Trang 9 của 16 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CuốiCuối
Kết quả 81 tới 90 của 159
  1. #81
    Moderator THIÊN UY™'s Avatar
    Bình Dương
    ATF v9.71 Update!! Public Discussion Thread:
    The Master Piece
  2. #82
    Nov 2012
    ĐỒNG THÁP
    ATF Lumia WP8 TP v9.80 Update!! 30 April 2013!! Release Date: April 30, 2013
    Firmware Version Required : 10.3.50
    Lumia Windows Phone 8.0 Dead Boot Repair via TP
    Supported Phones:
    Lumia 520T RM-913
    Lumia 520 RM-914
    Lumia 520 RM-915
    Lumia 521 RM-917
    Lumia 620 RM-846
    Lumia 720 RM-885
    Lumia 720T RM-887
    Supported Partition Repairs:
    M.B.R. (Master Boot Record)
    G.P.T. (GUID Partition Table)
    SBL1
    SBL2
    SBL3
    UEFI
    RPM
    TZ
    WINSECAPP
    Custom Read/Write eMMC Blocks also supported. The password is still
    "password" in HEX format.
    (Hint: RPL and Simlocks are inside a FAT12 Mountable Partition called DPP)
    Added Test Point Pictures for 520T, 520, 521, 620, 720 and 720T
    What's New ?
    * Lumia Windows Phone 8.0 Dead Boot Repair via TP
    * ATF FiRE Server Capable EXE (Flash Files/Links are still uploading)
    Bug Fixes:
    * Fixed Lumia Custom eMMC Read/Write Bug on new Hynix eMMC
    * Fixed SD Card Custom Password Masking
    Other Stuff
    * Complete Product Listing in Nokia.ini (as of April-30-2013)
    For this Update I give Special Thanks To:
    X-shadow's Wife for editing the Test Point Pictures for the new Lumia Windows 8.0 Phones.
    __________________________________________________ ________________________
    ATF Lumia WP8 TP v9.80 Update!! Public Discussion Thread:
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
  3. #83
    Nov 2010
    ATF AutoUpdate v9.83 - Some New Stuff - 08 May 2013 Release Date: May 08, 2013
    *** Only Available via the AutoUpdate Server ***
    1.
    Lumia WP8 Recovery Flashing Added
    Supported Phones:
    All Lumia WP8 Phones
    This will allow re-flashing of Lumia Phones which encountered an error during a previous firmware update (incomplete flashing). This will only work if BOOT Loaders are still OK.
    To perform recovery flashing:
    1. Run ATF Software, load the flash WP8 Flash File and click FLASH.
    2. Hold VOLUME_DOWN + POWER button until the phone will vibrate.
    3. Release VOLUME_DOWN + POWER button then connect USB Cable.
    4. Recovery Flashing will start and will Fix Partitions.
    2.
    BB5 Read Firmware Version via Flash Mode
    Supported Phones:
    All Single-CPU BB5 Phones (RAP3, RAPIDO, RAPUv1, RAPUv2, Broadcom and XG223)
    NOT Supported Phones:
    All Dual-CPU BB5 Phones (E90, N90, N95, N95-8GB, N73, N80 etc...)
    This will allow you to know the current firmware version inside the phone just in case the phone is dead. It will also prevent you from accidentally DOWNGRADING any BB5 Phone. USB and FBUS Connection are both supported.
    To check current firmware version:
    1. Click "Buscheck" or "Backup RPL" Button
    3.
    Added Alternative USB Boot Method in Settings
    In Settings --> Nokia Settings, check this:
    Use BB5 USB Boot Settings Type 2 (Fixes Booting Problem on some PC)
    If you get BB5 Booting Problems stuck at:
    "FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)"
    * Complete Product Listing in Nokia.ini (as of May-08-2013)
    Discuss Update Here:ATF Lumia WP8 TP v9.83 Update!! Public Discussion Thread: - GSM-Forum
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
  4. #84
    Bình Dương
    ATF v9.84
    Release Date: May 09, 2013
    Fixed Read Firmware Information via Flash Mode for some RAPU based phones (E5-00, C5-00, E6-00 etc...)
