Trang 15 của 36 Đầu tiênĐầu tiên ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... CuốiCuối
Kết quả 141 tới 150 của 352
  1. #141
    Sóc Sơn - Hà Nội
    Mặc định VolcanoBox 2.1.6 MTK Android SYSTEM Area Read & Su & Privacy Code new method
    World's 1st Added MTK Privacy code new method
    such as Privacy Code read from Qmobile E770 !!
    Added MTK Android judge whether to ROOT /SU super user (ADB mode).
    Backup SYSTEM file (requires ROOT permission).
    Write SYSTEM file (requires ROOT permission).
    Read and write SYSTEM file purpose is to repair some deleted APK files accidentally,
    screen shots :
    Root
    backup files
    Take backup system
    Dowload
  2. #142
    Moderator thanhphuek's Avatar
    Feb 2010
    Eakar Đến PLeiku
    Mặc định VolcanoBox2.1.7 SPD Android Read Info.SAFE Format.SAFE Root.Qmobile E770 &New Privacy
    SPD Android read info added whether to Format/Root
    SPD Android Format added new algo.
    SPD Android Root added new algo.
    SPD Android SAFE Format added.
    SPD Android SAFE ROOT added.
    Adjust MTK Android System write.
    **No More Hand on logo after format
    Privacy Code New ALGO Added.
    New Qmobile E770 etc tested !!
    VolcanoTool_v2.1.7.rar
    ĐIỆN TỬ-ĐIỆN THOẠI THANH PHÚ
  3. #143
    Nov 2010
    VolcanoBox2.1.7 SPD Android Read Info.SAFE Format.SAFE Root.Qmobile E770 &New Privacy What is new in 2.1.7
    Discussion here
  4. #144
    Thành viên tích cực GSM_SONGCONG™'s Avatar
    Jun 2008
    Sông Công_ Thái Nguyên
    VolcaoBox 2.1.8
    Whats new ?
    World's 1st Added SPD Android Verification system
    World's 1st Added SPD Android Verify your phone is Safe for format
    World's 1st Added SPD Android Verify your phone is Safe for Root
    World's 1st Added SPD Android Verify your phone is Safe for READ INFO
    Added MTK 6260 Read Flash
    Added MTK 6260 Write Flash
    Added MTK 6260 Imei Repair
    Added MTK 6260 Read privacy code
    Adjust MTK Android One-key Root(Solve some phones failed to root)
    Adjust coolsand Read flash bug
    Read Instructions VERY CARE FULLY !!
    About this Update Please Read very Care Fully before you operate any operation !!
    VolcanoBox 2.1.8 Launched world's 1st SPD Android Verify Partitions System. for this Function you can Verify you mobile is SAFE for ROOT or Format or Read info. for this you must have Mobile in Powered ON condition & with Usb Debug mode ON !!. What you have to do it Simply Plug usb cable and click on Partition from Volcano soft and run it. it will tell you is your Phone Supported for SAFE format / ROOT etc or not. If software tell you is safe it will become log in GREEN color and if software tell you is not safe it will show you log in RED color. so here we start...
    If software software show you log like this in GREEN COLOR.... This mean your phone is Supported for SAFE Root, format etc..
    Code:
    Partition as follows. It's supported to format and ROOT the mobile phone.
    >>mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjaluna),10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(dsp),3840k(runtimenv),10m(boot),10m(recovery),200m(system),190m(userdata),60m(cache),256k(misc),1m(boot_logo),1m(fastboot_logo),3840k(productinfo),512k(kpanic)
    If software show you log like this in RED COLOR.... This mean your phone is NOT supported for SAFE Root, Format etc...
    Code:
    Partition as follows. It's NOT supported to format and ROOT the mobile phone.
    How to do it ?
