] [FULL BOOT]
    Nokia X RM-980 [1.2.4.1] [FULL BOOT]
    Nokia X RM-980 [1.2.4.2] [FULL BOOT]
    Nokia X RM-980 [1.2.4.3] [FULL BOOT]
    Nokia X V2 RM-980 [1.1.3.20] [FULL BOOT] <--- For V2 Phones ONLY!!!
    Nokia X V2 RM-980 [1.2.4.21] [FULL BOOT] <--- For V2 Phones ONLY!!!
    Nokia X RM-981 [1.1.0.1] [FULL BOOT]
    Nokia X RM-981 [1.1.1.0] [FULL BOOT]
    Nokia X RM-981 [1.2.2.2] [FULL BOOT]
    Nokia X+ RM-1053 [1.1.0.2] [FULL BOOT]
    Nokia X+ RM-1053 [1.2.2.1] [FULL BOOT]
    Nokia XL RM-1030 [1.1.0.6] [FULL BOOT]
    Nokia XL RM-1030 [1.1.1.0] [FULL BOOT]
    Nokia XL RM-1030 [1.1.1.4] [FULL BOOT]
    Nokia XL RM-1030 [1.2.1.2] [FULL BOOT]
    Nokia XL RM-1030 [1.2.3.1] [FULL BOOT]
    Nokia XL RM-1030 [1.2.3.2] [FULL BOOT]
    Nokia XL V2 RM-1030 [1.1.2.20] [FULL BOOT] <--- For V2 Phones ONLY!!!
    Nokia XL V2 RM-1030 [1.1.3.21] [FULL BOOT] <--- For V2 Phones ONLY!!!
    Nokia XL RM-1042 [1.1.0.0] [FULL BOOT]
    Nokia XL RM-1042 [1.2.1.1] [FULL BOOT]
    Added for Samsung:
    SGH-i727 FULL BOOT 4.1.2
    SGH-i200 FULL BOOT 4.1.2 - (First In The World)
    *** You can download these Files via ATFJ.exe ---> Help ---> Updates
    download hêre
  9. #6
    Jan 2007
    ATF v11.80 Update!! Public Discussion Thread:
    Release Date: November 25, 2014
    [Nokia Android Updates]
    --> Added Support for Nokia XL 4G (RM-1061)
    ----> Added Secure ADB Connection
    ----> Dead Mode, Normal Mode, Recovery Mode Flashing
    ----> 1 Click ROOT
    ----> 1 Click Google Apps + Launcher Installer (NO NEED ROOT)
    ----> Added FULL IMEI/Simlocks/EFS Backup + Restore (NO NEED ROOT)
    *** WARNING: DO NOT CROSS-FLASH NOKIA XL 4G RM-1061 with other Nokia XL RM-xxxx ***
    --> Added Support for Nokia X2 (RM-1013)
    ----> Support Both Qualcomm and Nokia USB Drivers
    ----> 1 Click ROOT
    Added Nokia Lumia WP8.1 and Android Dead Boot Repair via eMMC (October to November 2014 Files)
    <<<<<< All Nokia Lumia/Android Dead Boot Repair Files -[Added Lumia 830] >>>>>> - GSM-Forum
    Lumia 830 RM-983 [02040.00012.14404.07019] [BIG BOOT] <-- eMMC Tool Exclusive!!!
    Lumia 830 RM-984 [02040.00005.14372.54001] [BIG BOOT] <-- eMMC Tool Exclusive!!!
    Lumia 830 RM-985 [02040.00005.14373.00002] [BIG BOOT] <-- eMMC Tool Exclusive!!!
    Lumia 830 RM-1049 [02040.00012.14404.07005] [BIG BOOT] <-- eMMC Tool Exclusive!!!
    [Samsung Updates]
    Factory Boot - Qualcomm USB Boot Repair 1.0 (Initial Public Release)
    --> Added Initial Suport for Samsung GT-i9505 (Galaxy S4 LTE)
    ----> This will BOOT Repair Phones which cannot be Repaired via SDC or JTAG
    ----> ONLY USB CONNECTION NEEDED (NO OPENING/SOLDERING OF PHONE)
    Current Boot Files Supported:
    ----> GT-i9505_16GB_4.4.2_I9505XXUGNJ8.bin <-- Latest Version !!!
    ----> GT-i9505_16GB_4.4.2_I9505VJUGNI2.bin
    ----> GT-i9505_16GB_4.4.2_I9505XXUGNG4.bin
    *** Please Install Supplimentary Boot Files From Here:
    ATF Offcial Support Area / file-support / Samsung USB Boot Repair
    Samsung Unbrick Image Creator 2.8
    --> Added Support for New Qualcomm CPU APQ8084/APQ8084 Pro (Galaxy Note 4, Galaxy Note Edge, Galaxy S5)
    --> Added Support for New Exynos CPU OCTA 5433 (Galaxy Note 4, Galaxy Tab S 10.5")
    --> Added Better Compression for Smaller SDC Files for New CPUs
    --> Added Automatic Check if TAR+MD5 File can be used for SDC Creation or Not
    --> Added BUILT-IN PIT Files for the following CPUs (So Now all you need is BL File for SDC Creation!!!)
