Trang 17 của 26 Đầu tiênĐầu tiên ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 CuốiCuối
Kết quả 161 tới 170 của 255
  1. #161
    Jan 2007
    Infinity `SM` software v1.11 released
    Service - added Read CRT function for MTK based phones (need Root)
    Service - added Bacup SEC function for MTK based phones (need Root)
    Installer has two parts:
    - InfinityBox_install_SM_v1.11
    - InfinityBox_update_SM_ResourcePack_v1.09 (old one). If you have Resource Pack installed earlier you do not need to download and install it again
    Download link
  2. #162
    Jan 2007
    Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options
    MTK 6570 CPU support:
    with NAND memory
    with eMMC memory
    Read Info - Complete device info, Security info
    Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ]
    Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ]
    Read NVRAM
    Write NVRAM
    Repair Security
    Formay FS - FRP, Settings, Privacy ( and mixed/special mode )
    MemoryTool
    MTK 6750 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    MTK 6755 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    MTK 6757 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    MTK 6763 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    MTK 6797 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    --- Under Test ---
    MTK 6758 CPU support:
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    MTK 6739 CPU support:
    with NAND memory
    with eMMC memory
    Read Firmware
    Write Firmware
    Read NVRAM
    Write NVRAM
    Repair Security
    MemoryTool
    Main
    - New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ]
    - New core. All code made from scratch.
    - New boot chain selection mode - automatic ( via defined user combination ) or manual.
    - New connection
    - Complete error handling and explanation
    - Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices
    - Easy end user customization for adding support for new device etc.
    Flasher
    - Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ]
    FW Reader
    - Completely new core, which allow handle all existing types and flash devices.
    Service
    - Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct.
    - Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection )
    - During NVRAM read/write SW also verify it condition and data
    MEMORY TOOL activated!
    Easy, fast and ultimate solution now come in MTK too!
    - Support eMMC and NAND flash IC secure
    - Allow READ, WRITE, ERASE partitions
    - Show partitions states and info only for eMMC devices
    - Allow RE-init PMT ( from scatter )
    Other
    Lot of other changes from v1 line, which not mandatory to mention
    Known issues/warnings/info:
    1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
    In result you will give read/write FW errors and rest problems at all.
    Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
    2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
    1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices!
    3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed.
    Read-write data, which you want, ignore "EMPTY" states.
    4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar
    In some cases WIPE partition may not work!
    5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing
    6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
    7. Device with NV_TYPE2 security may not work yet for repair sec!
    Download link
  3. #163
    Jan 2007
    Chinese Miracle-2 MTK/Mediatek v2.00 r2 - MT6739 support, SPUnlock and more
    As we told earlier, it was found some kind of problems with v2.00 at some PC and some hardware configuration. Current release should help to fix it. More details please see here - Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options - GSM-Forum
    More details about current release:
    - Main
    MT6739 CPU supported!
    MT6739 moved from TEST to GENERAL support.
    Firmwware read
    Firmware write
    NVRAM read
    NVRAM write
    Reset Settings / Format FS
    Reset FRP
    Reset Privacy
    MemoryTool
    - MemoryTool
    Fixed PMT init on some devices
    Optimized Expand/Collapse view functions
    Fixed DA1804 and DA1712 loaders support for WIPE
    Optimized NAND support
    - Service
    NVRAM module updated
    .dynamic page detection
    .some types support fixed
    .repair security ( security type detection ) updated
    FormatFS / Reset settings rebuild
    .Activated fully automatic "FULL FACTORY" mode, designed for all modern devices ( include devices with SEC_CONTROL )
    ."FULL FACTORY" mode set to default
    .Some "OLD" agents (DA15xx) may not work
    - SP Unlock activated
    Support all MTK modern phones, except MT6763 and MT6739.
    Read codes and Direct Unlock mode supported
    MT6570 eMMC ONLY devices supported
    - Core
    Fixed memory leak issues and problems with booting on some systems
    Optimized different OLD agents support for MODERN devices ( DA16xx and DA17xx line )
    SW more faster now
    EMI handler for MT6570 and MT6797 fully automated and complete
    Improved EMI lookup support for MT675x devices
    EMIDB updated
    Hint/Error explain module updated
    MT6758 support under test
    MT6771 support under test
    - Flasher
    Fixed break issue, when just one file selected for flashing.