    Download & Run 2.1.8
    click on SPD
    Select 6820
    Select One Key Root
    Select Partition
    untick auto pinout
    Plug normal usb cable to mobile in powered on condition
    Usb debug must be Enabled
    Click on run.
    wait few sec it will Show you Logs as i describe above
    Q: what is usefull if phone have pattern lock or any other problem and it have not usb debug Enabled then this option is useless how we can do that ?
    A: Yes it's true that if phone have pattern lock or any other problem and usb debug not Enabled this function is really useless but infact it's not useless. many time we can't found factory files and many time Same working phone we can get from market so here is hint . Take same working phone, Should be 100% same, plug phone with usb and check is it Safe to format or not. if it's safe then you can do it without any problem and if phone is not safe then you simply don't do. so basically we make this function just to verify is phone is SAFE for format, Root etc or not...
    Q: I plug phone but software not recognized or Software hang on "<<" then what to do ?
    A: Perform these Steps
    MAKE SURE YOUR PHONE IS CONNECTED IN POWERED ON CONDITION AND USB DEBUG ENABLED AND ADB ANDROID DRIVERS ARE INSTALLED AND YOU CAN SEE ADB ANDROID PHONE IN DEVICE MANGER !!!!!!
    go to start
    go to run
    type "CMD"
    clck on run
    ( go to Volcanobox 2.1.8 Folder/Tools ) for exmaple you have Volcano 2.1.8 in C: Drive so you should type this these commands. ( write all command without "" and right after every command you should press Enter button from keyboard)
    "C:\" ( Press Enter )
    it will become here
    C:/>
    then type
    "cd VolcanoTool_v2.1.8\tools" ( Press Enter )
    it will become here
    C:/VolcanoTool_v2.1.8\tools>
    then type
    "adb devices"
    now check what it's show to you
    if it's show like this
    * daemon not running. starting it now on port 5037 *
    * daemon started successfully *
    List of devices attached
    this mean your phone is not detecting by your computer's ADB.exe
    19761202 device
    This mean your phone is detect by your computer's ADB.exe
    Type this command
    "adb kill-server" ( press enter button )
    and again
    so here you have to do totally two different ways to work with it.
    so we will start
    if you phone not detecting by your computer's ADB.exe then you have to do this
    Keep phone connected
    go to ( in windows Explorer )
    C:\Documents and Settings\"Your name"\.android ( Your name should be your profile name here for exmaple "Jhon", "Anglina" etc )
    there you can see some files
    check do you have "adb_usb.ini" file in that folder or not
    If you have then open it in note pad if not then create new file named "adb_usb.ini" and save it.
    Be sure you save .INI extension not safe in any other format
    for confirm open C: Drive in Windows Explorer
    go to Tools
    click on Folder Options
    click on view
    Untick Hide extension for known file type
    click on ok
    now see that file is exactly "adb_usb.ini" be sure it's not "adb_usb.ini.txt" etc
    so as you done open it in note pad, ( if you already have this file then don't create new one just open it )
    type this in new line and save it
    "0x1782" ( write without "" )
    so after you save file
    open CMD again ( which already opened previously )
    Type these commands
    and again
    now type
    "adb devices" ( press enter button )
    now it should show like this
    19761202 device
    now you are ready to go.
    so right after this disconnect phone and connect it again and type these commands
    "adb kill-server" ( press enter )
    "adb device" ( press enter )
    as it's show
    19761202 device
    Keep this CMD open and go to Volcanobox and perform these steps to know is my phone Supported for SAFE format or not !!
    click on SPD
    Select 6820
    Select One Key Root
    Select Partition
    untick auto pinout
    click on run
    now it will show you your phones details in just 1 sec
    after you can do what ever you want !!
    Code:
    so from now no more SPD ANDROID PHONE WILL BECOME DEAD IF YOU VERIFY IT BEFORE FORMAT OR ROOT.... Keep in mind we had tested over 110 phones non of phones become dead while verifying !!
