Trang 6 của 16 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... CuốiCuối
Kết quả 51 tới 60 của 159
  1. #51
    Moderator VuongKhoaMobile's Avatar
    Mar 2010
    Mặc định ATF Lumia & Micro SD BruteForce v8.5 Update
    ATF Lumia & Micro SD BruteForce v8.5 Update!! 28 FEB 2012!!
    Windows Phone Lumia Flashing Engine Fully Supported
    --> FULL FLash Lumia 800, 800.2, 710, 710.1, 610 and other upcoming Windows Phone Devices
    --> Firmware Downgrade supported for ALL Lumia Products
    --> Partial Flashing Supported for ALL Lumia Products (Skip Mode, Skip WPOS, Skip OSBL etc...)
    --> Supports Dead and Alive Phone
    --> Can Scan Live Phone
    --> Cross-Flashing Supported for Products with the same Roothash (710 <--> 710.1 or 800 <--> 800.2)
    --> Boot OSBL via NORMAL MODE Fully Implemented (No need to power off phone)
    --> No need to press the VOLUME UP Button for Lumia 710 and Lumia 710.1
    Micro SD Card Password Bruteforce Now Implemented
    --> Customizable Character Sets Available (small caps only, digits only etc)
    --> Supports all Types of micro SD Card from 32MB upto 128GB
    --> Customizable Min and Max Length of Password Mask
    --> Pause/Resume Supported
    --> Automatically Saves RESUME File every 500 Passwords
    Micro SD Card Total Erase (Low Level Erase)
    Bug Fixes:
    1. Fixed GUI Hang when FBUS Simlock Backup Fails at the Start of Flashing.
    2. Fixed FBUS Booting when receiving receiving incomplete BB5 Boot Code.
    Other Updates:
    1. Added Complete New Product Listing Inside Nokia.ini
    2. Removed iTablets Legacy Flasher (iTablets and MEego are Now Fully Inside BB5 Tab)
    3. Improved BB5 Product Scanning after a Complete Flash
    Who will buy this if you can get more in ATF?
    __________________________________________________ ________________________
    Buy only from ATF [Advance Turbo Flasher] authorized resellers:
    ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
    ATF [Advance Turbo Flasher] official web sites:
    International - http://www.advance-box.com/
    ATF [Advance Turbo Flasher] official support forums:
    World Wide: Advance Turbo Flasher - GSM-Forum
    Indonesia: ATF (Advance Turbo Flasher))
    Philippine: Gsmph
    Syria: Arabic Support (Syria) GsmVIP
    Chinese support forum : ATF Box
    Vietnam: Saigonmobile
    India: Advance Box - .:: GsmIndia ::.
    Official Iran Support Forum : ASANGSM FORUM
    Bangladesh: Advance Box - Dhaka Mobile
    Chinese Support forum : www.yananliuhuan.com
    The Master Piece
  2. #52
    Thành viên danh dự TuấnPhát_GSM's Avatar
    Jan 2009
    Mặc định ATF ULTRA v8.60 Update !! 29 MAR 2012!!
    Advance Turbo Flasher v8.60
    ATF Box New Firmware LogiCore 10.3.12 Official Release
    --> Fixes SD Card Slot Issues on ATF Big Chrome Boxes
    --> Enables the use of ATF SD Card Cable Accessory for ATF Lightning and Nitro Boxes
    --> More Stable FBUS Flashing for RAP3Gv30 Phones
    --> 13% Speed Increase in Nitro FBUS Flashing
    --> 5% Speed Increase in USB Flashing (BB5, Infineon, MAEMO and MEEGO)
    ATF New Driver for New Firmware
    --> New More Stable FTDI Driver Set for better Operation when used with other GSM Boxes
    Rapido "Boom Boom Pow" Update
    --> (Boom) First in the World RAPIDO Full RPL Certificates (NPC, HWC, CCC and R&D) Backup via USB Cable Only
    --> (Boom) First in the World RAPIDO Full Flash Chip Reading via USB Cable Only
    --> (Pow ) RAPIDO Phone Authorize using ATF Network via USB Cable Only*
    ATF BB5 Software Enhancements:
    --> BUSCheck Button in USB Mode is now Enabled for ALL New Generation Single CPU BB5 and Infineon Phones**
    --> Backup RPL Button in USB Mode is now Enabled for ALL New Generation Single CPU BB5**
    --> Write RPL via USB is now Enabled for ALL BB5 RAPIDO Phones (RAPIDOYAWEH not Supported)
    --> Write RPL via USB is now Enabled for ALL BB5 RAP3Gv40 Phones
    --> Write RPL via USB is now Enabled for ALL BB5 RAPUYAMA v1.1 Phones
    --> Write RPL via USB is now Enabled for ALL BB5 RAPUYAMA v2.1 Phones