    ################################################## #######################################ATF v9.83
    1.
    Supported Phones:
    2.
    Supported Phones:
    3.
    ATF v9.80
    Lumia Windows Phone 8.0 Dead Boot Repair via TP (First In The World!)
    Supported Phones:
    Lumia 520T RM-913
    Lumia 520 RM-914
    Lumia 520 RM-915
    Lumia 521 RM-917
    Lumia 620 RM-846
    Lumia 720 RM-885
    Lumia 720T RM-887
    SBL1
    SBL2
    SBL3
    UEFI
    RPM
    TZ
    WINSECAPP
    What's New ?
    Bug Fixes:
    Other Stuff
    Who will buy this if you can get more in ATF?
    The Master Piece
  5. #85
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    Advance Turbo Flasher Found
    Driver Version : 00020824
    Library Version : 00030207
    Box Type : AdvanceBox Turbo
    Box Firmware : LogiCore 10.3.50
    Software Version : v9.84
    AdvanceBox SN : E2D37D6EC2
    Box Status : ACTIVATED
    Box Successfully Initialized
  6. #86
    Nov 2010
    ATF Auto Update v9.85 - 15 May 2013 ATF Auto Update v9.85 :
    Fix firmware check error on manually file selection
    To get the update use Auto update server
    Philippine: Gsmph
  7. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thanhphuek (15-05-2013)
  8. #87
    Thành viên chính thức LongBiênMobile's Avatar
    Tel: 0982 980 688 Y/M : long_gsm
  9. #88
    May 2011
    Hà Nội City
    ATF XG618 Support v9.90 Update!! 29 May 2013!!
    Release Date: May 29, 2013
    XGOLD 618 Support Added
    Supported Phones:
    Asha 301/3018 RM-839 - Fully Tested
    Asha 301/3018 RM-840 - Fully Tested
    Asha 301/3018 RM-841 - Not Yet Released
    Other Future XG618 Phones
    Supported Operations:
    Normal Firmware Flashing
    Downgrade Firmware Flashing
    Backup RPL
    Read/Write PM and PP
    *** Warning: DO NOT CROSS FLASH these phones. Always Flash with correct RM-XXX ***
    What's New ?
    * Improved BB5 Firmware Version Check via Flash Mode
    * Skip Firmware Version Check Option in Settings (If you want ATF to skip Firmware Version Check via Flash Mode)
    * New Reseller List Handler (No More Disappearing Resellers)
    * New WinUSB Driver for Lumia and New ASHA Phones (Old Drivers Removed)
    * Improved WinUSB Delphi Wrapper
    * 400% Speed Increase when Dumping eMMC Toshiba/New Hynix via TP
    Bug Fixes:
    * Fixed Read Firmware Information for Manually Loaded Flash Files (NON VPL)
    * Fixed bug that does not automatically select USB connection on ATF Startup
    * Fixed bug on Scan Phone that makes some new Rapuv2 phones reboot and fails to read Simlock Data (Nokia 500, 311 etc)
    Other Stuff
    * Complete Product Listing in Nokia.ini (as of May-28-2013)
    * Lumia 925
    * Lumia 928
    * Asha 501
    * Asha 301
    Known Limitations:
    * Firmware Version Check via Flash Mode does not support ADL Flashing
    For this Update We give Special Thanks To:
    Angel - For Reporting Bugs + Extensive Final Testing
    WAJID - For Beta Testing
    el-polaco - For Reporting Bugs
    sebagsm - For Reporting Bugs
    ATF XG618 Support 9.90 Update!! Public Disccusion Thread:
    http://forum.gsmhosting.com/vbb/f609...hread-1665598/
    Philippine: Gsmph
    The Master Piece
  10. #89
    Thành viên tích cực GSM_SONGCONG™'s Avatar
    Sông Công_ Thái Nguyên
    Repair Boot -Unlock-Mở Mạng-All các loại máy
    D/c:529 Ngã Tư Việt Đức-Sông Công-TN
    SDT: 0969926800 : Yahoo: dinhchien_yeuem
  11. #90
    Jan 2007
    ATF v10.00 JTAG, EMMC TOOLS Update!! 25 JUL 2013!!