    Very special Thanks to Stanner
    Download link
    Download MediaFire
    Repair Boot -Unlock-Mở Mạng-All các loại máy
    D/c:529 Ngã Tư Việt Đức-Sông Công-TN
    SDT: 0969926800 : Yahoo: dinhchien_yeuem
  5. ( GSM_SONGCONG™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TuệNguyễn (21-06-2013)
  6. #145
    Thành viên tích cực VH-Mobile's Avatar
    Đà Lạt
    VolcanoBox 2.1.9
    Whats new ?
    Adjust SPD Android Read infor
    Added SPD Android new flash ic
    Added MTK Android Auto Format (nand+emmc)
    Adjust SPD Android Root
    Added LOT of new SPD Android Phones for SAVE Format & Root etc
    you must verify for save format
    How to get verified that my phone is SAFE to FORMAT or ROOT ?
    Use This link for that and READ IT VERY CARE FULLY !!
    Here it some SuccessFul BETA Testing reports from VolcanoBox 2.1.9
    VolcanoBox 2.1.9 SuccessFull format ( Chinese Android TAB 3100 ) most problem was TAB
    Volcanobox 2.1.9 Successful format SPD Android 6820 (Feiteng mini N9300)
    What's new coming in next upcoming updates ?
    ( This screen shot Saved during Initial Testing, forget to take Write Flash screen soon i will post more details )
    Coming Soo SPD ANDROID READ FULL FLASH ( Almost ready )
    Coming Soon SPD ANDROID WRITE FULL FLASH ( Almost ready )
    Coming Soon Some SPD Android phones after even write Factory Flash file gave error "cft not calibrate" like Karbonn K1+ Solution ( Almost ready )
    Coming Soon Flash file server ( for that we are asking you to must register your box Please Read this thread for more details )
    and many other HOT Exclusive Updates are on the way !!
    ( This is not just Advertisement as i post Successful Read Flash image same like that i will post more details in upcoming updates )
    Caution :- You must Register your box before 01-Aug-2013. We will Block All Boxes which is not Registered !!
    for Registration you must use this Important Notice From VolcanoBox Team = Please Register your Box Before 1st-Aug-2013
    to Make sure of Quality & Continue Grand Updates you must have to use THIS LATEST VolcanoBox Ver 2.1.9 !!
    link tải: 2013.07.08%20VolcanoTool_v2.1.9.rar
    No Mirror Links Please !!
    No Thanks Posts Please !!
    Please Use This ver and Write here ALL BUGS with Complete DETAILS !!
    0967-225-468
  7. ( VH-Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    mobile_1980 (09-07-2013)
  8. #146
    V.I.P QuốcBình's Avatar
    Aug 2007
    GIA HUY MOBILE VŨNG TÀU
    bổ xung cho đầy đủ thông tin:
    Click this bar to view the full image.
    VolcanoBox 2.1.9
    Whats new ?
    Note Please :
    You must use Original GPG Cables with VolcanoBox !! i got some reports from Users that got problem in Box, After Investigate we found They were using NON GPG CABLES so from now whenever you bought Box from any one Please Confirm from him that he is giving you ORIGINAL GPG CABLES WITH VOLCANOBOX !! ELSE We will not Give you any kind of Warranty !! this is happen when you purchase VolcanoBox from NON Official RESELLER, so was a Notice for any one Please keep this in mind cause of FAKE Cables is Cause of HARDWARE Failure !! Thanks you
    Coming Soon SPD ANDROID READ FULL FLASH ( Almost ready )
    MediaFire Link
    HotFile Link
    GiaHuy Mobile-Song vĩnh.Tân phước.Tân thành.BRVT-0643.922.999-09888.7.1112
    VCB.0081000752371-Agibank.6004205000674-Mua bán,sữa chữa iphone-Nokia 8800
  9. #147
    Thành viên tích cực backbom_830's Avatar
    Mar 2012
    285 Nguyễn Tất Thành, MĐrăk, ĐăkLăk
    VolcanoBox 2.2.1
    Whats new ?
    Added SPD 6820/8810 Android Read Flash
    1st Read info then write Flash !!