    --> Write RPL via USB is now Enabled for ALL BB5 BCM21351 Phones (Broadcom)
    --> Custom Erase Flash Chip via USB is now Enabled for ALL BB5 RAPIDO Phones (RAPIDOYAWEH not Supported)
    --> Custom Erase Flash Chip via USB is now Enabled for ALL BB5 RAP3Gv40 Phones
    --> Custom Erase Flash Chip via USB is now Enabled for ALL BB5 RAPUYAMA v1.1 Phones
    --> Custom Erase Flash Chip via USB is now Enabled for ALL BB5 RAPUYAMA v2.1 Phones
    --> Custom Erase Flash Chip via USB is now Enabled for ALL BB5 BCM21351 Phones (Broadcom)
    --> Permanent Memory Area (PM) is now Initialized Before Writing
    --> Upto 7 Flash Files can now be displayed with Scrolling Down the Flash File List
    --> VPL Details are now Displayed in the Main Log Window
    --> New button "Check" can now be used to determine whether your Downloaded Flash files are corrupted or not
    --> Added Force 64K CNT Page is now Available in both FBUS and USB Connections
    --> Original SX4 Server is now updated and fixed to v1.50 Protocol
    --> Software Logs for USB Flashing Phone #2 is now Saved
    --> Software Logs for SD BF is now Saved
    --> New Feature Decrypt PM 308 will decrypt all PM 308 blocks and save it into a file
    Micro SD Card Brute Force Module Update:
    --> Speed Cap for SD Card Bruteforce is Now Removed (Now you can BF with MAXIMUM SD CARD SPEED***)
    --> Fixed Bug on Detecting Lock Status of some "non standard" Cards
    --> Enabled Option to use ATF SD Card Cable
    General Software Bug Fixes:
    --> Enable Logging Option in Settings --> General Settings is now Enabled
    --> Fixed Bug of UI Crashing when Flash File List is double-clicked
    --> Super Dongle Keys are now Checked Before getting access to use the Original SX-4 Server
    --> Enabled WinUSB Driver detection and installation upon Program Start-Up
    Other Updates:
    --> Updated New Phone Models inside Nokia.ini
    Notes:
    * ATF Network Activation is Required for Authorizing RAPIDO Phones via USB Connection
    ** Single CPU means that the BB5 Phone does not have a separate APE CPU.
    Examples of Dual CPU Phones: N95-8GB, 6630, N90, E90
    Rap3Gv3 Phones are not supported for USB Buscheck as well (5130c, 3110c, 7210c, 6300c)
    *** SD Card BF Speed Depends on the Actual SD Card. Speeds may vary
    from 45 passwords per second to 25,000 passwords per second.
    DOWNLOAD HERE:
    Offical Hotfile Mirror
    Offical Mirrorcreator Mirror
    DOWNLOAD HERE:
  3. ( TuấnPhát_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TUYHOAGSM™ (30-03-2012)
  4. #53
    Executive Administrator TUYHOAGSM™'s Avatar
    Oct 2007
    TP.Tuy Hòa
    Arrow ATF Minor Update v8.62 released:
    What's new:
    Fixed RAP3Gv3 USB Flashing "MCU CONFIGURATION IS NOT VALID"
    Fixed Battery Value 0 Error When Flashing via USB
    Fixed USB Booting Problem Delay on FUR
    Fixed FBUS Buscheck Timeout Delays (Faster Buschecks Now)
    Fixed Infineon SP Lock Table Reading
    Get new ATF SW from here:
  5. #54
    Super Moderator TuệNguyễn's Avatar
    TP Hồ Chí Minh
    ATF new V8.63
    Unlock-repair boot-repair imei-repair emmc-nạp Tiếng Việt all smart phone
    ĐC: 159/7/2 Đường TTH07 Phường Tân Thới Hiệp Q12 TPHCM
    ĐT: 0903135569 - Skype: tuenguyen.79
  6. #55
    Thành viên tích cực ngocminhhungyen's Avatar
    Feb 2009
    jhhj
    ATF v8.70 Update!! 25 APR 2012!! Flashing Updates:
    --> Lumia 900 RM-808 and RM-823 Now Fully Supported and Tested
    --> Blocked Cross Flashing a X3-02.5 (RM-775) with a X3-02 (RM-639) Flash File
    --> Blocked Cross Flashing a C3-01.5 (RM-776) with a C3-01 (RM-640) Flash File
    --> Dual CPU (CMT + APE) New Protocol FBUS Flashing Re-Activated (N95, E90)
    --> Dual CPU (CMT + APE) Phone Authorize via The ATF Network Re-Activated
    --> Dual CPU (CMT + APE) ADL USB Flashing Re-Activated (N95-8GB, N95, N73, E90)
    --> Dual CPU (CMT + APE) First In The World ADL USB Recovery Flashing (N95-8GB, N95, E90)
    Other Updates:
    --> Improved Drive Detection for ALL SYMBIAN APE Phones...