    HWInfo compatibility status shown in log in both cases ( succes or failed )
    - FW reader
    MT6739 support
    New types of firmwares supported
    Optimized NAND reading on DA18xx line loaders
    Read Firmware size now shown in log
    - New models included
    Limited MEIZU support
    Limited Oppo support
    Limited Gionee support
    Limited BQ support
    Some basic "generic" secure devices support optimized
    Known issues/warnings/info :
    1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors!
    Read-Write data, which you want, ignore "EMPTY" states.
    4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
    5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
    6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
    7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
    Download link
  4. #164
    Jan 2007
    Infinity Chinese Miracle II SCR/SPD-RDA v1.03: New models and features
    Supported CPU list:
    Spreadtrum: SC6530, SC6531, SC6531(A/C), SC6531E, SC6533, SC6533G
    RDA Mirco: RDA8851 rev A,B,C,L,CL
    RDA Micro: RDA8826
    RDA Mirco RDA8851 rev A,B,C,L,CL/RDA8826
    Flashing protocol updated
    Updated LOD tools ( flashing / customizing )
    Spreadtrum SC6533/G:
    Protocol updated
    Support for REV2 bootrom mode activated
    FW reading revised
    Spreadtrum SC6530/6531/A/C/E:
    Revised Repair security feature
    Flashing revised
    -> Activated "Format FFS" during BINARY dump writing
    -> Use that feature, if device not allow make direct format ( some C/E revision devices )
    User code read revised - activated 2nd mode : from DUMP
    -> Press and hold LEFT SHIFT key, while starting ReadUsercode code operation. Select desired dump file to read code.
    Activated AUTO fixer for memory dumps
    Internal loaders updated
    Spreadtrum other:
    Protocol updated
    PAC handling revised
    Improved Flashing procedure for SC7701/SC7702 devices
    Improved Flashing procedure for SC6825/SC8825 devices
    Known issues[*]/warnings[!]/info[I]:
    1. [I] AUTO fixer for memory dumps
    -> That feature will AUTOMATICALLY FIX dumps from devices with "abnormal" flash and memory layout ( issue found on number of devices 16MB flash with 8MB layout )
    -> Just select binary dump in flashing tab or any other operation, which require file select.
    2. [*] In some cases Format FFS may fail on E and C rev
    -> Read Flash Dump, write it back. During Dump writing SW will ask you about FormatFFS.
    Download link
  5. #165
    Jan 2007
    Infinity `SM` software v2.00 released
    Infinity Samsung Activation server is back with new Smart-Card firmware for latest `SM` software release.
    `SM` software v1.xx was released time ago as a free software for Infinity users. From now v2.00 released as a paid addon.
    Users who have made free Infinity `SM` activation can use it in future with `SM` software v1.xx. If users of free `SM` Activation want to use `SM` software v2.xx they should obtain new `SM` activation.
    Infinity `SM` software v2.00 news:
    - many internal stability improvements
    - FRP unlock engine re-written
    - FRP unlock procedure updated
    - security area write for MTK based devices
    - security area write for Exynos based devices
    - Smart-Card firmware should be updated to use this software release
    - "SM ResourcePack" should be installed to get all released functions working
    At the moment there is a special offer for `SM` v2.xx Activation. Price is quite cheap right now but with each new `SM` update released price will be higher than before. So you can activate software right now for a cheap price or you can wait some time, see software updates progress and then pay higher price for it.
    List of supported models and features for previous software release - Infinity `SM` software - general information, models, functions etc. - GSM-Forum
    Test reports are here - Success test reports with Infinity SM software - GSM-Forum
    Download link
  6. #166
    Jan 2007
    Infinity `SM` software v2.02 released
    Service changes:
    - Downgrade modem procedure released. This operation may be dangerus so use at own risk and only if you are really know you need it !