    Added SPD 6820/8810 Android Write Flash (**BETA Don't write on Working phones can harm your phone)
    Added SPD 6531 Read Info
    Added SPD 6531 Read Flash
    Added SPD 6531 Format (for safety recommendations please backup data first, then load file to format)
    Added SPD 6531 Write Flash
    Added SPD 6531 Find Password
    SPD 6820/8810 new flash ic added
    MTK Andriod Write added new algorithm
    Adjust MTK Andriod change IMEI new algorithm,solve some imei lost after reset factory
    Adjust SPD Andriod ADB Read partition
    Adjust SPD Andriod Root and Format
    Added 625a imei repair meta mode ( software can show nothing but infact imei repaired in phone )
    Added Round 102 new Firmware for Root
    Added Round 123 new Frimware for format
    Always Readinfo 1st then do Format
    Always do MTK Android AUTO format
    Do not Customize MTK Android phones
    No need anymore registration
    Firmware update
    Must Connected to internet before you run it 1st time !!
    @ALL BETA TESTERS PLEASE DOWNLOAD THIS VER 2.2.1 VER AND USE IT
    if you got any Problem feel free to post complete details
    Hotfile.com: One click file hosting: VolcanoTool_v2.2.1_Final.rar
    Quang Nam Mobile 285-Nguyễn Tất Thành-MĐrăk-ĐăkLăk
  10. #148
    Jan 2007
    VolcanoBox 2.2.1.1 Server upgrated - Invalid license Solved - Server not found solved
    VolcanoBox 2.2.1.1
    Click here to download
    Whats New ?
    Solved - Invalid License Data
    Improved - Communication Speed
    Improved - Server Load
    How to solve Invalid License Data ?
    Click here to download this file
    Make it Unrar
    Double click on it ( Make sure to run it only 1 or 2 times )
    after run Volcanobox
    Problem should be Solved !!
    How to Solve Box not found in 2.2.1.1 & which was compromised on 2.2.1 & Which was working fine on 2.1.9
    Click here and read details
    What else new in this update ?
    This update have all contents from 2.2.1 Please have a look this thread
    VolcanoBox 2.2.1 Released - 31-07-2013 - The King is BACK !!!!
    Br
    Faisal_Computer
  11. #149
    V.I.P thanhtunggialai™'s Avatar
    Nam Định
    VolcanoBox 2.2.2
    What's new ?
    Added MTK one key ADB mode ROOT
    Added One key ADB mode Root for many other Cpu ( BETA )
    Solution for CFC
    Added One key to solve CFC don't calibrate
    Added One key for SPD Android to Solve Don't Calibrate
    Added new flash Support for Spd Android phones
    Download Link 1
    Download Link 2
    Thanh Tùng Mobile
    Địa chỉ : Chợ gạo - Thành Lợi - Vụ Bản - Nam Định
    Phone : 0905022590
  12. #150
    Jun 2008
    VolcanoBox 2.2.3
    !! The Ultimate Tool for All kind of Android Phones !!
    Whats new ?
    ۩⇨ MTK Android BOOT Increased to WIPE data and cache
    Supported for ROOTED Android Phone
    ۩⇨ MTK Android Increased a Reset GMAIL Account
    Support ROOTED Android Phones & Usb Debug Mode ON
    **Without DATA LOSTED
    **Supported All Most All Kind of Android Phones
    **Such has Original Samsung - HTC Etc
    MTK & SPD Phoones are TESTED
    ۩⇨ MTK Android adjustment su/unlock
    Supported Which Phones are ADB ROOT
    ۩⇨ Adjust MTK Android Write Flash
    ۩⇨ Optimization of SPD Android format
    How to Reset Gmail account ?
    Make Sure your phones is rooted & Usb Debug mode on
    Go to MTK TAB
    Click on One Key-Root
    Select Reset-Gmail from Options
    Plug phone
    Untick Auto pinfind
    Tick on Usb mode
    Click on run
    wait for software will tell you it's done and phone is being Restart
    Done !!