    ----> APQ8074.pit
    ----> APQ8084.pit
    ----> MSM8226.pit
    ----> MSM8228.pit
    ----> MSM8274.pit
    ----> MSM8626.pit
    ----> MSM8674.pit
    ----> MSM8928.pit
    ----> MSM8930.pit
    ----> MSM8960.pit
    ----> MSM8974.pit
    ----> EXYNOS_3_DUAL_3250.pit
    ----> EXYNOS_4_DUAL_4210.pit
    ----> EXYNOS_4_QUAD_4412.pit
    ----> EXYNOS_5_DUAL_5250.pit
    ----> EXYNOS_5_OCTA_5410.pit
    ----> EXYNOS_5_OCTA_5420.pit
    ----> EXYNOS_5_OCTA_5422.pit
    ----> EXYNOS_5_OCTA_5433.pit
    SM-G7109 = SM-G7109_4.3_8GB_G7109KEUBNG1.sdc
    SM-N910P = SM-N910P_4.4.4_16GB_N910PVPU1ANIE.sdc
    SM-N910T = SM-N910T_4.4.4_16GB_N910TUVU1ANJ7.sdc
    SM-N910U = SM-N910U_4.4.4_2GB_N910UXXU1ANJ5.sdc
    SM-N9108V = SM-N9108V_4.4.4_16GB_N9108VZMU1ANIG.sdc
    SM-N7506V = SM-N7506V_4.3_16GB_N7506VZNUAND2.sdc
    Download Them Here:
    ATF Offcial Support Area / file-support / Samsung SDC Files
    [GENERAL UPDATES]
    --> Fixed Windows 64-BIT OpenSSL Problem for Server Connection
    --> Added all variants of Nokia Lumia 830 and Microsoft Lumia 535 in Nokia.ini
    --> Added New USB Drivers for Nokia Lumia/Microsoft Lumia Phones
    --> Added New USB Drivers for Nokia X2 RM-1013
    Who will buy this if you can get more in ATF?
    __________________________________________________ ________________________
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
    Official download link ATF v11.80
    [/CENTER]
    [B]
  10. #7
    Jan 2007
    Release Date: November 27, 2014
    [/COLOR]
    *** GET THIS UPDATE VIA AUTO-UPDATE SEVER ***
    [Samsung Updates]
    Samsung Unbrick Image Creator 2.9
    --> Added Support for New Qualcomm 64-BIT CPU MSM8916!!! (Galaxy A3, Galaxy A5, Galaxy Core Max etc...)
    Fully Tested on Actual Phone Here:
    Galaxy Core Max SM-G5108Q SDC Tests - GSM-Forum
    Galaxy A3
    SM-A3000 : SM-A3000_4.4.4_8GB_A3000ZCU1ANJ8.sdc
    SM-A300F : SM-A300F_4.4.4_8GB_A300FXXU1ANKC.sdc
    SM-A300H : SM-A300H_4.4.4_8GB_A300HXXU1ANKC.sdc
    Galaxy A5
    SM-A5000 : SM-A5000_4.4.4_8GB_A5000ZCU1ANK2.sdc
    SM-A500F : SM-A500F_4.4.4_8GB_A500FXXU1ANJ9.sdc
    SM-A500G : SM-A500G_4.4.4_8GB_A500GXXU1ANK1.sdc
    SM-A500H : SM-A500H_4.4.4_8GB_A500HXXU1ANJ9.sdc
    SM-A500M : SM-A500M_4.4.4_8GB_A500MUBU1ANK1.sdc
    Other 64-Bit Phones
    SM-G357FZ : SM-G357FZ_4.4.4_8GB_G357FZXXU1ANHD.sdc
    SM-G3608 : SM-G3608_4.4.4_8GB_G3608ZMU1ANJ5.sdc
    SM-G360G : SM-G360G_4.4.4_8GB_G360GDVU1ANJ4.sdc
    SM-G5108Q : SM-G5108Q_4.4.4_8GB_G5108QZCU1ANI5.sdc
    SM-G5308W : SM-G5308W_4.4.4_8GB_G5308WZMU1ANI8.sdc
    SM-G530Y : SM-G530Y_4.4.4_8GB_G530YZTU1ANJ3.sdc
    Download Them Here:
    ----> 1 Click ROOT
    ----> 1 Click ROOT
    [Samsung Updates]
    ----> APQ8074.pit
    ----> APQ8084.pit
    ----> MSM8226.pit
    ----> MSM8228.pit
    ----> MSM8274.pit
    ----> MSM8626.pit
    ----> MSM8674.pit
    ----> MSM8928.pit
    ----> MSM8930.pit
    ----> MSM8960.pit
    ----> MSM8974.pit
    Download Them Here:
    [GENERAL UPDATES]
  11. #8
    Jan 2007
    ATF v11.81 Update!! Public Discussion Thread:
    [/COLOR]
    [Samsung Updates]
    Galaxy A3
    Galaxy A5
    Other 64-Bit Phones
    Download Them Here:
    ----> 1 Click ROOT
    ----> 1 Click ROOT
    [Samsung Updates]
    ----> APQ8074.pit
    ----> APQ8084.pit
    ----> MSM8226.pit
    ----> MSM8228.pit
    ----> MSM8274.pit
    ----> MSM8626.pit
    ----> MSM8674.pit
    ----> MSM8928.pit
    ----> MSM8930.pit
    ----> MSM8960.pit
    ----> MSM8974.pit
    Download Them Here:
    [GENERAL UPDATES]
  12. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TuệNguyễn (27-11-2014)
  13. #9
    Jan 2007
    TF v11.82 Update!! Public Discussion Thread:
    Release Date: November 28, 2014
    ATF 11.82
    Or Download Manually Here:
    http://174.120.45.27/current_exe/AdvanceBox.exe
    [Bug Fixes]
    1. Window Phone "Extra File Loaded" Bug In Flashing --- FIXED
    2. Auto Update Feature of EXE now FIXED
  14. #10
    Nov 2010
  15. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