    --> FORMAT FILE SYSTEM Now Supports S40 FILE2 Drives (5130c, X2-01, etc..)
    --> REMOVE SD Card Password via S40 Phone FILE2 Format of Drive E:
    DCT4 Update:
    --> DCT4 ASIC 2-5-6-7 SP Data Rebuild for DIRECT UNLOCK and REPAIR
    Other Updates:
    --> New Products Added to Nokia.ini
    Bugs Killed in this Update:
    --> Fixed SUB SCAN PHONE = PC Restart Bug on some AMD and Intel Core2 Computers
    --> Fixed USB Flashing "MCU CONFIGURATION IS NOT VALID"
    --> Fixed Battery Value 0 Error When Flashing via USB
    --> Fixed USB Booting Problem Delay on FUR
    --> Fixed FBUS Buscheck Timeout Delays (Faster Buschecks Now)
    --> Fixed Bug on Unsupported "NORMALIZE SUSD" Flash Files
    --> Fixed RAP3Gv3 FBUS Flashing Bug "Please Check RX2 Blah Blah..."
    --> Adjusted Infineon USB Flashing to exit properly during a Flash Error
    Special Thanks Goes To:
    ashish_gsm <-- USB Scan Phone Surrogate PC for Debugging
    MOYAL <-- USB Scan Phone Fix Beta Tester
    Some Clarifications:
    1. Old Phones Can now be flashed with New Loaders and New Protocol (like 5130 and N95-8GB).
    But it is still BETTER to use OLD PROTOCOL and OLD LOADERS for these Phones.
    2. You can now flash N95-8GB, N73, E90 etc via USB Cable Only.
    3. Nitro and Lightning users can now EASILY REMOVE Password from any SD Card without buying
    or making an SD Card Cable Adapter. Simply put SD Card inside a S40 Phone like 5130c or
    X2-01 etc... When card is now inside the phone, use FILE SYSTEM FORMAT Option to Format
    Drive E:... That is it!
    ATF v8.70 Update!! Public Discussion Thread:
    Philippine: Gsmph
    The Master Piece
    Repair - Unlock - Nạp tiếng việt - Chuyển hệ cho tất cả các loại ĐTDĐ
  7. #56
    Thành viên chính thức hungthinhmobi's Avatar
    Mar 2012
    MR. ATF WHY My ATF Have FTD2XX.DLL PROBLEM AND FBUS BOOT PROBLEM??? (ANSWER INSIDE)
    Just Update your ATF Box Drivers to 2012 version...
    Too lazy to download the full installer for 8.70 ???
    Ok ok, here is the link for the New Drivers Only...
    http://174.120.45.27/tmp/ATF_NEW_DRIVERS.rar
    Update first the "AdvanceBox Programming Port" ...
    Windows will ask you to RESTART you PC after you update the driver...
    after windows restart, then update
    "AdvanceBox Turbo Flasher"
    Both of them should become driver version
    2.08.23
    02/07/2012
    If you do not see the same version as above, then you did something
    wrong...
    Windows always tries to be smart and automatically find a suitable
    driver for you... BUT NO, DO NOT LET WINDOWS INSTALL AUTOMATIC!!!
    Manually tell Bill Gates to use driver:
    Remember,,, 8.70 super duper update need super duper 2012 Driver.
    You must see EXACTLY LIKE THIS:
    Unlock-Mở Mạng-Sửa Lỗi Phần Mềm-Nạp TV
    Y!h:hungthinh0939157157
  8. #57
    Jan 2007
    ATF v8.80 New Update!! Public Discussion Thread:
    Advance Turbo Flasher v8.80
    Flashing Updates:--> Lumia Flashing Optimization for 610, 710, 800 and 900 Flash Files
    --> BB5 USB Flashing Default Timeout Corrections on RAPUYAMA Booting
    --> BB5 DUAL CPU New Protocol Flashing (N95, N95-8GB, N90 Etc) Speedup
    Driver Updates:
    --> New ATF Box FTDI Drivers 2.08.24
    --> Nokia Connectivity Driver v7.1.78.0
    --> Lumia New WinUSB Drivers (32-Bit and 64-Bit)
    Bug Fixes:--> DCT4 ASIC 2-5-6-7 Direct Unlocking Fixed for Custom Profile Bits
    Download from here:
  9. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    TUYHOAGSM™ (01-06-2012)
  10. #58
    TP Hồ Chí Minh
  11. ( TuệNguyễn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #59
    V.I.P -=Nguyên=-'s Avatar
    Mar 2012
    Khánh Hòa
    ATF 8.90 Nitro SD Update!! 26 JUN 2012!!