    What Kind of Phones it's support ?
    In Theory All kind Of Android phones Supported Include Original & Chinese too, Such as Samsung, Htc etc from Original phones and MTK, SPD etc Based Phones
    Will i have data lost after reset Gmail ?
    We had tested in MTK and SPD no Data Lost
    How to reset Gmail account of Original Mobiles ?
    Make sure Usb Debug On and Mobile is rooted
    Go to MTK TAB
    Plug phone
    Untick Auto pinfind
    Tick on Usb mode
    Click on run
    Done !!
    How to reset Gmail account of SPD Phones ?
    Go to MTK TAB
    Plug phone
    Untick Auto pinfind
    Tick on Usb mode
    Click on run
    Done !!
    Which is the Best tool for root ?
    Normal VolcanoBox can Root almost All kind of MTK and SPD Phones but you can use this tool, is really good and Easy and Effective !!
    Download Root Tool link 1
    Download Root Tool Link 2
    Watch Some Videos
    [YOUTUBEHD]4MyUucsiXa4[/YOUTUBEHD]
    [YOUTUBEHD]apOsC6HjshI[/YOUTUBEHD]
    [YOUTUBEHD]oron-LVEmF0[/YOUTUBEHD]
    [YOUTUBEHD]c94rSZvo4rE[/YOUTUBEHD]
    Detailed info about Invalid License DATA !!
    Let me Tell you, Now VolcanoBox is using Server as you all knows that and we have some data store into your pc via server which is in your Registry, If somehow your Antivirus / Fireware / Malware Detector / or any thing is protecting your windows will not allow Volcanobox software verify registry keys and results is Invalid license data. there could be some solution of this problem,
    Solution # 1
    Download this file
    Extract it
    Run it
    after Run Volcanobox will be fine
    Solution # 2
    Download this file
    Uninstall Completely Your antivirus/malware detector or any kind of shield
    Extract that file
    run it
    restart pc
    redownload 2.2.3 from internet
    run it
    Solution # 3
    Download VolcanoBox 2.1.9
    Download this file
    Run volcanoBox 2.1.9
    go to System
    Click on System Self-Test
    Click on System Recovery
    Extract that file
    Run that file
    Restart system
    Redownload 2.2.3
    Extract it
    Run it
    Solution # 4
    Click on start
    Click on Turn Off Computer
    Click on Turn Off
    Insert Windows Cd/DVD
    Format windows ( C Drive or where you install windows )
    Install Windows
    Install Drivers
    Do not Install any kind of Shield
    Download 2.2.3
    Run
    Invalid License DATA in log windows !!
    Run VolcanoBox 2.2.3
    go to System
    Click on System Self Test
    Restart System
    Should be ok
    Click here to download hotfile
    Click here to download MediaFire
    No more mirror please !!
    This ver mayhave problem in rooting
    Which phones we tested for Gmail reset is successfuly done without data lost
    We will not responsible if somehow your data is deleted !!
  1. NS Pro Update Post here
    By DNA in forum NS Dongle
    Trả lời: 72
    Bài viết cuối: 10-09-2016, 01:13
  2. GB-Key New Update AE Post Ở Đây
    By Lính Khang in forum Các thiết bị khác
    Bài viết cuối: 16-11-2012, 07:14
  3. Axe Box New Update AE Post ở đây
    By TuấnPhát_GSM in forum AxeBox
    Trả lời: 27
    Bài viết cuối: 16-01-2012, 09:38
  4. MT Box New Update AE Post ở đây !!!
    By HoangThong_hotrokythuat3 in forum MT-Box
    Trả lời: 35
    Bài viết cuối: 23-11-2011, 08:07
  5. CPF Box II New Update AE Post ở đây
    By TuấnPhát_GSM in forum CPF-BOX Ⅱ
    Bài viết cuối: 06-08-2011, 15:31
