Trang 7 của 10 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 CuốiCuối
Kết quả 61 tới 70 của 92
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    Mcnpro Box official version 3.2.9 Released
    What's new for Mcnpro box version 3.2.9 ?
    • Improved MTK 6573/6516/6513 read /write
    • Fix Nor flash write bugs for boot6
    • Improved MTK USB Pin-find function
    • Improved Spreadtrum 6800H read /write
    • Add support Spreadtrum 880xG
    • Spreadtrum new Flash ICs added
    • Fix Mstar read /write bugs
    • Other small report bugs fixed
    Upgrading from Previous Versions:
    • Version of 3.2.9 request install Suite version 2.1.1 at first, As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section !
    Mcnpro_Box_3.2.9.rar
    More informations check here>>>
    Best regards !
    Mcnbox
  2. ( THIÊN UY™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ĐẶNG BẢO_GSM™ (23-05-2012)
    Moderator LocPhatBacLieu™'s Avatar
    Apr 2011
    Bạc Liêu
    Vietcombank: 0111000277148 - Yahoo: locphatbaclieu
    Tel: 09.68.68.68.52 - 0919.11.79.68
    Nov 2010
    Mcnpro Box Online updater v2.1 Released Mcnpro Box Online updater v2.1 Released
    New update coming in this week !
    Best regards !
    Mcnbox Team
    Nov 2010
    Mcnpro Box hot update to V3.3.0 ★★★★★ What's new for Mcnpro box version 3.3.0 ? New!! Hot!!
    • Add CoolSand CPU complete supported
      • Read / Write
      • IMEI Change
      • Format
      • Unlock
      • Factory Set
      • Read Code
    • Spreadtrum new Flash ICs added (6610/20)
    • Spreadtrum read/write bugs fixed (6800H)
    • Spreadtrum bootloader improved(880xG)
    • MTK new Rx/Tx pin detection method added
    • MTK read /write bugs fixed (For New CPU)
      Welcome to use McnBox!
      Selected COM9
      Baud setting ...
      Set Baud done
      Initialize in progress ...
      Checking data ...
      Serial No. MCNxxxxxxxxxxxx
      Firmware V1.15
      Checksum 15B9-21BE
      Software V3.30
      Box Connected!
      Ready working at COM9
    As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
    Ahead of others. Do Customer needed !
    Discussion here>> Mcnpro Box version 3.3.0
    Best regards !
    Mcnbox
    Apr 2011
    Bạc Liêu
      • Read / Write
      • IMEI Change
      • Format
      • Unlock
      • Factory Set
      • Read Code
      Selected COM9
      Baud setting ...
      Set Baud done
      Checking data ...
      Firmware V1.15
      Checksum 15B9-21BE
      Software V3.30
      Box Connected!
    Link: Mediafire
    Mcnpro_Box_3.3.0_LocPhatBacLieu™.rar
    Best regards !
    Mcnbox
    May 2011
    Hà Nội City
    ★★★★★ Mcnpro Box 3.3.1 hot Released ★★★★★
    What's new for Mcnpro box version 3.3.1 ? New!! Hot!!
    • Improved CoolSand CPU Read /Write
    • CoolSand new flash ICs added
    • Spreadtrum New flash ICs added
    • Improved MT6276 /6255 read/write bugs
    • Improved MTK new Rx/Tx pin detection method
    • Improved MT65xx CPU (6573/6516) read/write bugs
      Quote:
    • Welcome to use McnBox!
      Selected COM9
      Baud setting ...
      Set Baud done
      Checking data ...
      Firmware V1.15
      Checksum 15B9-21BE
      Software V3.31
      Box Connected!
    ★★★★★Discussion here>> Mcnpro Box version 3.3.1 ★★★★★
    We are sure , Mcnpro Box Still is the best product for chinese mobile phone ! what you are waiting for ??
    Best Regards !
    Mcnbox Team
  8. #7
    Bình Dương
    What's new for Mcnpro box version 3.3.3 ? New!! Hot!!
    • MTK 65xx bugs fixed (Full Supported)
    • MTK new Flash ICs added
    • Improved MTK USB read /write bugs
    Selected COM9
    Baud setting ...
    Set Baud done
    Checking data ...
    Firmware V1.15
    Checksum 15B9-21BE
    Software V3.33
    Box Connected!
    Upgrading from Previous Versions:As usual, Version 3.3.3 request install Suite version 2.1.2 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
    ★★★★★Discussion here>> Mcnpro Box version 3.3.3 ★★★★★
    Read it , you may get something special
    Best regards !
    Mcnbox Team
  9. #8
    Apr 2011
    Bạc Liêu
  10. #9
    Moderator Thuyết Vũ's Avatar
    Aug 2007
    Gia lai
    big up big up !
  11. #10
    Bình Dương
    What's new for Mcnpro box version 3.3.5 ? New!! Hot!!
    • USB Cable stand function added
    • CoolSand new Flash ICs added
    • CoolSand reported bugs fixed
    • Mstar new Flash ICs added
    • Mstar unlock function improved
    • MTK 6250/6252A read/write Improved
    • MTK Android phone IMEI Change/repair function added
    • Add support Spreadtrum SC6530 (AMD32-128,SPANSION,Samsung,INTEL,Numonyx,SST,TSB,CFEON etc)
    • Update Main software to V3.3.5
    As usual, Version 3.3.5 request install Suite version 2.1.3 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section , You also can using updater direct upgrade your software online!
  12. ( THIÊN UY™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TuấnPhát_GSM (16-09-2012)
Hiện có 7 người đang xem bài này . Bao gồm : 0 thành viên và 7 khách
  1. ATF Update anh em vui lòng post ở đây
    By nokia service code in forum Advance Turbo Flasher
    Trả lời: 158
    Bài viết cuối: 31-03-2017, 23:22
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Vigis New Update anh em vui lòng post ở đây
    By taihv™ in forum VygisToolbox
    Trả lời: 274
    Bài viết cuối: 14-05-2014, 09:34
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