    - rebuild Reset FRP procedure
    Internal changse:
    - a lot of changes related to use server functions
    - bug fixes and internal improvements
    Download link
  7. #167
    Jan 2007
    Latest released version: 2.03
    Curent price: 70 Infinity credits
    Download link
  8. #168
    Jan 2007
    Infinity `SM` software v2.04 released
    Flasing - add Reset userlock / pin / pattern / password in FRP ON + OEM ON mode options
    Many bug fixed
    How to use Reset User lock options:
    - see phone version in Recovery menu
    - download COMBINATION file according to the phone version
    - check checkbox and add your COMBINATION file
    - flash phone
    - after write COMBINATION file wait phone is turned on
    - phone on in recovery mode, reboot phone
    - you have access to phone data
    after backup user data - reflash phone
    Download link
  9. #169
    Jan 2007
    Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features
    Important:
    - Software installed to new folder /CM2MT2/ and designed to support new models
    Legacy core support activated:
    MT6571
    MT6572
    MT6580
    MT6582
    MT6589
    MT6592
    MT6595
    MT6597
    MT6732
    MT6735
    MT6737
    MT6752
    MT6753
    MT6795
    MT8127
    MT8163
    MT8321
    MT8732
    MT8735
    MT8752
    Identify: full device info, security info
    Flash Factory Firmware
    Read Factory Firmware
    Reset FRP
    Repair Security (Flash Mode, Direct)
    SP unlock
    MemoryTool - complete device control, service, repair, forensic etc.
    - Main
    Loader database optimized, size reduced.
    DA v1820 line support tested and activated
    DA v1836 line support tested and activated
    Connection level revised
    BROM level support optimized
    Optimized and changed HighSpeed port selection
    FlashEngine revised
    NVRAM tool revised
    Global option PWM - allow switch SW between two different work modes for RAPHAEL.
    > Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc.
    > For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE )
    - Service
    Repair Security revised
    > Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes !
    Format FS - new mode activated: Forced Erase
    Format FS - fixed WIPE mode
    - Core
    EMIDB updated
    New EMI engine for LEGACY line
    > EMI engine support almost all existing LEGACY line
    > New types for RAPHAEL included
    - FW reader
    LEGACY core supported ( unsigned and static signed types are supported )
    Scatter creation optimized
    - Other
    Settings tab activated ( firmware path settings and other features can be found here )
    AutoUpdate ( module files ) feature activated
    Many other changes and fixes
    1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list.
    2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list !
    3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed.
    4. MT6592 support on DAv18xx loader line broken ( DA issue )
    5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP )
    6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC )
    7. NAND support on LEGACY line is not activated yet
    Download link
  10. #170
    Jan 2007
    Infinity Chinese Miracle-2 MTK/Mediatek v2.02 - new features, loaders, improvements
    - Base
    Base - Read info from EMI base (preloader) in manual mode after selection
    Base - Info reading improved ( in some cases device info can be empty )
    Base - Manual mode selection revised ( Boot fail issues in manual mode )
    - MemoryTool
    MemTool - Partition types detection improved
    MemTool - Interface changes ( partition selection style changed, menu sctructure changed )
    MemTool - work with boot1/boot2 section revised for LEGACY line
    MemTool - InitPreloader option activated ( LEGACY/RAPHAEL )
    MemTool - Flash service regions read/write now allowed ( if they not set as protected - i.e. OTP )
    - Flasher
    Flasher - Removed "Skip preloader" option, use selection instead ( untick preloader from flashing list )
    Flasher - Customization model revised
    Flasher - DL Fix / ADL Checksum revised
    Flasher - Preloader initialization during flashing revised
    Flasher - More accurate PMT/GPT rebuild, for compatibility with SPFT ( PMT invalid issues after servicing with MT2 module )
    - Firmware Reader
    FWReader - Scatter compatibility for spft optimized (6735, 6737)
    FWReader - More types supported for safe read
    FWReader - Info reading improved ( in some cases device info can be empty )
    FWReader - SW path settings also accepted now on FW read
    - Platform changes
    Platform - MT6589 support optimized
    Platform - MT6592 support optimized
    Platform - MT673x support optimized
    - Loader database
    LoaderDB - New agents included ( BQ, TECNO, INFINIX, VIVO )
    - Other
    Other - Lot of small fixes and changes, reported by users
    Thanks to : gracy_elec, kamal_singla and other our users for providing files and/or testing
    Download link
  1. Z3X BOX LG New Update
    By TuấnPhát_GSM in forum Z3X-BOX FOR LG
    Trả lời: 133
    Bài viết cuối: 19-03-2021, 09:27
  2. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  3. Trả lời: 31
    Bài viết cuối: 02-11-2011, 15:23
  4. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
  5. Trả lời: 0
    Bài viết cuối: 27-12-2010, 21:51