    Introducing the Official ATF Nitro SD Reader.
    The ATF Nitro SD Reader enables Micro SD Card Brute-Force and
    Factory Formatting Functionalities for ALL ATF Boxes without
    Micro SD Card Ports. It also works on the Original ATF Chrome Box.
    Features:
    Ultra-Fast Communication Speed (upto 25 Mhz for Hi-Speed Capable Cards).
    Fastest Brute-Force Speed with Intelligent Card Speed Threshold Adjustment.
    First and ONLY Device in the GSM Industry that can retrieve SD Card Passwords without FORMAT.
    Compatibility:
    Compatible with ATF Lightning, ATF Nitro and ATF Chrome Boxes with LogiCore 10.3.12 or Higher.
    Compatible with ALL Micro SD Card Brands that conform or don't conform to the SD Standards.
    Compatible with ALL Micro SD Card Capacities (Tested upto 128 GigaBytes).
    Flashing Updates:
    --> Added Support for Newer Mass Memory Content Files
    --> Only Scans Existing VALID Directories for Flash Files
    --> Skips MEEGO/MAEMO Flash File Intensive Pre-Parsing
    Other Updates:
    --> Custom PM Erase Section and Sub Field (For Expert Use Only)
    --> Support for ATF Nitro SD Card Reader for SD Card BF and Factory Formatting
    --> Added New Phones inside Nokia.ini
    Bug Fixes:
    --> Fixed AUTO-ADL Flashing Selection on LIVE RAPIDO Phones
    --> Fixed Incorrect SP Lock/Open Status on One Specific Service Provider
    --> Fixed USB "ULTRA SLOW" Mass Memory Flashing for Built-In EMMC Chip
    --> Fixed Some Wrong Entries inside Nokia.ini
    DOWNLOAD HERE:
    ATF v8.90 Nitro SD Update!! Public Discussion Thread:
    ATF v8.90 Nitro SD Update!! Public Discussion Thread: - GSM-Forum
    International - Advance Turbo Flasher - By Advance Team - ATF Lightning - ATF Nitro - Fastest Flasher in world - Nokia flasher - ATF Samsung - First in the world
    Nguyên - 240B Trần Quý Cáp - Ninh Hòa - Khánh Hòa
    Phone: 0947.000.369 Yahoo: unlock_care Vietcombank:
    0061000793784
  13. #60
    Nov 2010
    ATF v8.92 Auto-Update 29 JUN 2012!!! Public Discussion Thread: A New EXE Update v8.92 has been uploaded to the ATF Server.
    To Get this Update, please follow the Steps Below:
    1. Make Sure
    "Automatically Check for Updates" is Checked...
    2. Restart ATF Exe, and you will get POP-UP Message Like this:
    *** Click YES ***
    3. You can check the Download Status on ANY of the tabs in "Product Support"
    4. After Software restarts, you now have the NEW VERSION but you might need to "UPDATE IMPORTANT FILES" if necessary.
    5. "UPDATE IMPORTANT FILES" if necessary.
    6. After ALL Necessary Files are updated, Restart ATF EXE and Enjoy the New Update!
    Flashing Updates:
    --> New Nokia Flash Loaders 12.14.001.4
    Bug Fixes:
    --> Fixed "ULTRA SLOW" Flashing of S40 PPM and CNT Files
    --> Adjusted FUR New Protocol Booting
    Philippine: Gsmph
    The Master Piece
  14. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ThanhHaMobile™ (29-06-2012)
  1. Update Mcn-pro anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum McnPro Box
    Trả lời: 91
    Bài viết cuối: 31-01-2015, 07:58
  2. Update Gpgdragon anh em vui lòng post ở đây!
    By HoangThong_hotrokythuat5 in forum GPGDragon
    Trả lời: 125
    Bài viết cuối: 25-06-2014, 22:08
  3. Update Z3X China anh em vui lòng post ở đây
    By htv1810 in forum Z3X Dongle for Сhina Editor
    Trả lời: 16
    Bài viết cuối: 26-04-2012, 17:30
  4. Update SpiderMan anh em vui lòng post ở đây
    By HoangThong_hotrokythuat5 in forum SpiderMan Box
    Bài viết cuối: 18-06-2011, 11:52
  5. Z3x samsung update anh em vui lòng post tại đây
    By HoangThong_hotrokythuat4 in forum Z3X-BOX FOR SAMSUNG
    Bài viết cuối: 05-10-2010, 16:34