    Advance Turbo Flasher v10.00
    Release Date: July 25, 2013
    Firmware Version Required : 10.3.70
    ATF JTAG Official Launch (Requires 1 time Activation)
    ATF JTAG
    [ATF JTAG]
    ATF JTAG Initial Phone Support List (All Lumia WP8 Released Phones):
    Lumia 928 RM-860
    Lumia 925 RM-910
    Lumia 925 RM-893
    Lumia 925 RM-892
    Lumia 920T RM-867
    Lumia 920 RM-822
    Lumia 920 RM-821
    Lumia 920 RM-820
    Lumia 820 RM-826
    Lumia 820 RM-825
    Lumia 820 RM-824
    Lumia 720T RM-887
    Lumia 720 RM-885
    Lumia 620 RM-846
    Lumia 521 RM-917
    Lumia 520T RM-913
    Lumia 520 RM-915
    Lumia 520 RM-914
    Main ATF JTAG Software Features:
    * Cheap 1 time Activation Cost with NO additional Hardware Purchase needed
    * Super Easy Nokia WP8 JTAG JIGS Already Available
    * Super Easy Interface... Simple and Effective
    * Clear JTAG Pinouts Viewer
    * Fast JTAG Connection (480 Mbps USB via ATF Box)
    * Fully Customizable Software GUI Language (Create your own Language File)
    * Repair any "DEAD BOOT" Lumia WP8 Phone
    * "QUICK FIX" Option - For Dead phones via Flashing
    * "FULL BOOT" Option - For Dead phones via eMMC Boot Corruption
    [eMMC Tool 2.0 Lite]
    Introducing eMMC Tool 2.0 Lite under "ATF Plus"
    * eMMC Read Speed increased 800% Faster
    * Supports Samsung Exynos 4 CPU with just 4 wires to solder (LIVE PHONE ONLY for NOW)
    * Supports Snapdragon CPU with just 4 wires to solder
    * Supports Reading and Writing to USER AREA, BOOT1, BOOT2, RPMB, GP1, GP2, GP3 or GP4 Partition
    * NON Encrypted READ/WRITE Functions
    [New ATF Box Firmware]
    Introducing LogiCore 10.3.70
    * Enhanced eMMC Reading Speeds up to 1.85 MBPS @ 15.00 Mhz
    * 1 GB Dump = 7-8 minutes
    * TP Unlocks WP7 (710 and 800) in less than 30 seconds for any eMMC Brand
    * Fixed Toshiba and new Hynix ack delay issues
    * Improved SD Card BF Speed
    * Enabled SPI Flash Direct Programming
    * Improved FBUS DDR + 2TX Speed now up to 18.00 Mhz
    [Infineon XG213]
    * Automatically Reads RPL in Plain Binary Format on every Flash Boot
    * Automatically Reads PM in Plain Binary Format on every Flash Boot
    * Automatically Reads Security Code on every Flash Boot (No need Local Mode)
    * Added New Loaders for all released XG213 Models
    [WP8]
    * Improved Flashing to accommodate SUPER big Verizon Flash Files
    * Added Latest Variant Listing as of July 25, 2013
    [WP7]
    * Greatly Improved TP Unlock Speed and Patch Firmware Checking
    * Fixed Problem on Toshiba and new Hynix Unlock Problem on ATF Chrome Box
    [BB5]
    * Removed Phone Firmware Checking if Selected in Settings the option:
    "Skip Firmware Version Checking on BB5 Phones before Flashing"
    [DCT4]
    * Fixed DCT4 RPL via Server Problem "You do not have free credits..."
    What More to Expect ???
    1. Separate EXE for eMMC Tool 2.0 to be released soon...
    2. Add other phone brands for ATF JTAG Support ?
    ATF v10.00 JTAG, EMMC Update!! Public Disccusion Thread:
    International - Advance Turbo Flasher - By Advance Team - ATF Lightning - ATF Nitro - Fastest Flasher in world - Nokia flasher - ATF Samsung - First in the world
    Philippine: Gsmph
    Chinese Support forum : yananliuhuan.com
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
